<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Bulk edit Point Hierarchy]]></title><description><![CDATA[<p dir="auto">Is there a way to bulk edit the hierarchy? If not is there a way that when I import points via Excel I can tell it what folders it belongs to?</p>
]]></description><link>https://forum.mango-os.com/topic/3163/bulk-edit-point-hierarchy</link><generator>RSS for Node</generator><lastBuildDate>Tue, 12 May 2026 03:47:50 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3163.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 19 Dec 2017 17:17:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Bulk edit Point Hierarchy on Tue, 19 Dec 2017 19:07:26 GMT]]></title><description><![CDATA[<p dir="auto">Hi psysak,</p>
<p dir="auto">In the upcoming release we put a "path" property into the data point's JSON that is /path/to/folder for the import/export tool and endpoints, but not into the CSV.</p>
<p dir="auto">I can write a little python script here, if you like, that converts a CSV with a /path/to/folder column into a hierarchy JSON, if you would like.</p>
<p dir="auto">Edit: It will probably be added into the CSV model in 3.4, but I have no projection when that will be as we're trying to wrap 3.3 up currently.</p>
]]></description><link>https://forum.mango-os.com/post/16597</link><guid isPermaLink="true">https://forum.mango-os.com/post/16597</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 19 Dec 2017 19:07:26 GMT</pubDate></item></channel></rss>
