<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Add Data Manually]]></title><description><![CDATA[<p dir="auto">Hi, I have a client that has lost some data due to a field component not working.  Is there a way to insert data manually for this period?</p>
]]></description><link>https://forum.mango-os.com/topic/3294/add-data-manually</link><generator>RSS for Node</generator><lastBuildDate>Sat, 16 May 2026 23:46:07 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3294.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 22 Feb 2018 11:23:02 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Add Data Manually on Thu, 22 Feb 2018 14:24:42 GMT]]></title><description><![CDATA[<p dir="auto">Sure, just look at the Data Import module on the legacy UI.<br />
<img src="https://camo.nodebb.org/3b23003468d94db6cb52884dab048c288902f117?url=https%3A%2F%2Fi.imgur.com%2FY00GSiI.png" alt="0_1519309385754_Screenshot 2018-02-22 07.21.15.png" class=" img-fluid img-markdown" /><br />
You can download data from the legacy watch list and then use the Add/Delete column to add in new data.</p>
<p dir="auto">If you are using Excel and have issues it's probably due to Excel changing the format of your date and time.</p>
]]></description><link>https://forum.mango-os.com/post/17430</link><guid isPermaLink="true">https://forum.mango-os.com/post/17430</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 22 Feb 2018 14:24:42 GMT</pubDate></item></channel></rss>
