<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[About Slave Connection]]></title><description><![CDATA[<p dir="auto">Hi;</p>
<p dir="auto">I am using bac4j and bacnet newly. I want to make  a connection to bacnet as a slave. The SlaveDeviceTest examples is working good. But there are some question about that<br />
Q1- When I make a connection to bacnet as a slave, the device created on network 0(on local network). How can I create on other network(Network 1 or 2 ...)</p>
<p dir="auto">Q2-The Analog Output was Created  in SlaveDeviceTest example. But When I try the this output to write from out application "Write access denied" message occured. (The Analog Input is working good. I can see input values)</p>
<p dir="auto">I hope You can help me<br />
Thank you for your interest</p>
]]></description><link>https://forum.mango-os.com/topic/303/about-slave-connection</link><generator>RSS for Node</generator><lastBuildDate>Wed, 11 Nov 2026 06:45:21 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/303.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 Feb 2010 10:48:14 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to About Slave Connection on Thu, 16 Feb 2012 08:15:32 GMT]]></title><description><![CDATA[<p dir="auto">The real-life analogy is, e.g. an outdoor temperature. You can only read it - you can't change it (realistically). In cases like this having a read-only type is appropriate.</p>
]]></description><link>https://forum.mango-os.com/post/6177</link><guid isPermaLink="true">https://forum.mango-os.com/post/6177</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Thu, 16 Feb 2012 08:15:32 GMT</pubDate></item><item><title><![CDATA[Reply to About Slave Connection on Thu, 16 Feb 2012 08:04:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mlohbihler" aria-label="Profile: mlohbihler">@<bdi>mlohbihler</bdi></a> said:</p>
<p dir="auto">Q2) An Analog Output is read only. You can only write to Analog Input and Analog Value (of the 3 Analog types). Same goes for Binary and Multistate. So, the write access denied error is correct.</p>
<p dir="auto">I would like to ask if there's any reason for Analog Output to be read-only ?</p>
]]></description><link>https://forum.mango-os.com/post/6176</link><guid isPermaLink="true">https://forum.mango-os.com/post/6176</guid><dc:creator><![CDATA[cepheid]]></dc:creator><pubDate>Thu, 16 Feb 2012 08:04:13 GMT</pubDate></item><item><title><![CDATA[Reply to About Slave Connection on Mon, 22 Feb 2010 00:25:50 GMT]]></title><description><![CDATA[<p dir="auto">Q1) My understanding is that the local device does not specify source address information. This is added by a router when the request is destined for a remote network. So, there is no need to specify this information.</p>
]]></description><link>https://forum.mango-os.com/post/3261</link><guid isPermaLink="true">https://forum.mango-os.com/post/3261</guid><dc:creator><![CDATA[mlohbihler]]></dc:creator><pubDate>Mon, 22 Feb 2010 00:25:50 GMT</pubDate></item></channel></rss>
