<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[urgent alarm identification]]></title><description><![CDATA[<p dir="auto">running a system on Mango 3.0. Everything is working fine, but have gotten this urgent alarm that returns to normal after a few seconds.</p>
<p dir="auto">Exception from modbus master: Bad file descriptor (ioctl FIONREAD failed)</p>
<p dir="auto">Would like to know how to locate the problem causing the alarm. It happened about 7 times in Feb and 3 so far in Mar. It came to my attention after I started alarms to be sent out via text recently.</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.mango-os.com/topic/3360/urgent-alarm-identification</link><generator>RSS for Node</generator><lastBuildDate>Thu, 18 Jun 2026 14:01:29 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3360.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Mar 2018 15:25:33 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to urgent alarm identification on Mon, 02 Apr 2018 18:30:28 GMT]]></title><description><![CDATA[<p dir="auto">That makes more sense than it being a timeout. A timeout would have produced a ModbusTransportException with timeout as its message, not an operating system message about a file descriptor having issues.</p>
]]></description><link>https://forum.mango-os.com/post/17882</link><guid isPermaLink="true">https://forum.mango-os.com/post/17882</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 02 Apr 2018 18:30:28 GMT</pubDate></item><item><title><![CDATA[Reply to urgent alarm identification on Mon, 02 Apr 2018 18:25:05 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> Unfortunately, got the error again. I don't think it had anything to do with the solution I posted above; just a coincidence it stopped for a while. It returns back to normal in a few seconds ,shorter than our refresh time, so it isn't losing any data. It is modbus TCP. It must be just dropping signal. It is at a rural location. I just figured losing connection would alarm a different message.</p>
]]></description><link>https://forum.mango-os.com/post/17881</link><guid isPermaLink="true">https://forum.mango-os.com/post/17881</guid><dc:creator><![CDATA[sbaik]]></dc:creator><pubDate>Mon, 02 Apr 2018 18:25:05 GMT</pubDate></item><item><title><![CDATA[Reply to urgent alarm identification on Wed, 28 Mar 2018 14:44:52 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for sharing the resolution!</p>
]]></description><link>https://forum.mango-os.com/post/17841</link><guid isPermaLink="true">https://forum.mango-os.com/post/17841</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 28 Mar 2018 14:44:52 GMT</pubDate></item><item><title><![CDATA[Reply to urgent alarm identification on Wed, 28 Mar 2018 13:20:11 GMT]]></title><description><![CDATA[<p dir="auto">Hi phildunlap,</p>
<p dir="auto">It looks like the problem is gone after increasing the update period and the timeout. It must have been timing out momentarily.</p>
<p dir="auto">Thanks for your suggestion.</p>
]]></description><link>https://forum.mango-os.com/post/17834</link><guid isPermaLink="true">https://forum.mango-os.com/post/17834</guid><dc:creator><![CDATA[sbaik]]></dc:creator><pubDate>Wed, 28 Mar 2018 13:20:11 GMT</pubDate></item><item><title><![CDATA[Reply to urgent alarm identification on Mon, 19 Mar 2018 15:57:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi sbaik, welcome to the forum!</p>
<p dir="auto">I am guessing this is Modbus serial? I can't say I've seen that many times, i would wonder things like,</p>
<li>Does the serial port get momentarily disconnected? I think you would see it reconnect in the dmesg output.</li>
<li>Could someone be issuing different baud reads (perhaps through the API or modbus tools) to this serial line?</li>
<li>Do you miss data for a while when this happens?</li>
]]></description><link>https://forum.mango-os.com/post/17783</link><guid isPermaLink="true">https://forum.mango-os.com/post/17783</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 19 Mar 2018 15:57:25 GMT</pubDate></item></channel></rss>
