<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MSSQL Data Source ClassNotFoundException]]></title><description><![CDATA[<p dir="auto">I installed Mango on my Windows 10 laptop to start testing. Trying to build an MSSQL data source to database located on my laptop. Seeing the following error:<br />
INFO  2017-10-11T03:42:34,330 (com.serotonin.m2m2.sql.SqlDataSourceRT.initialize:510) - Error while initializing data source<br />
java.lang.ClassNotFoundException: com.microsoft.sqlserver.jdbc.SQLServerDriver<br />
at java.net.URLClassLoader.findClass(URLClassLoader.java:381) ~[?:1.8.0_131]<br />
at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_131]<br />
at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_131]<br />
at java.lang.Class.forName0(Native Method) ~[?:1.8.0_131]<br />
at java.lang.Class.forName(Class.java:264) ~[?:1.8.0_131]<br />
at com.serotonin.m2m2.sql.SqlDataSourceRT.initialize(SqlDataSourceRT.java:498) [sql-ds-3.2.0.jar:?]<br />
at com.serotonin.m2m2.sql.SqlDataSourceRT.manageConnection(SqlDataSourceRT.java:281) [sql-ds-3.2.0.jar:?]<br />
at com.serotonin.m2m2.sql.SqlDataSourceRT.doPoll(SqlDataSourceRT.java:298) [sql-ds-3.2.0.jar:?]<br />
at com.serotonin.m2m2.rt.dataSource.PollingDataSource.doPollNoSync(PollingDataSource.java:196) [mango-3.2.1.jar:?]<br />
at com.serotonin.m2m2.rt.dataSource.PollingDataSource.scheduleTimeoutImpl(PollingDataSource.java:162) [mango-3.2.1.jar:?]<br />
at com.serotonin.m2m2.rt.dataSource.PollingDataSource$1.scheduleTimeout(PollingDataSource.java:70) [mango-3.2.1.jar:?]<br />
at com.serotonin.m2m2.util.timeout.TimeoutTask.run(TimeoutTask.java:59) [mango-3.2.1.jar:?]<br />
at com.serotonin.timer.Task.runTask(Task.java:179) [mango-3.2.1.jar:?]<br />
at com.serotonin.timer.TaskWrapper.run(TaskWrapper.java:23) [mango-3.2.1.jar:?]<br />
at com.serotonin.timer.OrderedThreadPoolExecutor$OrderedTaskCollection.run(OrderedThreadPoolExecutor.java:307) [mango-3.2.1.jar:?]<br />
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]<br />
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]<br />
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]</p>
<p dir="auto">My driver class setting is as follows: com.microsoft.sqlserver.jdbc.SQLServerDriver</p>
<p dir="auto">My connection string is as follows: jdbc:sqlserver://127.0.0.1:1433;database=Bisson;integratedSecurity=false;</p>
<p dir="auto">I am not sure what I am missing here.</p>
<p dir="auto">Please advise.</p>
<p dir="auto">Thanks,</p>
]]></description><link>https://forum.mango-os.com/topic/3001/mssql-data-source-classnotfoundexception</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 09:01:35 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/3001.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 11 Oct 2017 03:44:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MSSQL Data Source ClassNotFoundException on Wed, 11 Oct 2017 05:01:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi eksantrik,</p>
<p dir="auto">The JDBC driver for MSSQL is not bundled with Mango. You can download it here: <a href="https://docs.microsoft.com/en-us/sql/connect/sql-connection-libraries#anchor-20-drivers-relational-access" rel="nofollow ugc">https://docs.microsoft.com/en-us/sql/connect/sql-connection-libraries#anchor-20-drivers-relational-access</a> (has links for 6.0 and 6.2 for Java currently). You want the .tar.gz download, it'll have the driver compiled for Java 8, so copy that jar into your Mango/overrides/lib directory and try again.</p>
]]></description><link>https://forum.mango-os.com/post/15787</link><guid isPermaLink="true">https://forum.mango-os.com/post/15787</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 11 Oct 2017 05:01:07 GMT</pubDate></item></channel></rss>
