<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Text on gauges]]></title><description><![CDATA[<p dir="auto">I'm trying to use the ma-gauge-chart and have two issues.</p>
<li>The text between &lt;ma-gauge-chart&gt; does not seem to display &lt;/ma-gauge-chart&gt;. It shows in the editor when I edit it but does not appear on the final displayed page.</li>
<li>Can you set a units to dosplay with the value?</li>
<p dir="auto">Regards<br />
Peter</p>
]]></description><link>https://forum.mango-os.com/topic/3376/text-on-gauges</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 13:52:55 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3376.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 28 Mar 2018 20:29:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Text on gauges on Fri, 30 Mar 2018 07:19:17 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/petermcs" aria-label="Profile: petermcs">@<bdi>petermcs</bdi></a> you can move the position of the text with offset properties</p>
]]></description><link>https://forum.mango-os.com/post/17870</link><guid isPermaLink="true">https://forum.mango-os.com/post/17870</guid><dc:creator><![CDATA[pierjsap]]></dc:creator><pubDate>Fri, 30 Mar 2018 07:19:17 GMT</pubDate></item><item><title><![CDATA[Reply to Text on gauges on Fri, 30 Mar 2018 06:59:35 GMT]]></title><description><![CDATA[<p dir="auto">Thank you both very much. I've set the units on the data point and it now shows up on the gauge.<br />
The titles/text option puts the title on top which is not where it needs to be so I've just put the gauge in a div with the text after and styled it to center the text which works ok for now...</p>
<p dir="auto">Peter</p>
]]></description><link>https://forum.mango-os.com/post/17869</link><guid isPermaLink="true">https://forum.mango-os.com/post/17869</guid><dc:creator><![CDATA[petermcs]]></dc:creator><pubDate>Fri, 30 Mar 2018 06:59:35 GMT</pubDate></item><item><title><![CDATA[Reply to Text on gauges on Thu, 29 Mar 2018 08:17:05 GMT]]></title><description><![CDATA[<p dir="auto">How to suggest by Matt you can customize your gauge.</p>
<p dir="auto">&lt;ma-gauge-chart id="4cab95e2-1514-4e14-9edc-4563c92bebf1" style="position: absolute; width: 400px; height: 400px; left: 0px; top: 116px;" point="YOUR_POINT" animate-band-mode="true" arrow-alpha="0" interval="15" value-offset="15" tick-interval="90" tickcolor="#ff0000" band1-color="#ff0000" auto-start="true" auto-end="true" band1-end="90" options="{titles:[{text: 'YourTEXT',size: 15}],axes: [{startAngle: -90, endAngle:90,innerRadius:100}], radius: '105'}" radius="105"&gt;&lt;/ma-gauge-chart&gt;<br />
You can read the API and this post <a href="https://forum.infiniteautomation.com/topic/2943/gauge-styles" rel="nofollow ugc">Gauge styles</a> to realize personalize your gauge.</p>
<p dir="auto">I hope this helps ;) bye <a class="plugin-mentions-user plugin-mentions-a" href="/user/petermcs" aria-label="Profile: petermcs">@<bdi>petermcs</bdi></a></p>
]]></description><link>https://forum.mango-os.com/post/17861</link><guid isPermaLink="true">https://forum.mango-os.com/post/17861</guid><dc:creator><![CDATA[pierjsap]]></dc:creator><pubDate>Thu, 29 Mar 2018 08:17:05 GMT</pubDate></item><item><title><![CDATA[Reply to Text on gauges on Thu, 29 Mar 2018 01:19:45 GMT]]></title><description><![CDATA[<p dir="auto">I can tell you that the ma-gauge-chart tag is an angularJS component so it will not show anything between the tags, and thus not be rendered.<br />
Units usually show if you have set the unit field on the individual datapoint under /data_sources.shtm.<br />
Feel free to take screenshots and describe further what you are trying to accomplish.</p>
<p dir="auto">Fox</p>
]]></description><link>https://forum.mango-os.com/post/17856</link><guid isPermaLink="true">https://forum.mango-os.com/post/17856</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Thu, 29 Mar 2018 01:19:45 GMT</pubDate></item></channel></rss>
