<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Home Automation Devices]]></title><description><![CDATA[<p dir="auto">Hi,<br />
Though I would post some of the devices which I am using:<br />
Velman K8061  - Inputs and Outputs (Over 32)<br />
VK011: Serial Temperature Sensor Interface</p>
<p dir="auto">If you have these devices and would like software to connect to Mango, just let me know.</p>
]]></description><link>https://forum.mango-os.com/topic/35/home-automation-devices</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 11:11:39 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/35.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 22 Aug 2007 02:17:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Home Automation Devices on Fri, 19 Dec 2014 05:56:41 GMT]]></title><description><![CDATA[<p dir="auto">xx</p>
]]></description><link>https://forum.mango-os.com/post/9601</link><guid isPermaLink="true">https://forum.mango-os.com/post/9601</guid><dc:creator><![CDATA[Balistar]]></dc:creator><pubDate>Fri, 19 Dec 2014 05:56:41 GMT</pubDate></item><item><title><![CDATA[Reply to Home Automation Devices on Wed, 05 Nov 2014 11:55:56 GMT]]></title><description><![CDATA[<p dir="auto">Can you be more specific? Maybe someone else will have the same issue...</p>
]]></description><link>https://forum.mango-os.com/post/9459</link><guid isPermaLink="true">https://forum.mango-os.com/post/9459</guid><dc:creator><![CDATA[Sxandy]]></dc:creator><pubDate>Wed, 05 Nov 2014 11:55:56 GMT</pubDate></item><item><title><![CDATA[Reply to Home Automation Devices on Sat, 06 Oct 2007 00:15:16 GMT]]></title><description><![CDATA[<p dir="auto">Sorry about the domain issues, they should be repaired now. I have a service which installs that monitors the values comming from the temp board. The values are then populated to a database. I then use mango to view the data from the database. I am not sure this is the best way to do this; however, it works great for me :)</p>
<p dir="auto">I would be glad to try to help you if you belive this is the way you want to go.</p>
]]></description><link>https://forum.mango-os.com/post/1979</link><guid isPermaLink="true">https://forum.mango-os.com/post/1979</guid><dc:creator><![CDATA[mjbcomputers]]></dc:creator><pubDate>Sat, 06 Oct 2007 00:15:16 GMT</pubDate></item><item><title><![CDATA[Reply to Home Automation Devices on Sun, 23 Sep 2007 01:52:40 GMT]]></title><description><![CDATA[<p dir="auto">Hello Roger,</p>
<p dir="auto">I can't speak too confidently for Matt, but since there appears to be a problem with his domain i'll tell you what i know.</p>
<p dir="auto">Matt used some functionality with the VK011 to connect it to a SQL database, and then used Mango to read and update values on the same database. I don't know if there is a more direct route between the VK011 and Mango (such as using Modbus or something), but if not, the database that he used was MySQL, which is a free download, and for Fedora is available from the "add software" interface or using yum.</p>
]]></description><link>https://forum.mango-os.com/post/1954</link><guid isPermaLink="true">https://forum.mango-os.com/post/1954</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Sun, 23 Sep 2007 01:52:40 GMT</pubDate></item><item><title><![CDATA[Reply to Home Automation Devices on Sun, 23 Sep 2007 00:29:05 GMT]]></title><description><![CDATA[<p dir="auto">How are you going about using the VK011 to connect to Mango. I Have a hot tub that I need to monitor the temp on for comfort and anti-freezing issues. I am about to buy this VK011 and setup on my Linux fedora HAS computer.</p>
]]></description><link>https://forum.mango-os.com/post/1953</link><guid isPermaLink="true">https://forum.mango-os.com/post/1953</guid><dc:creator><![CDATA[Roger]]></dc:creator><pubDate>Sun, 23 Sep 2007 00:29:05 GMT</pubDate></item></channel></rss>
