<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Point Values]]></title><description><![CDATA[<p dir="auto">Hello, began to give a message in my points values:</p>
<p dir="auto">"Values of points limited to 5001 values, please shorten the time interval or adjust the rollup interval"</p>
<p dir="auto">Can each point have only 5001 values? Can not put an infinite number of values? Well I need to update the values of the points every 10 minutes and this ends up locking my system.</p>
]]></description><link>https://forum.mango-os.com/topic/3528/point-values</link><generator>RSS for Node</generator><lastBuildDate>Wed, 22 Apr 2026 21:27:49 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3528.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 25 May 2018 12:10:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Point Values on Fri, 25 May 2018 14:38:51 GMT]]></title><description><![CDATA[<p dir="auto">Hi guys,</p>
<p dir="auto">Series are limited to millisecond resolution for storing values and if using the NoSQL database will not have more than one value at one millisecond.</p>
<p dir="auto">The charting limit is indeed 5001 by default and can be changed. <a href="https://forum.infiniteautomation.com/topic/2983/increase-the-5001-limit-on-values-in-the-new-dashboards-ui" rel="nofollow ugc">https://forum.infiniteautomation.com/topic/2983/increase-the-5001-limit-on-values-in-the-new-dashboards-ui</a></p>
<p dir="auto">TLDR Administration --&gt; UI Settings</p>
]]></description><link>https://forum.mango-os.com/post/18601</link><guid isPermaLink="true">https://forum.mango-os.com/post/18601</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 25 May 2018 14:38:51 GMT</pubDate></item><item><title><![CDATA[Reply to Point Values on Fri, 25 May 2018 14:21:47 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/leoboeng" aria-label="Profile: leoboeng">@<bdi>leoboeng</bdi></a> said in <a href="/post/18598">Point Values</a>:</p>
<p dir="auto">Are you trying to view these points on a chart? That's the only time I've seen this message come up.</p>
<p dir="auto">I do not think you are limited on the number of point values you can store (though that possibly varies based on your license?) , but you are limited on the number you can show on a chart at any given time.</p>
]]></description><link>https://forum.mango-os.com/post/18600</link><guid isPermaLink="true">https://forum.mango-os.com/post/18600</guid><dc:creator><![CDATA[rshah]]></dc:creator><pubDate>Fri, 25 May 2018 14:21:47 GMT</pubDate></item></channel></rss>
