<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango API: &quot;connectivity lost, restoring connection&quot;]]></title><description><![CDATA[<p dir="auto">Hi, I have done the following steps as per documentation:<br />
1)edit env.properties file swagger.enabled=true in the mango/override/properties folder<br />
2)Restart Mango<br />
3)login as admin user</p>
<p dir="auto">However I encounter message prompt from the bottom of screen "connectivity lost, restoring connection".The mango instance restart again and again.</p>
<p dir="auto">Looking into the developer tools, I found the issue is the api connection.<br />
Next I disable the swagger.enabled=false, and login mango again. This time everything is back to normal without connectivity issue.</p>
<p dir="auto">May I know what could be wrong  and any advise to enable mango api correctly?</p>
<p dir="auto">-mango core 3.4.5<br />
-mangoAPI 3.4.4</p>
<p dir="auto">Thanks &amp; regards<br />
Desmond Luong</p>
]]></description><link>https://forum.mango-os.com/topic/3695/mango-api-connectivity-lost-restoring-connection</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 12:17:50 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3695.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 06 Aug 2018 09:34:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango API: &quot;connectivity lost, restoring connection&quot; on Mon, 06 Aug 2018 10:23:06 GMT]]></title><description><![CDATA[<p dir="auto">After my attempt to shut down the MangoES and reboot it, now I see magic, It works!</p>
<p dir="auto">It is a false alarm and thank you <a class="plugin-mentions-user plugin-mentions-a" href="/user/craigweb" aria-label="Profile: CraigWeb">@<bdi>CraigWeb</bdi></a> for your fast response.</p>
]]></description><link>https://forum.mango-os.com/post/19424</link><guid isPermaLink="true">https://forum.mango-os.com/post/19424</guid><dc:creator><![CDATA[Desmond]]></dc:creator><pubDate>Mon, 06 Aug 2018 10:23:06 GMT</pubDate></item><item><title><![CDATA[Reply to Mango API: &quot;connectivity lost, restoring connection&quot; on Mon, 06 Aug 2018 11:09:44 GMT]]></title><description><![CDATA[<p dir="auto">Hi Desmond</p>
<p dir="auto">I am sure the IAS staff will ask for your ma.log file.  You might as well post it so long...  Is the instance running on a Mango ES or a server ?</p>
]]></description><link>https://forum.mango-os.com/post/19423</link><guid isPermaLink="true">https://forum.mango-os.com/post/19423</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Mon, 06 Aug 2018 11:09:44 GMT</pubDate></item></channel></rss>
