<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Performing a &quot;set&quot; on a Persistent TCP point]]></title><description><![CDATA[<p dir="auto">Is it possible to perform a set on a persistent TCP point such that the set gets pushed from the data source to the publisher?</p>
]]></description><link>https://forum.mango-os.com/topic/3156/performing-a-set-on-a-persistent-tcp-point</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 06:33:09 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3156.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 15 Dec 2017 22:25:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Performing a &quot;set&quot; on a Persistent TCP point on Thu, 10 Jan 2019 17:07:06 GMT]]></title><description><![CDATA[<blockquote>
<p dir="auto">Has anything changed with Persistent TCP being bi-directional now in 3.5??</p>
<p dir="auto">Yes. As Fox mentioned there is a setting on the publisher that permits it to accept sets. If,</p>
<ul>
<li>the "Allow data source to set values back" is enabled on the publisher</li>
<li>the original published point is settable</li>
<li>it is set as settable in the point created on the receiver</li>
<li>and the user has set permission to the point on the receiver</li>
</ul>
<p dir="auto">then you can set to the received point. It will behave as though it were set on the publishing device, such that the value is only recorded as it is echoed back in the normal course of publishing.</p>
]]></description><link>https://forum.mango-os.com/post/20936</link><guid isPermaLink="true">https://forum.mango-os.com/post/20936</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 10 Jan 2019 17:07:06 GMT</pubDate></item><item><title><![CDATA[Reply to Performing a &quot;set&quot; on a Persistent TCP point on Thu, 10 Jan 2019 01:26:11 GMT]]></title><description><![CDATA[<p dir="auto">Well it does allow you to set points back the other way assuming you tick the checkboxes to allow it. I still stick to separate points, at the cost yes it means more data, but easier debugging and troubleshooting means I'm happy.</p>
]]></description><link>https://forum.mango-os.com/post/20925</link><guid isPermaLink="true">https://forum.mango-os.com/post/20925</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Thu, 10 Jan 2019 01:26:11 GMT</pubDate></item><item><title><![CDATA[Reply to Performing a &quot;set&quot; on a Persistent TCP point on Thu, 10 Jan 2019 01:22:03 GMT]]></title><description><![CDATA[<p dir="auto">Has anything changed with Persistent TCP being bi-directional now in 3.5??</p>
]]></description><link>https://forum.mango-os.com/post/20924</link><guid isPermaLink="true">https://forum.mango-os.com/post/20924</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Thu, 10 Jan 2019 01:22:03 GMT</pubDate></item><item><title><![CDATA[Reply to Performing a &quot;set&quot; on a Persistent TCP point on Mon, 18 Dec 2017 16:57:14 GMT]]></title><description><![CDATA[<p dir="auto">As Fox suggested, it is not possible through the Persistent TCP points unless you use a second publisher. You can't set values to persistent TCP points generally.</p>
<p dir="auto">The TCP/IP data source is another choice to a new publisher.</p>
]]></description><link>https://forum.mango-os.com/post/16571</link><guid isPermaLink="true">https://forum.mango-os.com/post/16571</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 18 Dec 2017 16:57:14 GMT</pubDate></item><item><title><![CDATA[Reply to Performing a &quot;set&quot; on a Persistent TCP point on Sun, 17 Dec 2017 19:55:52 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/psysak" aria-label="Profile: psysak">@<bdi>psysak</bdi></a> If youn mean you have a mango unit publishing data and you want to be able to set back the other way, The only way to do so is to create a publisher going back the other way. That way when you set the datapoint on the mango unit receiving the published data the changes are pushed back to the initial mango unit doing the publishing. This does mean you would have a new datasource to capture and hold the set data.</p>
]]></description><link>https://forum.mango-os.com/post/16564</link><guid isPermaLink="true">https://forum.mango-os.com/post/16564</guid><dc:creator><![CDATA[MattFox]]></dc:creator><pubDate>Sun, 17 Dec 2017 19:55:52 GMT</pubDate></item></channel></rss>
