<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Excel Report]]></title><description><![CDATA[<p dir="auto">Hello, I have a problem with excel report, it generated about 10 reports and nothing started to generate no more. He does not fail, he just keeps on turning.</p>
<p dir="auto">I'm sending the console logging.</p>
<p dir="auto"><a href="https://drive.google.com/file/d/1eRssFfP6JMF6HtZtzMuu6Os7CWRUfH6n/view?usp=sharing" rel="nofollow ugc">https://drive.google.com/file/d/1eRssFfP6JMF6HtZtzMuu6Os7CWRUfH6n/view?usp=sharing</a></p>
]]></description><link>https://forum.mango-os.com/topic/3617/excel-report</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 14:54:23 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3617.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 27 Jun 2018 11:40:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Excel Report on Tue, 24 Jul 2018 16:51:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> said in <a href="/post/19281">Excel Report</a>:</p>
<p dir="auto">the top section of /system_settings.shtm</p>
<p dir="auto">I just checked the top section of /system_settings.shtm and I actually saw that you are using H2.</p>
<p dir="auto">I think it was something of the update, because I made an update and since then it did not work anymore, but before that it was like MYSQL.</p>
<p dir="auto">I will pass the database to MYSQL and check if the error will continue.</p>
]]></description><link>https://forum.mango-os.com/post/19289</link><guid isPermaLink="true">https://forum.mango-os.com/post/19289</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Tue, 24 Jul 2018 16:51:20 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Tue, 24 Jul 2018 15:08:15 GMT]]></title><description><![CDATA[<p dir="auto">I see you sent in your log file to <a href="mailto:support@infiniteautomation.com" rel="nofollow ugc">support@infiniteautomation.com</a></p>
<p dir="auto">If that is fully up to date, then you are still using H2</p>
]]></description><link>https://forum.mango-os.com/post/19283</link><guid isPermaLink="true">https://forum.mango-os.com/post/19283</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 24 Jul 2018 15:08:15 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Tue, 24 Jul 2018 14:53:01 GMT]]></title><description><![CDATA[<p dir="auto">Hmm. Well, the DATA4 column was not created by Mango, nor was the index on it.</p>
<p dir="auto">You could post the stack trace produced by running a report here and perhaps it will shed some different light than that from the H2 attempt (copy it from the log file)</p>
<p dir="auto">The other thing MySQL would enable is a <code>show create table pointValues;</code> statement and a <code>show create table pointValueAnnotations;</code></p>
<p dir="auto">You may also want to post a screenshot of the top section of /system_settings.shtm so we can ensure this is indeed MySQL.</p>
]]></description><link>https://forum.mango-os.com/post/19281</link><guid isPermaLink="true">https://forum.mango-os.com/post/19281</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 24 Jul 2018 14:53:01 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Tue, 24 Jul 2018 12:28:59 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I switched to MySQL as recommended, but started to make the same mistake. Follow the error photo</p>
<p dir="auto"><img src="https://camo.nodebb.org/2b2f745f2dafa365c2d41042087fcf524ece3378?url=https%3A%2F%2Fi.imgur.com%2FxdVYOFb.png" alt="0_1532435544683_erro relatorio.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/19279</link><guid isPermaLink="true">https://forum.mango-os.com/post/19279</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Tue, 24 Jul 2018 12:28:59 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 18:49:46 GMT]]></title><description><![CDATA[<p dir="auto">This is a pretty good site for those kinds of questions: <a href="https://help.infiniteautomation.com" rel="nofollow ugc">https://help.infiniteautomation.com</a></p>
<p dir="auto">I found your answer here:<br />
<a href="https://help.infiniteautomation.com/database-conversions/?rq=convert%20database" rel="nofollow ugc">https://help.infiniteautomation.com/database-conversions/?rq=convert database</a></p>
]]></description><link>https://forum.mango-os.com/post/19076</link><guid isPermaLink="true">https://forum.mango-os.com/post/19076</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Thu, 28 Jun 2018 18:49:46 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 18:48:15 GMT]]></title><description><![CDATA[<p dir="auto">Ah ok thanks, I typed the wrong password. I already made another user use root only for testing.</p>
<p dir="auto">But do you know if I can copy the data from the old database to the new sql? I tried the backups but it did not work if you missed a large part of the setup.</p>
]]></description><link>https://forum.mango-os.com/post/19075</link><guid isPermaLink="true">https://forum.mango-os.com/post/19075</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Thu, 28 Jun 2018 18:48:15 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 18:25:30 GMT]]></title><description><![CDATA[<p dir="auto">The log says:</p>
<pre><code>'Cannot create PoolableConnectionFactory (Access denied for user 'root'@'localhost''
<p dir="auto">This is probably due to a permissions problem with MySQL or you have put in the wrong password.  I have found that setting up permissions in MySQL is a little tricky.</p>
<p dir="auto">First make sure you can connect to the 'mango' database in MySQL as the root user from the command line or the MySQL Workbench application.  Then restart mango.</p>
<p dir="auto">I would guess that the root user does not have permissions to access the mango database from localhost.  In MySQL each user has permissions to databases based on hostname/IP address.</p>
]]></description><link>https://forum.mango-os.com/post/19074</link><guid isPermaLink="true">https://forum.mango-os.com/post/19074</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Thu, 28 Jun 2018 18:25:30 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 18:19:05 GMT]]></title><description><![CDATA[<p dir="auto">Follow the link</p>
<p dir="auto"><a href="https://drive.google.com/file/d/19-tQDbCn9bl1yHeCeiOLPBST7QJTmcAd/view?usp=sharing" rel="nofollow ugc">https://drive.google.com/file/d/19-tQDbCn9bl1yHeCeiOLPBST7QJTmcAd/view?usp=sharing</a></p>
]]></description><link>https://forum.mango-os.com/post/19073</link><guid isPermaLink="true">https://forum.mango-os.com/post/19073</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Thu, 28 Jun 2018 18:19:05 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 18:14:56 GMT]]></title><description><![CDATA[<p dir="auto">Can you zip up the logs/ma.log file from the Mango folder and post that?  There will be the reason why it failed to start in the logs and I can then tell you how to fix it.</p>
]]></description><link>https://forum.mango-os.com/post/19072</link><guid isPermaLink="true">https://forum.mango-os.com/post/19072</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Thu, 28 Jun 2018 18:14:56 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 18:08:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/terrypacker" aria-label="Profile: terrypacker">@<bdi>terrypacker</bdi></a> he does not start, and the service is in active status</p>
<p dir="auto"><img src="https://camo.nodebb.org/d5d84030a74952020d3fd4037f4d0e1664faff32?url=https%3A%2F%2Fi.imgur.com%2FXpnbJMf.png" alt="0_1530209487404_gfgdfgf.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/19071</link><guid isPermaLink="true">https://forum.mango-os.com/post/19071</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Thu, 28 Jun 2018 18:08:54 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 17:56:23 GMT]]></title><description><![CDATA[<p dir="auto">Post the log file from the failed startup.</p>
]]></description><link>https://forum.mango-os.com/post/19070</link><guid isPermaLink="true">https://forum.mango-os.com/post/19070</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Thu, 28 Jun 2018 17:56:23 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 17:36:29 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I downloaded mysql, created the database mango, and modified the /classes/env.properties file as requested.</p>
<p dir="auto">Regarding the H2, I put all the commands as comments. Here's how it went:</p>
<pre><code># Default database settings, NOTE that on windows this must be an absolute path
#db.type=h2
#db.url=jdbc:h2:${ma.home}/databases/mah2
#db.location=${ma.home}/databases/mah2
#db.username=
#db.password=
#For web console
#db.web.start=false
#db.web.port=8091
#to compact the database size at shutdown (may take longer but will free up disk space)
#db.h2.shutdownCompact=false
<p dir="auto">And I made the following configuration in the mysql part:</p>
<pre><code># MySQL database settings. Your MySQL instance must already be running and configured before this can be used.
db.type=mysql
db.url=jdbc:mysql://localhost/mango
db.username=root
db.password=qnhopwp9
#db.mysqldump=&lt;location/command for mysqldump executable for backups&gt;
#db.mysql=&lt;location/command for mysql executable for restore&gt;
<p dir="auto">I did not move in any other line.</p>
<p dir="auto">I did as I understood, but the system is no longer  initializing. If someone can help me I would be very grateful</p>
]]></description><link>https://forum.mango-os.com/post/19069</link><guid isPermaLink="true">https://forum.mango-os.com/post/19069</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Thu, 28 Jun 2018 17:36:29 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 13:43:16 GMT]]></title><description><![CDATA[<p dir="auto">You could try to use MySQL, I believe the error message is caused because the H2 database is trying to create an index on a temporary table.  It seems you are using a large number of data points for this report.</p>
<p dir="auto">MySQL info here: <a href="https://help.infiniteautomation.com/installation-configuration/?rq=MysQL" rel="nofollow ugc">configuration info here</a></p>
]]></description><link>https://forum.mango-os.com/post/19067</link><guid isPermaLink="true">https://forum.mango-os.com/post/19067</guid><dc:creator><![CDATA[terrypacker]]></dc:creator><pubDate>Thu, 28 Jun 2018 13:43:16 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Thu, 28 Jun 2018 11:01:54 GMT]]></title><description><![CDATA[<p dir="auto">Hello, but I have already re-programmed the program, I downloaded it again from the site, I set it up step by step and started to make the same mistake, I'm having to look for other programs because every time I redo the program it generates about 7-10 reports and then so it hangs. If I can not find a solution I will have to change software because it is costing me a lot of time. Do you have no idea what this problem might be?</p>
]]></description><link>https://forum.mango-os.com/post/19066</link><guid isPermaLink="true">https://forum.mango-os.com/post/19066</guid><dc:creator><![CDATA[leoboeng]]></dc:creator><pubDate>Thu, 28 Jun 2018 11:01:54 GMT</pubDate></item><item><title><![CDATA[Reply to Excel Report on Wed, 27 Jun 2018 15:48:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi leoboeng,</p>
<p dir="auto">The reason the status is not updating is that the error message provided was too large for the database column that saves it on a failed report. This has been resolved in the next release of the ExcelReports module. As to the cause of the failure, that is the same messages about a "DATA4" column that isn't created by Mango and apparently cannot have an index. I do not know why you have an error about column DATA4, I was not able to reproduce the first time you asked about that, even given a database backup from you to try.</p>
]]></description><link>https://forum.mango-os.com/post/19038</link><guid isPermaLink="true">https://forum.mango-os.com/post/19038</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 27 Jun 2018 15:48:49 GMT</pubDate></item></channel></rss>
