<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[using Modbus4j ,Jumping values while reading value from secure elite 440-447 energy meter]]></title><description><![CDATA[<p dir="auto">Hi , while i was reading values from secure elite 440-447 energy meter using modbus4j.jar in java the values are jumping (means exchanging for eg:suppose i used to get kwh at 401 registry after some time i am getting voltage in that registry.).can you please help me out,i am struggling with these problem from so many days.<br />
Thank You.</p>
]]></description><link>https://forum.mango-os.com/topic/3200/using-modbus4j-jumping-values-while-reading-value-from-secure-elite-440-447-energy-meter</link><generator>RSS for Node</generator><lastBuildDate>Thu, 21 May 2026 07:11:34 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3200.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 10 Jan 2018 05:38:01 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to using Modbus4j ,Jumping values while reading value from secure elite 440-447 energy meter on Wed, 10 Jan 2018 16:22:57 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sagarsama,</p>
<p dir="auto">So, you're requesting the same register over some period of time, and it never errors but the value is usually what you would expect for the kWh and occasionally what you expect for the instantaneous voltage? That's bizarre. I would set up a Mango reading that register for a while to be sure that is what is going on (you make it sounds as though you are using Modbus4J in your own application), but that sounds like an issue with the PLC. If you're requesting the same range of values and it is spontaneously changing those values, that is its issue.</p>
]]></description><link>https://forum.mango-os.com/post/16776</link><guid isPermaLink="true">https://forum.mango-os.com/post/16776</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 10 Jan 2018 16:22:57 GMT</pubDate></item></channel></rss>
