<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[3.0.2 (3.0.1) update versioning problem]]></title><description><![CDATA[<p dir="auto">I have one of the early 3.0 ESs. The Core is 3.0.2 and all other modules are 3.0.1. I saw in a previous discussion that I should remove the Dashboard module (3.5) which I did. But I'm still getting a versioning problem error. Is there possibly another module which needs to be removed? I don't want to remove something that might brick it.</p>
]]></description><link>https://forum.mango-os.com/topic/3424/3-0-2-3-0-1-update-versioning-problem</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 23:42:00 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3424.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Apr 2018 20:07:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to 3.0.2 (3.0.1) update versioning problem on Tue, 17 Apr 2018 21:02:34 GMT]]></title><description><![CDATA[<p dir="auto">Yes, you could use the USB utility to move the whole update bundle zip into your /opt/mango directory if named as I suggested previously.</p>
<p dir="auto">It looks like your DNS resolved the correct IP, but you didn't (or couldn't) get a response. You could try <code>https://store.infiniteautomation.com</code> instead of http:// as your <code>store.url</code> in your env.properties file.</p>
]]></description><link>https://forum.mango-os.com/post/18066</link><guid isPermaLink="true">https://forum.mango-os.com/post/18066</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 17 Apr 2018 21:02:34 GMT</pubDate></item><item><title><![CDATA[Reply to 3.0.2 (3.0.1) update versioning problem on Tue, 17 Apr 2018 20:51:54 GMT]]></title><description><![CDATA[<p dir="auto">I cliked the send log to Infinite. Here is the applicable part:</p>
<p dir="auto">ERROR 2018-04-17T15:43:18,688 (com.serotonin.m2m2.web.dwr.ModulesDwr.versionCheck:149) - org.apache.http.conn.ConnectTimeoutException: Connect to <a href="http://store.infiniteautomation.com:80" rel="nofollow ugc">store.infiniteautomation.com:80</a> [<a href="http://store.infiniteautomation.com/35.161.166.188" rel="nofollow ugc">store.infiniteautomation.com/35.161.166.188</a>] failed: connect timed out at org.apache.http.impl.conn.HttpClientConnectionOperator.connect(HttpClientConnectionOperator.java:130) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.conn.PoolingHttpClientConnectionManager.connect(PoolingHttpClientConnectionManager.java:314) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.execchain.MainClientExec.establishRoute(MainClientExec.java:363) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.execchain.MainClientExec.execute(MainClientExec.java:219) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.execchain.ProtocolExec.execute(ProtocolExec.java:195) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.execchain.RetryExec.execute(RetryExec.java:85) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.execchain.RedirectExec.execute(RedirectExec.java:108) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.client.InternalHttpClient.doExecute(InternalHttpClient.java:186) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:82) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:106) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.client.CloseableHttpClient.execute(CloseableHttpClient.java:57) ~[httpclient-4.3.2.jar:4.3.2] at com.serotonin.web.http.HttpUtils4.executeWithRetries(HttpUtils4.java:174) ~[serotonin-utils-2.1.8.jar:?] at com.serotonin.web.http.HttpUtils4.getTextContent(HttpUtils4.java:132) ~[serotonin-utils-2.1.8.jar:?] at com.serotonin.m2m2.web.dwr.ModulesDwr.getAvailableUpgrades(ModulesDwr.java:347) ~[mango-3.0.2.jar:?] at com.serotonin.m2m2.web.dwr.ModulesDwr.versionCheck(ModulesDwr.java:127) [mango-3.0.2.jar:?] at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:1.8.0_131] at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62) ~[?:1.8.0_131] at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_131] at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_131] at org.directwebremoting.impl.ExecuteAjaxFilter.doFilter(ExecuteAjaxFilter.java:34) [dwr-2.0.11.jar:?] at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428) [dwr-2.0.11.jar:?] at com.serotonin.m2m2.web.dwr.util.TranslationsFilter.doFilter(TranslationsFilter.java:37) [mango-3.0.2.jar:?] at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428) [dwr-2.0.11.jar:?] at com.serotonin.m2m2.web.dwr.util.ExceptionDetectionFilter.doFilter(ExceptionDetectionFilter.java:26) [mango-3.0.2.jar:?] at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428) [dwr-2.0.11.jar:?] at com.serotonin.m2m2.web.dwr.util.DwrPermissionFilter.doFilter(DwrPermissionFilter.java:45) [mango-3.0.2.jar:?] at org.directwebremoting.impl.DefaultRemoter$1.doFilter(DefaultRemoter.java:428) [dwr-2.0.11.jar:?] at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:431) [dwr-2.0.11.jar:?] at org.directwebremoting.impl.DefaultRemoter.execute(DefaultRemoter.java:283) [dwr-2.0.11.jar:?] at org.directwebremoting.servlet.PlainCallHandler.handle(PlainCallHandler.java:52) [dwr-2.0.11.jar:?] at org.directwebremoting.servlet.UrlProcessor.handle(UrlProcessor.java:101) [dwr-2.0.11.jar:?] at org.directwebremoting.servlet.DwrServlet.doPost(DwrServlet.java:146) [dwr-2.0.11.jar:?] at javax.servlet.http.HttpServlet.service(HttpServlet.java:707) [javax.servlet-api-3.1.0.jar:3.1.0] at javax.servlet.http.HttpServlet.service(HttpServlet.java:790) [javax.servlet-api-3.1.0.jar:3.1.0] at org.eclipse.jetty.servlet.ServletHolder.handle(ServletHolder.java:845) [jetty-servlet-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1689) [jetty-servlet-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.servlets.GzipFilter.doFilter(GzipFilter.java:51) [jetty-servlets-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1676) [jetty-servlet-9.3.11.v20160721.jar:9.3.11.v20160721] at org.springframework.web.filter.ShallowEtagHeaderFilter.doFilterInternal(ShallowEtagHeaderFilter.java:110) [spring-web-4.3.7.RELEASE.jar:4.3.7.RELEASE] at com.serotonin.m2m2.web.filter.MangoShallowEtagHeaderFilter.doFilterInternal(MangoShallowEtagHeaderFilter.java:47) [mango-3.0.2.jar:?] at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) [spring-web-4.3.7.RELEASE.jar:4.3.7.RELEASE] at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1676) [jetty-servlet-9.3.11.v20160721.jar:9.3.11.v20160721] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:317) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:127) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.access.intercept.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:91) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at com.serotonin.m2m2.web.mvc.spring.security.PermissionExceptionFilter.doFilter(PermissionExceptionFilter.java:32) [mango-3.0.2.jar:?] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.access.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:115) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.session.SessionManagementFilter.doFilter(SessionManagementFilter.java:137) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.authentication.AnonymousAuthenticationFilter.doFilter(AnonymousAuthenticationFilter.java:111) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.servletapi.SecurityContextHolderAwareRequestFilter.doFilter(SecurityContextHolderAwareRequestFilter.java:169) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.savedrequest.RequestCacheAwareFilter.doFilter(RequestCacheAwareFilter.java:63) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.session.ConcurrentSessionFilter.doFilter(ConcurrentSessionFilter.java:134) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.authentication.AbstractAuthenticationProcessingFilter.doFilter(AbstractAuthenticationProcessingFilter.java:200) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.authentication.logout.LogoutFilter.doFilter(LogoutFilter.java:121) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.csrf.CsrfFilter.doFilterInternal(CsrfFilter.java:100) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) [spring-web-4.3.7.RELEASE.jar:4.3.7.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.header.HeaderWriterFilter.doFilterInternal(HeaderWriterFilter.java:66) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) [spring-web-4.3.7.RELEASE.jar:4.3.7.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.context.SecurityContextPersistenceFilter.doFilter(SecurityContextPersistenceFilter.java:105) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.context.request.async.WebAsyncManagerIntegrationFilter.doFilterInternal(WebAsyncManagerIntegrationFilter.java:56) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.web.filter.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:107) [spring-web-4.3.7.RELEASE.jar:4.3.7.RELEASE] at org.springframework.security.web.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:331) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy.doFilterInternal(FilterChainProxy.java:214) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.security.web.FilterChainProxy.doFilter(FilterChainProxy.java:177) [spring-security-web-4.1.1.RELEASE.jar:4.1.1.RELEASE] at org.springframework.web.filter.DelegatingFilterProxy.invokeDelegate(DelegatingFilterProxy.java:346) [spring-web-4.3.7.RELEASE.jar:4.3.7.RELEASE] at org.springframework.web.filter.DelegatingFilterProxy.doFilter(DelegatingFilterProxy.java:262) [spring-web-4.3.7.RELEASE.jar:4.3.7.RELEASE] at org.eclipse.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1668) [jetty-servlet-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.servlet.ServletHandler.doHandle(ServletHandler.java:581) [jetty-servlet-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:143) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.security.SecurityHandler.handle(SecurityHandler.java:548) [jetty-security-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.session.SessionHandler.doHandle(SessionHandler.java:226) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.handler.ContextHandler.doHandle(ContextHandler.java:1180) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.servlet.ServletHandler.doScope(ServletHandler.java:511) [jetty-servlet-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.session.SessionHandler.doScope(SessionHandler.java:185) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.handler.ContextHandler.doScope(ContextHandler.java:1112) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.handler.ScopedHandler.handle(ScopedHandler.java:141) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:213) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.handler.HandlerWrapper.handle(HandlerWrapper.java:134) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.Server.handle(Server.java:524) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.HttpChannel.handle(HttpChannel.java:319) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.server.HttpConnection.onFillable(HttpConnection.java:253) [jetty-server-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.io.AbstractConnection$ReadCallback.succeeded(AbstractConnection.java:273) [jetty-io-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.io.FillInterest.fillable(FillInterest.java:95) [jetty-io-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.io.SelectChannelEndPoint$2.run(SelectChannelEndPoint.java:93) [jetty-io-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.executeProduceConsume(ExecuteProduceConsume.java:303) [jetty-util-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.produceConsume(ExecuteProduceConsume.java:148) [jetty-util-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.util.thread.strategy.ExecuteProduceConsume.run(ExecuteProduceConsume.java:136) [jetty-util-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.util.thread.QueuedThreadPool.runJob(QueuedThreadPool.java:671) [jetty-util-9.3.11.v20160721.jar:9.3.11.v20160721] at org.eclipse.jetty.util.thread.QueuedThreadPool$2.run(QueuedThreadPool.java:589) [jetty-util-9.3.11.v20160721.jar:9.3.11.v20160721] at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131] Caused by: java.net.SocketTimeoutException: connect timed out at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:1.8.0_131] at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:1.8.0_131] at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:1.8.0_131] at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:1.8.0_131] at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:1.8.0_131] at java.net.Socket.connect(Socket.java:589) ~[?:1.8.0_131] at org.apache.http.conn.socket.PlainConnectionSocketFactory.connectSocket(PlainConnectionSocketFactory.java:72) ~[httpclient-4.3.2.jar:4.3.2] at org.apache.http.impl.conn.HttpClientConnectionOperator.connect(HttpClientConnectionOperator.java:118) ~[httpclient-4.3.2.jar:4.3.2] ... 102 more</p>
<p dir="auto">This is on a corporate lan. There are some things that are blocked. I would have to be local I think to use Webmin.</p>
<p dir="auto">I'm assuming the best option is using the USB file copy script. I'm assuming it is possible to copy the entire core Jar this way?</p>
]]></description><link>https://forum.mango-os.com/post/18065</link><guid isPermaLink="true">https://forum.mango-os.com/post/18065</guid><dc:creator><![CDATA[sstuhlmann]]></dc:creator><pubDate>Tue, 17 Apr 2018 20:51:54 GMT</pubDate></item><item><title><![CDATA[Reply to 3.0.2 (3.0.1) update versioning problem on Tue, 17 Apr 2018 20:16:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi sstuhlmann,</p>
<p dir="auto">It should be indicated in your Mango/logs/ma.log file what module caused the issue. You can also download the appropriate bundle from <a href="https://store.infiniteautomation.com/core" rel="nofollow ugc">https://store.infiniteautomation.com/core</a> (probably enterprise), and place it in your Mango/ directory with the name <code>m2m2-core-3.x.x.zip</code> and it'll perform the upgrade when you restart Mango.</p>
]]></description><link>https://forum.mango-os.com/post/18058</link><guid isPermaLink="true">https://forum.mango-os.com/post/18058</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 17 Apr 2018 20:16:53 GMT</pubDate></item></channel></rss>
