<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Failed to write core dump]]></title><description><![CDATA[<p dir="auto">Hello</p>
<p dir="auto">Now and then production Mango solution is found "crashed"! With this I mean that MANGO Stops once we can get access to Webmin.</p>
<p dir="auto">Looking to the generated logs I found a common message about Java than says: "Failed to write core dump. Core dumps have been disabled. To enable core dumping, try ulimit -c unlimited before starting Java again"</p>
<p dir="auto">My question is: Is it or not recommended to issue the specified command?</p>
<pre><code>ulimit -c unlimited
<p dir="auto">If you does not recommend it what should I try to solve the MANGO crashing issues?</p>
<p dir="auto">Thanks in advance,<br />
José</p>
]]></description><link>https://forum.mango-os.com/topic/3184/failed-to-write-core-dump</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 06:48:14 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3184.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 04 Jan 2018 12:27:44 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Failed to write core dump on Fri, 05 Jan 2018 16:23:08 GMT]]></title><description><![CDATA[<p dir="auto">You need to have Mango (and any other Java program) stopped when you do the update to Java, and then restart Mango with the new Java.</p>
]]></description><link>https://forum.mango-os.com/post/16728</link><guid isPermaLink="true">https://forum.mango-os.com/post/16728</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 05 Jan 2018 16:23:08 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to write core dump on Fri, 05 Jan 2018 11:03:39 GMT]]></title><description><![CDATA[<p dir="auto">Is there a special upgrade process for Java/MANGO that I have to pay attention once this is in a production environment or is that straight forward?</p>
José</p>
]]></description><link>https://forum.mango-os.com/post/16726</link><guid isPermaLink="true">https://forum.mango-os.com/post/16726</guid><dc:creator><![CDATA[jmatos]]></dc:creator><pubDate>Fri, 05 Jan 2018 11:03:39 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to write core dump on Thu, 04 Jan 2018 17:32:48 GMT]]></title><description><![CDATA[<p dir="auto">Your hs_err files contain,</p>
<pre><code>#
# A fatal error has been detected by the Java Runtime Environment:
#  SIGSEGV (0xb) at pc=0xb3f3d7cc, pid=592, tid=1828779104
<p dir="auto">One of the two hs_err files shows it was deep in the JVM when this happened. The first thing I would do in seeking resolution is update Java, as you appear to be on u33 when the latest are u151 and u152</p>
]]></description><link>https://forum.mango-os.com/post/16721</link><guid isPermaLink="true">https://forum.mango-os.com/post/16721</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 04 Jan 2018 17:32:48 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to write core dump on Thu, 04 Jan 2018 16:59:44 GMT]]></title><description><![CDATA[<p dir="auto">The problem to upload it seems</p>
<pre><code>Error
You do not have enough privileges for this action.
<p dir="auto">I will send to you by email</p>
]]></description><link>https://forum.mango-os.com/post/16720</link><guid isPermaLink="true">https://forum.mango-os.com/post/16720</guid><dc:creator><![CDATA[jmatos]]></dc:creator><pubDate>Thu, 04 Jan 2018 16:59:44 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to write core dump on Thu, 04 Jan 2018 16:56:30 GMT]]></title><description><![CDATA[<p dir="auto">Hmm, doesn't look like the upload worked. You can email them to us, or try the upload again. I find the buttons above the post body work best, and that I need to wait for it to present a blue link in the preview section of the post, which typically takes several seconds after it says <code>(Uploading 100%)</code></p>
]]></description><link>https://forum.mango-os.com/post/16719</link><guid isPermaLink="true">https://forum.mango-os.com/post/16719</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 04 Jan 2018 16:56:30 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to write core dump on Thu, 04 Jan 2018 16:54:09 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a></p>
<p dir="auto">Yes Phil I do have hs_err files.<br />
I upload the last ones hope it may help  [1_1515084790078_hs_err_pid592.log](Uploading 100%) [0_1515084790077_hs_err_pid568.log](Uploading 100%)</p>
<p dir="auto">Thanks,<br />
José</p>
]]></description><link>https://forum.mango-os.com/post/16718</link><guid isPermaLink="true">https://forum.mango-os.com/post/16718</guid><dc:creator><![CDATA[jmatos]]></dc:creator><pubDate>Thu, 04 Jan 2018 16:54:09 GMT</pubDate></item><item><title><![CDATA[Reply to Failed to write core dump on Thu, 04 Jan 2018 17:32:14 GMT]]></title><description><![CDATA[<p dir="auto">Hi José,</p>
<p dir="auto">I do not believe that is the cause. If it were, you would see messages in your ma.log files about not having enough available file descriptors. (Probably, IOException: Too many open files)</p>
<p dir="auto">It sounds like Java is having an error. Do you have any hs_err files in your Mango/ directory? If so, they should have information as to the cause. If not, what is occurring in your ma.log when it ends?</p>
]]></description><link>https://forum.mango-os.com/post/16717</link><guid isPermaLink="true">https://forum.mango-os.com/post/16717</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 04 Jan 2018 17:32:14 GMT</pubDate></item></channel></rss>
