<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Missing Event Handler]]></title><description><![CDATA[<p dir="auto">I created a scheduled event and a corresponding event handler; then recently noticed it wasn't firing. Looking at the event handler, I saw there was no event handler. Puzzled, I created a new event handler, but when I clicked "save" it rejected it for an existing XID.</p>
<p dir="auto">When I do an export, I see the event handler, but in not the Event Handler page. Unfortunately, it is also failing to execute.</p>
<p dir="auto">Here is the JSON for the Scheduled Event and the Event Handler:</p>
<pre><code>{
   "eventHandlers":[
         "eventType":{
            "sourceType":"SCHEDULED",
            "XID":"SE_get_forecast"
         "xid":"EH_get_forecast",
         "handlerType":"PROCESS",
         "activeProcessCommand":"get_forecast.bash",
         "activeProcessTimeout":60,
         "inactiveProcessCommand":"",
         "inactiveProcessTimeout":15,
         "alias":"Get forecast",
         "disabled":true
   "scheduledEvents":[
         "xid":"SE_get_forecast",
         "alarmLevel":"NONE",
         "scheduleType":"HOURLY",
         "activeCron":"0 0\/5 * * * ? *",
         "activeDay":0,
         "activeHour":0,
         "activeMinute":0,
         "activeMonth":11,
         "activeSecond":0,
         "activeYear":2017,
         "alias":"Get Weather Forecast",
         "disabled":false,
         "inactiveCron":"",
         "inactiveDay":0,
         "inactiveHour":0,
         "inactiveMinute":0,
         "inactiveMonth":11,
         "inactiveSecond":0,
         "inactiveYear":2017,
         "returnToNormal":false
]]></description><link>https://forum.mango-os.com/topic/3112/missing-event-handler</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 06:32:05 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3112.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 28 Nov 2017 03:03:07 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Missing Event Handler on Wed, 29 Nov 2017 21:31:03 GMT]]></title><description><![CDATA[<p dir="auto">Understood, but there was no such file. There is a file named com.serotonin.m2m2.db.upgrade.Upgrade17.log but it's empty</p>
<pre><code>-rw-r--r-- 1 mango mango  0 Nov 22 14:44 com.infiniteautomation.mango.scheduling.db.upgrade.Upgrade4.log
-rw-r--r-- 1 mango mango  0 Nov 22 12:58 com.serotonin.m2m2.db.upgrade.Upgrade13.log
-rw-r--r-- 1 mango mango 35 Nov 22 12:58 com.serotonin.m2m2.db.upgrade.Upgrade14.log
-rw-r--r-- 1 mango mango  0 Nov 22 12:58 com.serotonin.m2m2.db.upgrade.Upgrade15.log
-rw-r--r-- 1 mango mango  0 Nov 22 12:58 com.serotonin.m2m2.db.upgrade.Upgrade16.log
-rw-r--r-- 1 mango mango  0 Nov 22 12:58 com.serotonin.m2m2.db.upgrade.Upgrade17.log
<p dir="auto">The one file which isn't completely empty only reads:</p>
<pre><code>Updated 0 user comments with XIDs.
]]></description><link>https://forum.mango-os.com/post/16342</link><guid isPermaLink="true">https://forum.mango-os.com/post/16342</guid><dc:creator><![CDATA[AldoRamos]]></dc:creator><pubDate>Wed, 29 Nov 2017 21:31:03 GMT</pubDate></item><item><title><![CDATA[Reply to Missing Event Handler on Wed, 29 Nov 2017 21:28:11 GMT]]></title><description><![CDATA[<p dir="auto">It would probably be called <code>com.serotonin.m2m2.db.upgrade.Upgrade18.log</code></p>
]]></description><link>https://forum.mango-os.com/post/16340</link><guid isPermaLink="true">https://forum.mango-os.com/post/16340</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 29 Nov 2017 21:28:11 GMT</pubDate></item><item><title><![CDATA[Reply to Missing Event Handler on Wed, 29 Nov 2017 21:21:01 GMT]]></title><description><![CDATA[<p dir="auto">Didn't catch any errors during the actual upgrade, and no file exists by that name. However, there is this in the logs:</p>
<pre><code>INFO  2017-11-23T23:16:18,652 (com.serotonin.m2m2.Lifecycle.initialize:192) - Initializing Spring Object Mapper
INFO  2017-11-23T23:16:19,014 (com.serotonin.m2m2.Lifecycle.initialize:214) - Setting default time zone to America/Anchorage
INFO  2017-11-23T23:16:19,034 (com.serotonin.m2m2.Lifecycle.loadLic:512) - Checking license...
INFO  2017-11-23T23:16:19,038 (com.serotonin.m2m2.Lifecycle.loadLic:559) - License file core version does not match instance, defaulting to free mode
WARN  2017-11-23T23:16:19,074 (com.serotonin.m2m2.TimedLicenseRegistrar.checkLicenses:62) - Mango NoSQL database is running in free mode, Mango will shutdown at 7:16:19 24/11/2017.
INFO  2017-11-23T23:16:19,135 (com.serotonin.m2m2.db.BasePooledProxy.initializeImpl:36) - Initializing pooled connection manager
WARN  2017-11-23T23:16:20,206 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:96) - Upgrading 'core' from 13 to 14
INFO  2017-11-23T23:16:20,208 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:152) - Writing upgrade log to /var/opt/mango/logs/com.serotonin.m2m2.db.upgrade.Upgrade13.log
WARN  2017-11-23T23:16:20,364 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:96) - Upgrading 'core' from 14 to 15
INFO  2017-11-23T23:16:20,364 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:152) - Writing upgrade log to /var/opt/mango/logs/com.serotonin.m2m2.db.upgrade.Upgrade14.log
WARN  2017-11-23T23:16:20,600 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:96) - Upgrading 'core' from 15 to 16
INFO  2017-11-23T23:16:20,600 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:152) - Writing upgrade log to /var/opt/mango/logs/com.serotonin.m2m2.db.upgrade.Upgrade15.log
WARN  2017-11-23T23:16:21,251 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:96) - Upgrading 'core' from 16 to 17
INFO  2017-11-23T23:16:21,251 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:152) - Writing upgrade log to /var/opt/mango/logs/com.serotonin.m2m2.db.upgrade.Upgrade16.log
INFO  2017-11-23T23:16:21,363 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:152) - Writing upgrade log to /var/opt/mango/logs/com.serotonin.m2m2.db.upgrade.Upgrade16.log
WARN  2017-11-23T23:16:21,409 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:96) - Upgrading 'core' from 17 to 18
INFO  2017-11-23T23:16:21,409 (com.serotonin.m2m2.db.upgrade.DBUpgrade.createUpdateLogOutputStream:152) - Writing upgrade log to /var/opt/mango/logs/com.serotonin.m2m2.db.upgrade.Upgrade17.log
INFO  2017-11-23T23:16:21,494 (com.serotonin.m2m2.db.upgrade.DBUpgrade.checkUpgrade:36) - Starting instance with core version 3.2.2+20171009170034, db 18
INFO  2017-11-23T23:16:21,494 (com.infiniteautomation.nosql.MangoNoSqlProxy.initialize:77) - Starting MangoNoSql Database
INFO  2017-11-23T23:16:21,522 (com.infiniteautomation.tsdb.maint.TTSDBUpgrade.checkForUpgrade:77) - Upgrading from 0 to 1
INFO  2017-11-23T23:16:21,527 (com.infiniteautomation.tsdb.maint.TTSDBUpgrade.checkForUpgrade:77) - Upgrading from 1 to 2
INFO  2017-11-23T23:16:21,528 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:141) - Database started
INFO  2017-11-23T23:16:21,556 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:170) - Empty dir delete took 0ms
INFO  2017-11-23T23:16:21,557 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:227) - Corruption scan skipped because the database is configured not to run scan.
INFO  2017-11-23T23:16:21,558 (com.infiniteautomation.tsdb.maint.TTSDBUpgrade.checkForUpgrade:77) - Upgrading from 0 to 1
INFO  2017-11-23T23:16:21,558 (com.infiniteautomation.tsdb.maint.TTSDBUpgrade.checkForUpgrade:77) - Upgrading from 1 to 2
INFO  2017-11-23T23:16:21,559 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:141) - Database started
INFO  2017-11-23T23:16:21,584 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:170) - Empty dir delete took 0ms
INFO  2017-11-23T23:16:21,586 (com.infiniteautomation.tsdb.impl.IasTsdbImpl.&lt;init&gt;:227) - Corruption scan skipped because the database is configured not to run scan.
<p dir="auto">Bear in mind that the upgrade installed NoSQL before I upgraded the license, in case that impacts the process.</p>
<p dir="auto">Also, that server quickly ran out of space and needed additional storage added, causing these errors in the log:</p>
<pre><code>ERROR 2017-11-23T23:16:36,863 (com.serotonin.m2m2.internal.InternalMenuItem$2.run:104) - You have reached the maximum number of data points permitted for your 'Free' license: 300
com.serotonin.m2m2.LicenseViolatedException: You have reached the maximum number of data points permitted for your 'Free' license: 300
        at com.serotonin.m2m2.db.dao.DataPointDao.checkAddPoint(DataPointDao.java:335) ~[mango-3.2.2.jar:?]
        at com.serotonin.m2m2.db.dao.DataPointDao.saveDataPoint(DataPointDao.java:308) ~[mango-3.2.2.jar:?]
        at com.serotonin.m2m2.rt.RuntimeManager.saveDataPoint(RuntimeManager.java:451) ~[mango-3.2.2.jar:?]
        at com.serotonin.m2m2.internal.InternalMenuItem.maybeCreatePoints(InternalMenuItem.java:280) ~[internal-ds-3.2.0.jar:?]
        at com.serotonin.m2m2.internal.InternalMenuItem.maybeInstallSystemMonitor(InternalMenuItem.java:210) ~[internal-ds-3.2.0.jar:?]
        at com.serotonin.m2m2.internal.InternalMenuItem.access$000(InternalMenuItem.java:45) ~[internal-ds-3.2.0.jar:?]
        at com.serotonin.m2m2.internal.InternalMenuItem$2.run(InternalMenuItem.java:102) [internal-ds-3.2.0.jar:?]
        at com.serotonin.m2m2.Lifecycle$2.run(Lifecycle.java:340) [ma-priv-3.2.2.jar:?]
        at com.serotonin.timer.Task.runTask(Task.java:179) [mango-3.2.2.jar:?]
        at com.serotonin.timer.TaskWrapper.run(TaskWrapper.java:23) [mango-3.2.2.jar:?]
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_144]
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_144]
        at java.lang.Thread.run(Thread.java:748) [?:1.8.0_144]
INFO  2017-11-23T23:18:07,642 (com.serotonin.m2m2.Lifecycle.loadLic:512) - Checking license...
INFO  2017-11-23T23:19:05,806 (com.serotonin.m2m2.web.dwr.ModulesDwr$UpgradeDownloader.run:397) - UpgradeDownloader started
INFO  2017-11-23T23:19:05,807 (com.serotonin.m2m2.web.dwr.ModulesDwr$UpgradeDownloader.run:402) - UpgradeDownloader: Backing up...
INFO  2017-11-23T23:19:05,808 (com.serotonin.m2m2.rt.maint.work.BackupWorkItem.execute:112) - Starting backup WorkItem.
INFO  2017-11-23T23:19:05,809 (com.serotonin.m2m2.web.dwr.ModulesDwr$UpgradeDownloader.run:414) - UpgradeDownloader: Downloading modules...
INFO  2017-11-23T23:19:05,809 (com.serotonin.m2m2.rt.maint.work.DatabaseBackupWorkItem.execute:109) - Starting database backup WorkItem.
INFO  2017-11-23T23:19:06,072 (com.serotonin.m2m2.web.dwr.ModulesDwr$UpgradeDownloader.run:495) - UpgradeDownloader: Installing...
INFO  2017-11-23T23:19:06,072 (com.serotonin.m2m2.web.dwr.ModulesDwr$UpgradeDownloader.run:545) - UpgradeDownloader: Restarting...
INFO  2017-11-23T23:19:57,344 (com.serotonin.m2m2.rt.maint.work.DatabaseBackupWorkItem.backupMysqlWithOutDatabase:444) - Could not create the backup for mango in RDS-NUS.iA3.io:3306
WARN  2017-11-23T23:19:57,416 (com.serotonin.m2m2.rt.maint.work.DatabaseBackupWorkItem.execute:176) - Unable to create backup file: /var/opt/mango/backup/core-database-MYSQL-Nov-23-2017_231905
ERROR 2017-11-23T23:20:02,417 (com.serotonin.m2m2.Lifecycle$5.run:1448) - Unabled to create restart flag file
java.io.IOException: No space left on device
        at java.io.FileOutputStream.writeBytes(Native Method) ~[?:1.8.0_144]
        at java.io.FileOutputStream.write(FileOutputStream.java:326) ~[?:1.8.0_144]
        at sun.nio.cs.StreamEncoder.writeBytes(StreamEncoder.java:221) ~[?:1.8.0_144]
        at sun.nio.cs.StreamEncoder.implClose(StreamEncoder.java:316) ~[?:1.8.0_144]
        at sun.nio.cs.StreamEncoder.close(StreamEncoder.java:149) ~[?:1.8.0_144]
        at java.io.OutputStreamWriter.close(OutputStreamWriter.java:233) ~[?:1.8.0_144]
        at com.serotonin.m2m2.Lifecycle$5.run(Lifecycle.java:1445) [ma-priv-3.2.2.jar:?]
INFO  2017-11-23T23:20:02,417 (com.serotonin.m2m2.Lifecycle.terminate:361) - Mango Lifecycle terminating...
INFO  2017-11-23T23:20:02,941 (com.serotonin.m2m2.rt.DataSourceGroupTerminator.terminate:72) - Terminating 2 NORMAL priority data sources in 8 threads.
INFO  2017-11-23T23:20:02,951 (com.serotonin.m2m2.rt.RuntimeManager.stopDataSourceShutdown:415) - Data source 'Creekwood Input' stopped
INFO  2017-11-23T23:20:03,280 (com.serotonin.m2m2.rt.RuntimeManager.stopDataSourceShutdown:415) - Data source 'Mango Persistent TCP' stopped
INFO  2017-11-23T23:20:03,342 (com.serotonin.m2m2.rt.DataSourceGroupTerminator.terminate:102) - Termination of 2 NORMAL priority data sources took 401ms
INFO  2017-11-23T23:20:03,343 (com.serotonin.m2m2.rt.maint.BackgroundProcessing.joinTermination:481) - All high priority tasks exited gracefully.
INFO  2017-11-23T23:20:03,343 (com.serotonin.m2m2.rt.maint.BackgroundProcessing.joinTermination:487) - All medium priority tasks exited gracefully.
INFO  2017-11-23T23:20:03,343 (com.serotonin.m2m2.rt.maint.BackgroundProcessing.joinTermination:492) - All low priority tasks exited gracefully.
INFO  2017-11-23T23:20:03,343 (com.serotonin.m2m2.db.BasePooledProxy.terminateImpl:110) - Stopping database
INFO  2017-11-23T23:20:03,344 (com.infiniteautomation.nosql.MangoNoSqlProxy.shutdown:115) - Terminating NoSQL Batch Write Manager.
INFO  2017-11-23T23:20:03,344 (com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehindManager.terminate:242) - Terminating NoSQL Point Value Mover.
<p dir="auto">Although these are different servers, some of this might be relevant to the other topic: <a href="https://forum.infiniteautomation.com/topic/3111/migrate-data-into-mango-nosql-does-not-appear-to-be-doing-anything" rel="nofollow ugc">Migrate Data into Mango (NoSQL) does not appear to be doing anything</a></p>
]]></description><link>https://forum.mango-os.com/post/16336</link><guid isPermaLink="true">https://forum.mango-os.com/post/16336</guid><dc:creator><![CDATA[AldoRamos]]></dc:creator><pubDate>Wed, 29 Nov 2017 21:21:01 GMT</pubDate></item><item><title><![CDATA[Reply to Missing Event Handler on Wed, 29 Nov 2017 20:51:45 GMT]]></title><description><![CDATA[<p dir="auto">Hmm. Event handlers were decoupled from event detectors in that time, so that tells me that Upgrade18 might not have occurred entirely correctly in your case. Do you have an Upgrade18 log in your Mango/logs? Did you get an error to your console when it was performing this upgrade?</p>
]]></description><link>https://forum.mango-os.com/post/16333</link><guid isPermaLink="true">https://forum.mango-os.com/post/16333</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 29 Nov 2017 20:51:45 GMT</pubDate></item><item><title><![CDATA[Reply to Missing Event Handler on Wed, 29 Nov 2017 06:32:23 GMT]]></title><description><![CDATA[<p dir="auto">Very odd. In frustration, I added another event handler, with the same parameters. It saved, executed, and shows in the Event Handlers page — but not the original! (which I have not deleted)</p>
<pre><code>{
   "eventHandlers":[
         "eventType":{
         "activeProcessCommand":"false",
         "disabled":false
         "eventType":{
         "xid":"EH_get_forecast2",
         "activeProcessCommand":"\/usr\/lib\/ia3-util\/get_forecast.bash",
         "alias":"Get Forecast",
         "disabled":false
   "scheduledEvents":[
         "activeDay":0,
         "activeHour":0,
         "activeMinute":15,
         "activeMonth":11,
         "activeSecond":0,
         "activeYear":2017,
         "disabled":false,
         "inactiveCron":"",
         "inactiveDay":0,
         "inactiveHour":0,
         "inactiveMinute":0,
         "inactiveMonth":11,
         "inactiveSecond":0,
]]></description><link>https://forum.mango-os.com/post/16328</link><guid isPermaLink="true">https://forum.mango-os.com/post/16328</guid><dc:creator><![CDATA[AldoRamos]]></dc:creator><pubDate>Wed, 29 Nov 2017 06:32:23 GMT</pubDate></item><item><title><![CDATA[Reply to Missing Event Handler on Tue, 28 Nov 2017 23:37:54 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> said in <a href="/post/16318">Missing Event Handler</a>:</p>
<p dir="auto">because <code>"disabled":true</code></p>
<p dir="auto">Uh, yeah. chuckles.... I tinkered with the the config in hopes of triggering it just right, and that's one of the parameters I changed. Before I shared it. But after I saw it fail. ;-)</p>
<p dir="auto">On the less bonehead note, clearing the browser or the work directory did not seem to change anything.</p>
<p dir="auto">FWIW this server was recently upgraded from 2.8 to 3.2, if that tells you anything.</p>
]]></description><link>https://forum.mango-os.com/post/16323</link><guid isPermaLink="true">https://forum.mango-os.com/post/16323</guid><dc:creator><![CDATA[AldoRamos]]></dc:creator><pubDate>Tue, 28 Nov 2017 23:37:54 GMT</pubDate></item><item><title><![CDATA[Reply to Missing Event Handler on Tue, 28 Nov 2017 19:55:55 GMT]]></title><description><![CDATA[<p dir="auto">Hi Aldo,</p>
<p dir="auto">I imported it without issue. Can you try clearing your browser cache and deleting your Mango/work/jsp directory?</p>
<p dir="auto">Whatever the display issue, it's probably not executing because <code>"disabled":true</code> in the configuration you posted.</p>
]]></description><link>https://forum.mango-os.com/post/16318</link><guid isPermaLink="true">https://forum.mango-os.com/post/16318</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 28 Nov 2017 19:55:55 GMT</pubDate></item></channel></rss>
