<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Error Importing Modbus4J Library in Netbeans]]></title><description><![CDATA[<p dir="auto">Hi.<br />
I am trying  this library, I have funded the test code in the src/Test<br />
I have added the code to fresh NetBeans project and import the Modbus4J library from the right side library import panel.<br />
but still its showing error in the code.<br />
I tried with alt+enter but it's not showing to import option.</p>
<pre><code>package modbustestlibrery;
 * @author mdism
public class myModbus {
     * @param args the command line arguments
     ModbusFactory factory = new ModbusFactory();
     IpParameters params = new IpParameters();
     params.setHost("localhost");
     params.setPort(12345);
     ModbusMaster master = factory.createTcpMaster(params, true, false);
     // master.setRetries(4);
     master.setRetries(0);
     try {
     master.init();
     master.getValue(1, RegisterRange.HOLDING_REGISTER, 0, DataType.TWO_BYTE_INT_UNSIGNED);
     finally {
     master.destroy();
<pre><code>This is the error i am getting
Compiling 1 source file to D:\work\practice\Wifi\Java Test\ModbusTestLibrery\build\classes
D:\work\practice\Wifi\Java Test\ModbusTestLibrery\src\modbustestlibrery\myModbus.java:19: error: cannot find symbol
  symbol:   class ModbusFactory
D:\work\practice\Wifi\Java Test\ModbusTestLibrery\src\modbustestlibrery\myModbus.java:20: error: cannot find symbol
  symbol:   class IpParameters
D:\work\practice\Wifi\Java Test\ModbusTestLibrery\src\modbustestlibrery\myModbus.java:23: error: cannot find symbol
  symbol:   class ModbusMaster
D:\work\practice\Wifi\Java Test\ModbusTestLibrery\src\modbustestlibrery\myModbus.java:28: error: cannot find symbol
  symbol:   variable RegisterRange
  symbol:   variable DataType
7 errors
<p dir="auto"><img src="https://camo.nodebb.org/255b406ced3459d7b52d60e58f6f77d238a29eb1?url=https%3A%2F%2Fi.imgur.com%2FnkUIWm2.png" alt="1_1524135873781_Error2.png" class=" img-fluid img-markdown" /> <img src="https://camo.nodebb.org/b174fcf1c0db703e779be5600b0121348e81bc32?url=https%3A%2F%2Fi.imgur.com%2FysKjJ2E.png" alt="0_1524135873775_Error1.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Please help.</p>
]]></description><link>https://forum.mango-os.com/topic/3430/error-importing-modbus4j-library-in-netbeans</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Apr 2026 22:38:54 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3430.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 19 Apr 2018 11:06:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Error Importing Modbus4J Library in Netbeans on Thu, 19 Apr 2018 20:25:01 GMT]]></title><description><![CDATA[<p dir="auto">Seems like a path issue. Is modbus4j on your classpath?</p>
]]></description><link>https://forum.mango-os.com/post/18092</link><guid isPermaLink="true">https://forum.mango-os.com/post/18092</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 19 Apr 2018 20:25:01 GMT</pubDate></item></channel></rss>
