<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Retrieve last 12 hours of data]]></title><description><![CDATA[<p dir="auto">Hi All,</p>
<p dir="auto">Does anyone catch anything wrong with the following? It works without the maNow / maMoment stuff using DatePicker but I'd like to use the moment / maNow</p>
<pre><code> &lt;!-- Get current time, output to "to" --&gt;
&lt;ma-now update-interval="1 minutes" output="to"&gt;&lt;/ma-now&gt;
 &lt;!-- Calculate last 12 hours from current time, output to "from" --&gt;
&lt;ma-calc input="to | maMoment:'subtract':12:'hours'" output="from"&gt;&lt;/ma-calc&gt;
 &lt;!-- Get last 12 hours worth of data, average it per minute --&gt;
&lt;ma-point-values point-xid="leaderCascadeCurrentPower" values="point1Values" from="from" to="to" rollup="AVERAGE" rollup-interval="1 minutes"&gt;
&lt;/ma-point-values&gt;
&lt;p&gt;There are {{point1Values.length}} rows to display.&lt;/p&gt;
]]></description><link>https://forum.mango-os.com/topic/3423/retrieve-last-12-hours-of-data</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 00:15:40 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3423.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 17 Apr 2018 20:03:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Mon, 23 Apr 2018 18:21:38 GMT]]></title><description><![CDATA[<p dir="auto">Thanks a lot!</p>
<p dir="auto">We will do that.</p>
]]></description><link>https://forum.mango-os.com/post/18135</link><guid isPermaLink="true">https://forum.mango-os.com/post/18135</guid><dc:creator><![CDATA[rshah]]></dc:creator><pubDate>Mon, 23 Apr 2018 18:21:38 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Mon, 23 Apr 2018 18:15:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rshah" aria-label="Profile: rshah">@<bdi>rshah</bdi></a> two things</p>
<p dir="auto">a) I would strongly suggest moving your page into a custom / dashboard designer page inside the UI module. I can tell you that the above page will break upon installation of Mango 3.4<br />
To make the page full screen / no menu and toolbar, see here - <a href="https://forum.infiniteautomation.com/topic/3297/deploying-custom-page/3" rel="nofollow ugc">https://forum.infiniteautomation.com/topic/3297/deploying-custom-page/3</a></p>
<p dir="auto">b) Don't get every point and its values individually. Use a watch list as I posted above. You can use multiple watch lists if you want multiple charts. This also lets you dynamically add/remove points from the watchlist and you wont have to change your page markup.</p>
]]></description><link>https://forum.mango-os.com/post/18133</link><guid isPermaLink="true">https://forum.mango-os.com/post/18133</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Mon, 23 Apr 2018 18:15:17 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Mon, 23 Apr 2018 17:37:29 GMT]]></title><description><![CDATA[<p dir="auto">Here is what we are doing now -- I am not very familiar with Angular, my experience is largely with React -- can you advise if this is a <em>bad</em> way to do this?</p>
<pre><code>&lt;!DOCTYPE html&gt;
&lt;html lang="en"&gt;
    &lt;head&gt;
        &lt;meta charset="utf-8"&gt;
        &lt;meta http-equiv="x-ua-compatible" content="ie=edge"&gt;
        &lt;title&gt;Boiler 2 Screen&lt;/title&gt;
        &lt;meta name="viewport" content="width=device-width, height=device-height, initial-scale=1"&gt;
        &lt;link rel="stylesheet" href="/modules/mangoUI/web/vendor/angular/angular-csp.css"&gt;&lt;/link&gt;
        &lt;link rel="stylesheet" href="/modules/mangoUI/web/vendor/angular-material/angular-material.css"&gt;
        &lt;link rel="stylesheet" href="/modules/mangoUI/web/vendor/material-design-icons/iconfont/material-icons.css"&gt;
        &lt;link rel="stylesheet" href="/modules/mangoUI/web/vendor/md-pickers/mdPickers.css"&gt;
    &lt;/head&gt;
    &lt;body layout="column"&gt;
        &lt;!-- We only want to obtain last 12 hours of data, so use Angular Moment Library to do figure out what last 12 hours are--&gt;
        &lt;!-- Obtain 12 hours of point values based on point XID, average them per minute  store them in an array (object) (param = values) --&gt;
        &lt;!-- Boiler DHW information --&gt;
        &lt;!-- Member 1 Information (DHW Mode only) --&gt;
        &lt;ma-point-values
            point-xid="member1DhwTankTemp"
            rendered="true"
            values="m1TankValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="DP_member1FiringRateDHW"
            rendered="true"
            values="m1FireDHWValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="member1OutletTemp"
            rendered="true"
            values="m1OutletTempValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;!-- Member 3 Information (DHW Mode only) --&gt;
        &lt;ma-point-values
            point-xid="member3DhwTankTemp"
            rendered="true"
            values="m3TankValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="DP_member3FiringRateDHW"
            rendered="true"
            values="m3FireDHWValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="member3OutletTemp"
            rendered="true"
            values="m3OutletTempValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;!-- DHW Flow Data --&gt;
        &lt;ma-point-values
            point-xid="DHWSupplyRate"
            rendered="true"
            values="dhwSupplyRateValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="DHW11ReturnRate"
            rendered="true"
            values="dhw11SupplyRateValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="DP_DhwConsumedRate"
            rendered="true"
            values="dhwConsumedRateValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="IoM322DHWBsmntReturnTemp"
            rendered="true"
            values="returnBasementTemperatureValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="IoM3DHWSupTemp"
            rendered="true"
            values="DHW22SupplyTemperatureValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="IoM322DHW11ReturnTemp"
            rendered="true"
            values="return11TemperatureValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;ma-point-values
            point-xid="DHWBsmntReturnRate"
            rendered="true"
            values="basementReturnRateValues"
            from="from"
            to="to"
            rollup="AVERAGE"
        &lt;!-- Displays only if the app is still loading --&gt;
        &lt;div ng-if="appLoading"&gt;
            &lt;span&gt;App is loading..&lt;/span&gt;
        &lt;/div&gt;
        &lt;!-- Actual content of page once loaded --&gt;
        &lt;div ng-cloak layout="column" flex&gt;
            &lt;h3 class="centerText"&gt;DHW Tanks and Boilers&lt;/h3&gt;
            &lt;div layout="row"&gt;
                &lt;md-card flex="75"&gt;
                    &lt;md-card-content layout="column"&gt;
                        &lt;ma-serial-chart
                        style="height: 490px; width: 100%"
                        series-1-values="m1FireDHWValues"
                        series-1-title="Member 1 DHW Firing Rate"
                        series-1-color="red"
                        series-1-axis="left"
                        series-1-type="smoothedLine"
                        series-2-values="m3FireDHWValues"
                        series-2-title="Member 3 DHW Firing Rate"
                        series-2-color="green"
                        series-2-axis="left"
                        series-2-type="smoothedLine"
                        series-3-values="m1TankValues"
                        series-3-title="Member 1 Tank Temp"
                        series-3-color="blue"
                        series-3-axis="right"
                        series-3-type="smoothedLine"
                        series-4-values="m3TankValues"
                        series-4-title="Member 3 Tank Temp"
                        series-4-color="yellow"
                        series-4-axis="right"
                        series-4-type="smoothedLine"
                        legend="true"
                        options="{
                            valueAxes:[
                                    axisColor:'white',
                                    color:'white',
                                    title: 'Firing Rate (%)',
                                    titleColor: 'white',
                                    fontSize:26,
                                    titleFontSize:26,
                                    minimum:0,
                                    maximum:100
                                    axisColor:'white',
                                    color:'white',
                                    title: 'Temperature (ºF)',
                                    fontSize:26,
                                    titleFontSize:26,
                                    minimum:0,
                                    maximum:180
                        }"&gt;
                        &lt;/ma-serial-chart&gt;
                    &lt;/md-card-content&gt;
                &lt;/md-card&gt;
                &lt;md-card flex="25"&gt;
                            &lt;md-card flex="50"&gt;
                                &lt;md-card-title&gt;
                                    &lt;md-card-title-text&gt;
                                        Member 1 Firing Rate (DHW)
                                    &lt;/md-card-title-text&gt;
                                &lt;/md-card-title&gt;
                                    &lt;h4 id="testing"&gt;{{m1FireDHWValues[m1FireDHWValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                                        Member 3 Firing Rate (DHW)
                                    &lt;h4 id="testing"&gt;{{m3FireDHWValues[m3FireDHWValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                        &lt;/div&gt;
                                        Member 1 DHW Outlet Temp
                                    &lt;h4 id="testing"&gt;{{m1OutletTempValues[m1OutletTempValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                                        Member 3 DHW Outlet Temp
                                    &lt;h4 id="testing"&gt;{{m3OutletTempValues[m3OutletTempValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                        &lt;/div&gt;
                                        Member 1 DHW Tank Temperature
                                    &lt;h4 id="testing"&gt;{{m1TankValues[m1TankValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                                        Member 3 DHW Tank Temperature
                                    &lt;h4 id="testing"&gt;{{m3TankValues[m3TankValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                        &lt;/div&gt;
                &lt;/md-card&gt;
            &lt;/div&gt;
            &lt;h3 class="centerText"&gt;DHW Flow and Temperature&lt;/h3&gt;
                        &lt;ma-serial-chart
                        series-1-values="dhwSupplyRateValues"
                        series-1-title="DHW Supply Rate"
                        series-2-values="dhwConsumedRateValues"
                        series-2-title="DHW Consumed Rate"
                        series-3-values="DHW22SupplyTemperatureValues"
                        series-3-title="DHW Supply Temperature"
                        legend="true"
                        options="{
                            valueAxes:[
                                    axisColor:'black',
                                    color:'black',
                                    title: 'Flow Rate (Gal / Min)',
                                    titleColor: 'black',
                                    fontSize:26,
                                    titleFontSize:26,
                                    minimum:0,
                                    maximum:100
                                    axisColor:'black',
                                    color:'black',
                                    fontSize:26,
                                    titleFontSize:26,
                                    minimum:0,
                                    maximum:180
                        }"&gt;
                &lt;/md-card&gt;
                                        DHW Supply Flow Rate
                                    &lt;h4 id="testing"&gt;{{dhwSupplyRateValues[dhwSupplyRateValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                                        22 DHW Supply Temperature
                                    &lt;h4 id="testing"&gt;{{DHW22SupplyTemperatureValues[DHW22SupplyTemperatureValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                        &lt;/div&gt;
                                        11th Flr DHW Return Flow Rate
                                    &lt;h4 id="testing"&gt;{{dhw11SupplyRateValues[dhw11SupplyRateValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                                        22 DHW Bsmt Return Temperature
                                    &lt;h4 id="testing"&gt;{{returnBasementTemperatureValues[returnBasementTemperatureValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                        &lt;/div&gt;
                                        DHW Consumed Flow Rate
                                    &lt;h4 id="testing"&gt;{{dhwConsumedRateValues[dhwConsumedRateValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                                        22 DHW 11th Flr Return Temp
                                    &lt;h4 id="testing"&gt;{{return11TemperatureValues[return11TemperatureValues.length - 1].rendered}}&lt;/h4&gt;
                            &lt;/md-card&gt;
                        &lt;/div&gt;
                &lt;/md-card&gt;
            &lt;/div&gt;
        &lt;/div&gt;
        &lt;script src="/modules/mangoUI/web/vendor/requirejs/require.js"&gt;&lt;/script&gt;
        &lt;script src="/modules/mangoUI/web/loaderConfig.js"&gt;&lt;/script&gt;
        &lt;script&gt;require(['ngMango/bootstrap']);&lt;/script&gt;
    &lt;/body&gt;
&lt;/html&gt;
]]></description><link>https://forum.mango-os.com/post/18131</link><guid isPermaLink="true">https://forum.mango-os.com/post/18131</guid><dc:creator><![CDATA[rshah]]></dc:creator><pubDate>Mon, 23 Apr 2018 17:37:29 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Fri, 20 Apr 2018 22:44:22 GMT]]></title><description><![CDATA[<p dir="auto">Here's how I would accomplish what you are doing:</p>
<pre><code>&lt;ma-watch-list-get ng-model="designer.watchList" parameters="designer.parameters" on-points-change="designer.points = $points" id="d01a1ce8-d4d7-43b3-831c-9c619fb4bace" watch-list-xid="WL_ac76beaa-10f4-40f0-b714-d0fda1c1e801"&gt;&lt;/ma-watch-list-get&gt;
&lt;div class="ma-designer-root" id="4a3435f4-e428-4ee2-8ba8-1cf4511aa999" style="width: 1366px; height: 768px; position: relative;"&gt;
    &lt;ma-point-values id="5a8730ae-18bc-443c-8bad-e9ef83ccf104" points="designer.points" rollup-interval="15 minutes" rollup="FIRST" to="designer.time" from="designer.time | maMoment:'subtract':12:'hours'" style="position: absolute; left: 27px; top: 0px;" values="designer.values"&gt;&lt;/ma-point-values&gt;
    &lt;ma-serial-chart id="2796c91b-75b7-4759-9228-60d2e840b90f" style="position: absolute; width: 854px; height: 541px; left: 29px; top: 93px;" points="designer.points" values="designer.values" legend="true"&gt;&lt;/ma-serial-chart&gt;
    &lt;ma-now id="2269ccdd-6d99-4732-81a4-3d607e73dbb8" style="position: absolute; left: 210px; top: 0px;" update-interval="1 minute" output="designer.time"&gt;&lt;/ma-now&gt;
&lt;/div&gt;
]]></description><link>https://forum.mango-os.com/post/18117</link><guid isPermaLink="true">https://forum.mango-os.com/post/18117</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Fri, 20 Apr 2018 22:44:22 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Fri, 20 Apr 2018 22:32:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rshah" aria-label="Profile: rshah">@<bdi>rshah</bdi></a> said in <a href="/post/18113">Retrieve last 12 hours of data</a>:</p>
<p dir="auto">How would we use latest if we wanted 12 hours worth of data (point values) for ma-serial-chart?</p>
<p dir="auto">You would have to know the sample/poll period of the data points.</p>
<p dir="auto">My end goal is to populate ma-serial-chart with 12 hours of point values for multiple datapoints. I can send you the code I am using to do that now if it would help.</p>
<p dir="auto">What rollup are you using? Have you opened your chrome developer tools and checked the network requests that are going out? Check they aren't occurring more frequently than you intended and that they aren't taking too long to complete.</p>
<p dir="auto">You can post up your code if you would like, sure.</p>
]]></description><link>https://forum.mango-os.com/post/18116</link><guid isPermaLink="true">https://forum.mango-os.com/post/18116</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Fri, 20 Apr 2018 22:32:30 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Fri, 20 Apr 2018 20:22:46 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jared-wiltshire" aria-label="Profile: jared-wiltshire">@<bdi>jared-wiltshire</bdi></a> said in <a href="/post/18108">Retrieve last 12 hours of data</a>:</p>
<p dir="auto">Are you sure that you don't have some other error in your console (e.g. infinite digest error) which could be causing the page to bog down?</p>
<p dir="auto">Hi, yes no error.</p>
<p dir="auto">I thought about using <code>latest</code> initially but as there is only a way to limit the scope of latest via NUMBER of points rather than time-duration, I moved away from it.</p>
]]></description><link>https://forum.mango-os.com/post/18113</link><guid isPermaLink="true">https://forum.mango-os.com/post/18113</guid><dc:creator><![CDATA[rshah]]></dc:creator><pubDate>Fri, 20 Apr 2018 20:22:46 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Fri, 20 Apr 2018 19:44:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rshah" aria-label="Profile: rshah">@<bdi>rshah</bdi></a> said in <a href="/post/18104">Retrieve last 12 hours of data</a>:</p>
<p dir="auto">Calling ma-point-values fetches all 12 hours (for example) of data every single time you call it?</p>
<p dir="auto">Correct. Although saying "calling" is a little confusing, its not a function, its an Angular component. It will fetch all 12 hours when its attributes change (e.g. when the time period changes).</p>
<p dir="auto">ma-get-point to get the latest point and push to the array</p>
<p dir="auto">Are you talking about point values rather than points?</p>
<p dir="auto">This is essentially what the <code>&lt;ma-point-values&gt;</code> component does if you set the <code>latest="x"</code> attribute.</p>
]]></description><link>https://forum.mango-os.com/post/18108</link><guid isPermaLink="true">https://forum.mango-os.com/post/18108</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Fri, 20 Apr 2018 19:44:03 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Fri, 20 Apr 2018 19:33:28 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/jared-wiltshire" aria-label="Profile: jared-wiltshire">@<bdi>jared-wiltshire</bdi></a> said in <a href="/post/18098">Retrieve last 12 hours of data</a>:</p>
<p dir="auto">How often are you retrieving point values? If you have a timer (ma-now) and are updating the query for point values too regularly you will definitely cause the system to bog down.</p>
<p dir="auto">Jared, we are retrieving once per minute.</p>
<p dir="auto">Am I correct in this assumption:</p>
<p dir="auto">Calling ma-point-values fetches all 12 hours (for example) of data every single time you call it?<br />
Or, does it only fetch the latest data?</p>
<p dir="auto">If the former, is there a better way of doing this? I can probably create an array and call ma-get-point to get the latest point and push to the array rather than getting 12 hours worth of data every minute for 8+ points.</p>
<p dir="auto">Thanks!</p>
]]></description><link>https://forum.mango-os.com/post/18104</link><guid isPermaLink="true">https://forum.mango-os.com/post/18104</guid><dc:creator><![CDATA[rshah]]></dc:creator><pubDate>Fri, 20 Apr 2018 19:33:28 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Fri, 20 Apr 2018 19:21:53 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/rshah" aria-label="Profile: rshah">@<bdi>rshah</bdi></a> said in <a href="/post/18093">Retrieve last 12 hours of data</a>:</p>
<p dir="auto">Is ma-point-values the best way to get all this data to show on a chart? We are using ma-point-values to retrieve 12 hours of values for 12 or so points, and it really feels like it is slowing down the entire page significantly</p>
]]></description><link>https://forum.mango-os.com/post/18098</link><guid isPermaLink="true">https://forum.mango-os.com/post/18098</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Fri, 20 Apr 2018 19:21:53 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Fri, 20 Apr 2018 00:55:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a></p>
<p dir="auto">Is ma-point-values the best way to get all this data to show on a chart? We are using ma-point-values to retrieve 12 hours of values for 12 or so points, and it really feels like it is slowing down the entire page <em>significantly</em></p>
]]></description><link>https://forum.mango-os.com/post/18093</link><guid isPermaLink="true">https://forum.mango-os.com/post/18093</guid><dc:creator><![CDATA[rshah]]></dc:creator><pubDate>Fri, 20 Apr 2018 00:55:11 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Tue, 17 Apr 2018 20:46:14 GMT]]></title><description><![CDATA[<p dir="auto">The second form is probably the preferred form. In the preceding form, it will be updated every digest cycle regardless of what triggered that digest update (the default timer, some other modeled object, etc) while the latter will only update on the update interval, even if other things change in the digest.</p>
]]></description><link>https://forum.mango-os.com/post/18063</link><guid isPermaLink="true">https://forum.mango-os.com/post/18063</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 17 Apr 2018 20:46:14 GMT</pubDate></item><item><title><![CDATA[Reply to Retrieve last 12 hours of data on Tue, 17 Apr 2018 20:12:16 GMT]]></title><description><![CDATA[<p dir="auto">Of course it works fine now.</p>
<p dir="auto">Magic.</p>
<p dir="auto">I'm curious though if anyone thinks it would be better to use</p>
<pre><code>'now' | maMoment:'subtract':12:'hours'
<p dir="auto">instead of:</p>
<pre><code>&lt;ma-now update-interval="1 minutes" output="to"&gt;&lt;/ma-now&gt;
<p dir="auto">?<br />
Not sure if that would work for us or not.</p>
]]></description><link>https://forum.mango-os.com/post/18057</link><guid isPermaLink="true">https://forum.mango-os.com/post/18057</guid><dc:creator><![CDATA[rshah]]></dc:creator><pubDate>Tue, 17 Apr 2018 20:12:16 GMT</pubDate></item></channel></rss>
