<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Version 3.4.0 released!]]></title><description><![CDATA[<p dir="auto"><strong>core</strong> - Version 3.4.0</p>
<ul>
<li>Prevent NPEs that had been thrown in several json imports, particularly event detectors and handlers</li>
<li>Increase the XID field to 100 characters from 50</li>
<li>Adding new module definitions for custom queries to be used as helpers in REST query endpoints</li>
<li>Adding definition for Events by Data Point Tag query at /v1/events/module-defined-query/DATA_POINT_EVENTS_BY_TAG</li>
<li>Adding simplify settings as a property of data point VO</li>
<li>Removing get(object) and get(DataValue) from StartsAndRuntimeList javascript wrapper so these methods are no longer available and should never have been used</li>
<li>Raising Audit events as low priority work items to avoid database deadlock when raising events in a transaction.</li>
<li>Change locking for adding points to enable polling data sources to easily add points to themselves without a deadlock risk</li>
<li>Add new log4j configuration file to optionally use with high performance logging extension</li>
<li>Cache access to the System Locale to improve performance</li>
<li>Further improvements to Ordered Thread Pool Executors to ensure tasks are not orphaned and unable to run in high load systems</li>
<li>Use Mango’s locale to render and parse values.</li>
<li>Fix AnalogChangeEventDetector to properly configure its context for use in Emails</li>
<li>Improved System Settings validation when saving via REST</li>
<li>JSON Import for anything with an enabled property will only modify the value if the enabled property is in the JSON</li>
<li>JSON Emport, default to only export name not alias, alias is still supported for import on objects that previously had that property</li>
<li>Don’t update thread pool sizes if the settings are saved but not changed for peformance</li>
<li>Fix where a latest(limit) query for point values could have returned a list with a null value if there was no data</li>
<li>Ensure all data point listeners execute their tasks before returning a failure</li>
<li>Adding statistics generator for the NONE type rollup that will return unprocessed values</li>
<li>Adding the ability to define custom permissions for Event Types, to be expanded on in future releases</li>
<li>Improve authentication for websockets, basic authentication now supported, websockets are closed immediately when user logs out/tokens revoked/password changed etc</li>
<li>Update Spring, Spring Security, Jetty, jOOQ and Bouncy Castle dependencies</li>
<li>Fix bug when copying a data source the supplied Device Name was not applied to the copied points</li>
<li>Fix script context points toString for settable property</li>
<li>removing DataPointVO.settable property, use DataPointVO.pointLocatorVO.settable</li>
<li>Fix color in range renderers with rendered units. Add unit to range renderer output string if not in a defined range</li>
<li>Fix script DataPointWrapper to load tags if null in .getDataPointWrapper().getTags()</li>
</ul>
<p dir="auto"><strong>advancedComponents</strong> - Version 3.4.0</p>
<ul>
<li>Upgraded to work with core version 3.4.x</li>
</ul>
<p dir="auto"><strong>advancedScheduler</strong> - Version 3.4.0</p>
<ul>
<li>Changes to allow events to be viewed by anyone with Schedule read permission</li>
</ul>
<p dir="auto"><strong>asciiFile</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>BACnet</strong> - Version 3.4.0</p>
<ul>
<li>Setting reliability attribute for points</li>
<li>Upgrade BACnet4J to 4.1.5</li>
<li>Adding API support for PriorityValue, DateTime, and AmbiguousValue</li>
</ul>
<p dir="auto"><strong>brewersdashboard</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>controlcore</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>dashboardDesigner</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>dataFile</strong> - Version 3.4.0</p>
<ul>
<li>Added public char getSeparatorCharacter, getQuoteCharacter, and getEscapeCharacter methods to AbstractCSVDataSource, same defaults</li>
</ul>
<p dir="auto"><strong>dataImport</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>dataPointDetailsView</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>deviceConfig</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>dnp3</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>egauge</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>envcands</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>excelReports</strong> - Version 3.4.0</p>
<ul>
<li>Expanding end time of report to end of rollup period if using rollups</li>
</ul>
<p dir="auto"><strong>galil</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>graphicalViews</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>Haystack</strong> - Version 3.4.0</p>
<ul>
<li>Initial forcePointRead support</li>
<li>More unreliability conditions flagged for points</li>
</ul>
<p dir="auto"><strong>http</strong> - Version 3.4.0</p>
<ul>
<li>Fixed JSON export to include superclass information in HTTP receivers</li>
</ul>
<p dir="auto"><strong>internal</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>jmxds</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>jsonFileImport</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>log4jDS</strong> - Version 3.4.0</p>
<ul>
<li>Fix for potential null pointer exception when log messages had an empty message, they are now ignored</li>
</ul>
<p dir="auto"><strong>log4JReset</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>loggingConsole</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>maintenanceEvents</strong> - Version 3.4.0</p>
<ul>
<li>Change events to be viewable by anyone with edit permission to the data source for the event</li>
</ul>
<p dir="auto"><strong>mangoApi</strong> - Version 3.4.0</p>
<ul>
<li>Adding download option to /v1/modules/update-license-payload</li>
<li>Adding /v1//upload-upgrades to POST zip file with Mango upgrades (download Upgrade Bundle from store)</li>
<li>Adding /v1/events/module-defined-query/{query type} to expose custom queries defined by modules</li>
<li>Adding /v1/events/explain-module-defined-queries to explain all defined queries</li>
<li>Fixing /v1/logging/by-filename/{filename} Query to match new log file format</li>
<li>Adding StartsAndRuntime data to All Rollup for Multistate points</li>
<li>Adding ability to use DEFAULT rollups on /v2/point-values rollup endpoints even when the default rollup is NONE</li>
<li>Optionally supply a device name to apply to data points when copying a data source on /v1/data-sources/copy/{xid}</li>
</ul>
<p dir="auto"><strong>mangoESConfiguration</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>mangoNoSqlDatabase</strong> - Version 3.4.0</p>
<ul>
<li>Don’t allow migrating from an H2 database that doesn’t exist</li>
<li>Fix bug where purging a point with no data at all would endlessly loop</li>
</ul>
<p dir="auto"><strong>mangoUI</strong> - Version 3.4.0</p>
<ul>
<li>Use webpack v4 to combine frontend code into bundles, faster more reliable loading</li>
<li>Remove admin template and other templates, remove references from documentation</li>
<li>Add system settings for public url, failed loging alarm level</li>
<li>Use module version for cache control query parameter</li>
<li>Add offline upgrade page</li>
<li>Allow dropping files in file store pages in order to upload</li>
<li>Add unreliable icon to ma-point-value component</li>
<li>Display tags on data point details page and on point drop down lists</li>
<li>Always use equal spacing in ma-serial-chart if all graphs are bar charts</li>
<li>Bug fixes</li>
</ul>
<p dir="auto"><strong>mbus</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>measurlogicDTSCell</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>meta</strong> - Version 3.4.0</p>
<ul>
<li>Adding REST endpoint at /v2/meta-utils/generate/{xids} to generate history for multiple points</li>
<li>Adding REST endpoint at /v2/meta-utils/generate-data-source/{xid} to generate history for all points on a data source</li>
</ul>
<p dir="auto"><strong>modbus</strong> - Version 3.4.0</p>
<ul>
<li>Fixed bug in v2 endpoints that would fail to authorize any users</li>
<li>Fixed bug in Point Locator model that wouldn’t allow creating points with an offset via REST</li>
</ul>
<p dir="auto"><strong>mqttClientDataSource</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>onewire</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>opcda</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>openv4j</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>pachube</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>pakbus</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>persistent</strong> - Version 3.4.0</p>
<ul>
<li>Transmit points, rollups, chart settings, and permissions to received points</li>
<li>Add tags to all points being sent from a publisher, or all points received by a receiver</li>
<li>Add port into connection description</li>
<li>Optionally override data point permission fields at the publisher or the data source</li>
<li>Tags added to receiver points persist if not conflicting trasmitted tags</li>
</ul>
<p dir="auto"><strong>pid</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>pointLinks</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>pop3</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>reports</strong> - Version 3.4.0</p>
<ul>
<li>Added web/user-ftl folder to allow persisting ftl templates across module upgrades, place your user defined report templates there</li>
</ul>
<p dir="auto"><strong>scheduledEvents</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>scripting</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>serial</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>snmp</strong> - Version 3.4.0</p>
<ul>
<li>Add unreliability status into data points</li>
</ul>
<p dir="auto"><strong>sqlConsole</strong> - Version 3.4.0</p>
<ul>
<li>Fixed bug with commas inside string values</li>
</ul>
<p dir="auto"><strong>sqlds</strong> - Version 3.4.0</p>
<ul>
<li>Use single quote to parse strings to allow for use of comma when inserting/updating String values</li>
</ul>
<p dir="auto"><strong>ssh</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>sstGlobalScripts</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>sstGraphics</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>sstTheme</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>TCPIP</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>templateConfig</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>twilio</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>virtualDS</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>vmstat</strong> - Version 3.4.0</p>
<ul>
</ul>
<p dir="auto"><strong>watchlists</strong> - Version 3.4.0</p>
<ul>
<li>Adding custom REST query to get all data point events by watchlist XID at /v1/events/module-defined-query/DATA_POINT_EVENTS_BY_WATCHLIST</li>
</ul>
<p dir="auto"><strong>zwave</strong> - Version 3.4.0</p>
<ul>
</ul>
]]></description><link>https://forum.mango-os.com/topic/3457/version-3-4-0-released</link><generator>RSS for Node</generator><lastBuildDate>Tue, 17 Nov 2026 17:20:58 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3457.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 01 May 2018 18:02:19 GMT</pubDate><ttl>60</ttl></channel></rss>
