<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Adding a data source column to the primary data sources window]]></title><description><![CDATA[<p dir="auto">Where we have many ES devices running, it is convenient to have all these machines streaming data to our primary cloud server.  Many of the data schemes have identical nomenclature and it would be wonderful if that on the primary data sources screen instead or in addition to the Data Source Type it could filter by data sources Name, We can include the data sources type distinction in the name if we had to  know the type.  It would help a lot with handling data points since all our devices have the same names across different data sources.   We can then filter all client data sources for example a client may have 3 properties,  multiple data sources for each, all with same schema, same device names,  right now we have no way to isolate just one client's devices as a filtered group on the cloud.</p>
]]></description><link>https://forum.mango-os.com/topic/3366/adding-a-data-source-column-to-the-primary-data-sources-window</link><generator>RSS for Node</generator><lastBuildDate>Sun, 13 Sep 2026 14:49:20 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3366.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 21 Mar 2018 13:16:30 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Adding a data source column to the primary data sources window on Mon, 14 May 2018 13:25:53 GMT]]></title><description><![CDATA[<p dir="auto">I just reread this, and I'm not sure i understood the question in the OP. On a reread, it sounds like this feature exists and should be unmissable:</p>
<p dir="auto"><img src="https://camo.nodebb.org/b1f09d39dfd9c983dd0859ceacf8438b9605ae93?url=https%3A%2F%2Fi.imgur.com%2F8oAYpUK.png" alt="0_1526304450256_dsNameFilter.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/18422</link><guid isPermaLink="true">https://forum.mango-os.com/post/18422</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 14 May 2018 13:25:53 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a data source column to the primary data sources window on Sun, 13 May 2018 06:06:23 GMT]]></title><description><![CDATA[<p dir="auto">Awesome! Was going to ask when this is coming, it  going to come in very handy.</p>
]]></description><link>https://forum.mango-os.com/post/18411</link><guid isPermaLink="true">https://forum.mango-os.com/post/18411</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Sun, 13 May 2018 06:06:23 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a data source column to the primary data sources window on Fri, 11 May 2018 15:58:03 GMT]]></title><description><![CDATA[<p dir="auto">Tags were added to the transmitted data point info in this interim. You can also define additional tags to mixin on either the publisher or the data source.</p>
]]></description><link>https://forum.mango-os.com/post/18407</link><guid isPermaLink="true">https://forum.mango-os.com/post/18407</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 11 May 2018 15:58:03 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a data source column to the primary data sources window on Fri, 11 May 2018 15:54:15 GMT]]></title><description><![CDATA[<p dir="auto">Yes ok I have not implemented any point tags yet and I do need this to go through persistent TCP so I have decided to decorate the Device-XID with a prefix for now and perhaps change later.  Anyhow this does eliminate much of the confusion of which points are from which devices. Thanks guys.</p>
]]></description><link>https://forum.mango-os.com/post/18405</link><guid isPermaLink="true">https://forum.mango-os.com/post/18405</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Fri, 11 May 2018 15:54:15 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a data source column to the primary data sources window on Wed, 21 Mar 2018 15:58:41 GMT]]></title><description><![CDATA[<p dir="auto">I concur with CraigWeb, but with the caveat that we haven't included tags in the point attributes transmitted by the Persistent publisher. This is high on our TODO list.</p>
<p dir="auto">The more oldschool way of doing this is to make your XIDs more meaningful.</p>
]]></description><link>https://forum.mango-os.com/post/17811</link><guid isPermaLink="true">https://forum.mango-os.com/post/17811</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 21 Mar 2018 15:58:41 GMT</pubDate></item><item><title><![CDATA[Reply to Adding a data source column to the primary data sources window on Wed, 21 Mar 2018 13:31:21 GMT]]></title><description><![CDATA[<p dir="auto">I think using the new point tagging system is going to be your best bet. Add your specific client as a tag to those points.</p>
]]></description><link>https://forum.mango-os.com/post/17807</link><guid isPermaLink="true">https://forum.mango-os.com/post/17807</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Wed, 21 Mar 2018 13:31:21 GMT</pubDate></item></channel></rss>
