<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Nibe Fighter 1130 with RCU 11]]></title><description><![CDATA[<p dir="auto">Hi!</p>
<p dir="auto">I have just baught myself a ground heater with an attached RCU 11. I'm a total novice on modbus TCP to make that clear.</p>
<p dir="auto">What I am looking for is a simple way to pick up values from the heater. In my knowledge they should be in holding registers. (Accordning to <a href="http://www.nibe.se/Pages/42625/RCU_Parameterlista_F1135_1235.pdf" rel="nofollow ugc">http://www.nibe.se/Pages/42625/RCU_Parameterlista_F1135_1235.pdf</a> (In swedish, but in tables)</p>
<p dir="auto">I have tried to configured mango, but when i enable the modbus IP in databases I get the following errors..</p>
<blockquote></blockquote>
<p dir="auto">ERROR 2010-03-29 21:36:33,593 (org.quartz.core.JobRunShell.run:211) - Job com.serotonin.mango.rt.dataSource.PollingDataSource.PollingDataSource-1 threw an unhan<br />
dled Exception:<br />
java.lang.AbstractMethodError: com.serotonin.modbus4j.ip.IpMessageRequest.expectsResponse()Z<br />
at com.serotonin.io.messaging.SenderConnection.send(SenderConnection.jav<br />
a:76)<br />
a:106)<br />
at com.serotonin.modbus4j.ip.tcp.TcpMaster.send(TcpMaster.java:76)<br />
at com.serotonin.modbus4j.ModbusMaster.sendFunctionGroup(ModbusMaster.ja<br />
va:329)<br />
at com.serotonin.modbus4j.ModbusMaster.send(ModbusMaster.java:272)<br />
at com.serotonin.mango.rt.dataSource.modbus.ModbusDataSource.doPoll(Modb<br />
usDataSource.java:83)<br />
at com.serotonin.mango.rt.dataSource.PollingDataSource.scheduleTimeout(P<br />
ollingDataSource.java:79)<br />
at com.serotonin.mango.util.TimeoutJob.execute(TimeoutJob.java:48)<br />
at org.quartz.core.JobRunShell.run(JobRunShell.java:202)<br />
at org.quartz.simpl.SimpleThreadPool$WorkerThread.run(SimpleThreadPool.j<br />
ava:525)</p>
<p dir="auto">My configuration is<br />
Transport type: TCP<br />
Host: (Entered the IP adress)<br />
Port: 502</p>
<p dir="auto">I added one point.<br />
Slave ID: 1<br />
Register range: Holdning register<br />
Modbus data type: 2 byte signed integer<br />
Offset: 2 (Wich should be "Produktkod" or "Varmvattentemperatur (mantelgivare)" accourdning to Nibe<br />
Settable: unchecked<br />
Additive: 0</p>
<p dir="auto">I guess it is something very obvious.<br />
I have tried to make contact with another application that is using modbus and I get some results, so there is no network problem.</p>
<p dir="auto">Regards: Jon - Sweden</p>
]]></description><link>https://forum.mango-os.com/topic/347/nibe-fighter-1130-with-rcu-11</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 17:45:36 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/347.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 29 Mar 2010 20:05:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Wed, 31 Mar 2010 02:12:13 GMT]]></title><description><![CDATA[<p dir="auto">I don't know what to say. I've tried the 1.8.1 download on Windows and Mac using the available download and install instructions, and accessing a Modbus TCP slave, and it works perfectly. If this continues to be a problem for you i can only suggest you wait for the 1.8.2 release, forthcoming once some details with a collaborator are worked out, hopefully in a matter of weeks.</p>
]]></description><link>https://forum.mango-os.com/post/3541</link><guid isPermaLink="true">https://forum.mango-os.com/post/3541</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Wed, 31 Mar 2010 02:12:13 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Tue, 30 Mar 2010 20:59:21 GMT]]></title><description><![CDATA[<p dir="auto">However, I can scan for nodes. When I do a scan I get a result from 1 to 240...</p>
]]></description><link>https://forum.mango-os.com/post/3539</link><guid isPermaLink="true">https://forum.mango-os.com/post/3539</guid><dc:creator><![CDATA[bamsejon]]></dc:creator><pubDate>Tue, 30 Mar 2010 20:59:21 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Tue, 30 Mar 2010 20:44:50 GMT]]></title><description><![CDATA[<p dir="auto">Just tried a complete reinstallation.<br />
Deleted the whole tomcat directory (First copying the files that where posted here)<br />
Extracted tomcat to c:<br />
Extracted mango to C:\tomcat\webapps\ROOT<br />
Started tomcat with c:\tomcat\bin\startup<br />
logged in with admin<br />
added a datasource (Modbus IP)<br />
Added a point (Holding register)<br />
Enabled the datasource and did got the error as explained earlier...</p>
]]></description><link>https://forum.mango-os.com/post/3538</link><guid isPermaLink="true">https://forum.mango-os.com/post/3538</guid><dc:creator><![CDATA[bamsejon]]></dc:creator><pubDate>Tue, 30 Mar 2010 20:44:50 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Tue, 30 Mar 2010 20:17:55 GMT]]></title><description><![CDATA[<p dir="auto">Can you try removing your installation (just delete the mango web app dir) and try reinstalling?</p>
]]></description><link>https://forum.mango-os.com/post/3536</link><guid isPermaLink="true">https://forum.mango-os.com/post/3536</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 30 Mar 2010 20:17:55 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Tue, 30 Mar 2010 20:14:05 GMT]]></title><description><![CDATA[<p dir="auto">I recently downloaded it, installed java and apache tomcat accordning to the installation instruction.<br />
OS: Windows SR 2003 STD 32bit</p>
]]></description><link>https://forum.mango-os.com/post/3534</link><guid isPermaLink="true">https://forum.mango-os.com/post/3534</guid><dc:creator><![CDATA[bamsejon]]></dc:creator><pubDate>Tue, 30 Mar 2010 20:14:05 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Tue, 30 Mar 2010 03:38:54 GMT]]></title><description><![CDATA[<p dir="auto">Hmm. Did you use 1.8.1 out of the box, so to speak, or did you update anything about it? The thing is, i can't reproduce the problem with the version that is on the download page right now.</p>
]]></description><link>https://forum.mango-os.com/post/3524</link><guid isPermaLink="true">https://forum.mango-os.com/post/3524</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Tue, 30 Mar 2010 03:38:54 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Mon, 29 Mar 2010 21:06:26 GMT]]></title><description><![CDATA[<p dir="auto">about modbus4j, yes, the old one is overwritten.<br />
Placed it in C:\tomcat\webapps\ROOT\WEB-INF\lib</p>
]]></description><link>https://forum.mango-os.com/post/3523</link><guid isPermaLink="true">https://forum.mango-os.com/post/3523</guid><dc:creator><![CDATA[bamsejon]]></dc:creator><pubDate>Mon, 29 Mar 2010 21:06:26 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Mon, 29 Mar 2010 21:04:32 GMT]]></title><description><![CDATA[<p dir="auto">According to system information. 1.8.1</p>
]]></description><link>https://forum.mango-os.com/post/3522</link><guid isPermaLink="true">https://forum.mango-os.com/post/3522</guid><dc:creator><![CDATA[bamsejon]]></dc:creator><pubDate>Mon, 29 Mar 2010 21:04:32 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Mon, 29 Mar 2010 21:02:35 GMT]]></title><description><![CDATA[<p dir="auto">You left the updated modbus4J.jar in there, right? The old one got overwritten?</p>
]]></description><link>https://forum.mango-os.com/post/3521</link><guid isPermaLink="true">https://forum.mango-os.com/post/3521</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 29 Mar 2010 21:02:35 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Mon, 29 Mar 2010 21:01:09 GMT]]></title><description><![CDATA[<p dir="auto">Hmm, what version of Mango do you have?</p>
]]></description><link>https://forum.mango-os.com/post/3520</link><guid isPermaLink="true">https://forum.mango-os.com/post/3520</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 29 Mar 2010 21:01:09 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Mon, 29 Mar 2010 20:57:19 GMT]]></title><description><![CDATA[<p dir="auto">Nope.. Got the following error when I try to enable it...(Restarted tomcat after updating the file)</p>
<p dir="auto">ERROR 2010-03-29 22:55:02,625 (com.serotonin.mango.web.filter.ExceptionDetection<br />
Filter.doFilter:38) - DWR invocation exception<br />
java.lang.NoSuchMethodError: com.serotonin.modbus4j.ModbusMaster.setExceptionLis<br />
tener(Lcom/serotonin/io/messaging/MessagingConnectionListener;)V<br />
at com.serotonin.mango.rt.dataSource.modbus.ModbusDataSource.initialize(<br />
ModbusDataSource.java:134)<br />
at com.serotonin.mango.rt.dataSource.modbus.ModbusIpDataSource.initializ<br />
e(ModbusIpDataSource.java:53)<br />
at com.serotonin.mango.rt.RuntimeManager.initializeDataSource(RuntimeMan<br />
ager.java:257)<br />
at com.serotonin.mango.rt.RuntimeManager.saveDataSource(RuntimeManager.j<br />
ava:242)<br />
at com.serotonin.mango.web.dwr.DataSourceListDwr.toggleDataSource(DataSo<br />
urceListDwr.java:66)<br />
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)<br />
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.<br />
java:39)<br />
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces<br />
sorImpl.java:25)<br />
at java.lang.reflect.Method.invoke(Method.java:597)<br />
at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilt<br />
er.java:34)<br />
at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.j<br />
ava:428)<br />
at com.serotonin.mango.web.dwr.util.LoggedInAjaxFilter.doFilter(LoggedIn<br />
AjaxFilter.java:39)<br />
ava:428)<br />
at com.serotonin.web.dwr.LocalizationFilter.doFilter(LocalizationFilter.<br />
java:54)<br />
ava:428)<br />
at com.serotonin.mango.web.filter.ExceptionDetectionFilter.doFilter(Exce<br />
ptionDetectionFilter.java:26)<br />
ava:428)<br />
at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java<br />
:431)<br />
:283)<br />
at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandle<br />
r.java:52)<br />
at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:1<br />
01)<br />
at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146)<br />
at javax.servlet.http.HttpServlet.service(HttpServlet.java:637)<br />
at javax.servlet.http.HttpServlet.service(HttpServlet.java:717)<br />
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(Appl<br />
icationFilterChain.java:290)<br />
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationF<br />
ilterChain.java:206)<br />
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperV<br />
alve.java:233)<br />
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextV<br />
alve.java:191)<br />
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.j<br />
ava:128)<br />
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.j<br />
ava:102)<br />
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineVal<br />
ve.java:109)<br />
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.jav<br />
a:293)<br />
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java<br />
:849)<br />
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.proce<br />
ss(Http11Protocol.java:583)<br />
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:45<br />
4)<br />
at java.lang.Thread.run(Thread.java:619)<br />
WARN  2010-03-29 22:55:02,656 (org.directwebremoting.util.CommonsLoggingOutput.w<br />
arn:67) - Method execution failed:<br />
ava:242)<br />
java:39)<br />
er.java:34)<br />
ava:428)<br />
ava:428)<br />
java:54)<br />
ava:428)<br />
ava:428)<br />
:431)<br />
:283)<br />
r.java:52)<br />
01)<br />
ava:128)<br />
ava:102)<br />
ve.java:109)<br />
a:293)<br />
:849)<br />
4)<br />
WARN  2010-03-29 22:55:02,671 (org.directwebremoting.util.CommonsLoggingOutput.w<br />
arn:59) - --Erroring: batchId[3] message[java.lang.NoSuchMethodError: com.seroto<br />
nin.modbus4j.ModbusMaster.setExceptionListener(Lcom/serotonin/io/messaging/Messa<br />
gingConnectionListener;)V]</p>
<p dir="auto">Regards /Jon</p>
]]></description><link>https://forum.mango-os.com/post/3519</link><guid isPermaLink="true">https://forum.mango-os.com/post/3519</guid><dc:creator><![CDATA[bamsejon]]></dc:creator><pubDate>Mon, 29 Mar 2010 20:57:19 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Mon, 29 Mar 2010 20:49:53 GMT]]></title><description><![CDATA[<p dir="auto">K, try updating this too...</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/13.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/3518</link><guid isPermaLink="true">https://forum.mango-os.com/post/3518</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 29 Mar 2010 20:49:53 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Mon, 29 Mar 2010 20:47:41 GMT]]></title><description><![CDATA[<p dir="auto">Thank yo very much for a quick response.</p>
<p dir="auto">However, after updating the file and trying to enable the the config, I got the following error...</p>
<p dir="auto">ERROR 2010-03-29 22:45:14,000 (com.serotonin.mango.web.filter.ExceptionDetection<br />
java.lang.NoClassDefFoundError: com/serotonin/messaging/MessagingExceptionHandle<br />
r<br />
at com.serotonin.modbus4j.ModbusFactory.createTcpMaster(ModbusFactory.ja<br />
va:29)<br />
e(ModbusIpDataSource.java:50)<br />
ava:242)<br />
at com.serotonin.mango.web.dwr.DataSourceEditDwr.toggleEditDataSource(Da<br />
taSourceEditDwr.java:244)<br />
java:39)<br />
er.java:34)<br />
ava:428)<br />
ava:428)<br />
java:54)<br />
ava:428)<br />
ava:428)<br />
:431)<br />
:283)<br />
r.java:52)<br />
01)<br />
ava:128)<br />
ava:102)<br />
ve.java:109)<br />
a:293)<br />
:849)<br />
4)<br />
Caused by: java.lang.ClassNotFoundException: com.serotonin.messaging.MessagingEx<br />
ceptionHandler<br />
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoa<br />
der.java:1387)<br />
der.java:1233)<br />
... 37 more<br />
WARN  2010-03-29 22:45:14,015 (org.directwebremoting.util.CommonsLoggingOutput.w<br />
r<br />
va:29)<br />
ava:242)<br />
java:39)<br />
er.java:34)<br />
ava:428)<br />
ava:428)<br />
java:54)<br />
ava:428)<br />
ava:428)<br />
:431)<br />
:283)<br />
r.java:52)<br />
01)<br />
ava:128)<br />
ava:102)<br />
ve.java:109)<br />
a:293)<br />
:849)<br />
4)<br />
... 37 more<br />
WARN  2010-03-29 22:45:14,031 (org.directwebremoting.util.CommonsLoggingOutput.w<br />
arn:59) - --Erroring: batchId[6] message[java.lang.NoClassDefFoundError: com/ser<br />
otonin/messaging/MessagingExceptionHandler]</p>
]]></description><link>https://forum.mango-os.com/post/3517</link><guid isPermaLink="true">https://forum.mango-os.com/post/3517</guid><dc:creator><![CDATA[bamsejon]]></dc:creator><pubDate>Mon, 29 Mar 2010 20:47:41 GMT</pubDate></item><item><title><![CDATA[Reply to Nibe Fighter 1130 with RCU 11 on Mon, 29 Mar 2010 20:15:21 GMT]]></title><description><![CDATA[<p dir="auto">That error doesn't in fact have anything to do with Modbus, at least regarding connectivity. There appears to be a problem with the Modbus implementation version that you have. Try replacing WEB-INF/lib/modbus4j.jar with the attached version, restart, and see if that helps.</p>
<p dir="auto">Attachment: <a href="http://archive.infiniteautomation.com/forum/posts/downloadAttach/12.page" rel="nofollow ugc">download link</a></p>
]]></description><link>https://forum.mango-os.com/post/3516</link><guid isPermaLink="true">https://forum.mango-os.com/post/3516</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 29 Mar 2010 20:15:21 GMT</pubDate></item></channel></rss>
