<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Hard coding the rollup-type in the watchlist-chart]]></title><description><![CDATA[<p dir="auto">I am trying to hard code the watchlist-chart rollup-type = "DELTA" changing it from the dateBar.rollupType value but it is not changing?  It Only changes when I use dateBar.rollupType and change it here in this dateBar... Any ideas?<br />
Are the parameters for rollup still [NONE, AVERAGE,DELTA,MINIMUM,<br />
MAXIMUM,ACCUMULATOR,SUM,FIRST,LAST]  ??</p>
]]></description><link>https://forum.mango-os.com/topic/2985/hard-coding-the-rollup-type-in-the-watchlist-chart</link><generator>RSS for Node</generator><lastBuildDate>Fri, 15 May 2026 23:32:33 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2985.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 03 Oct 2017 15:00:51 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Hard coding the rollup-type in the watchlist-chart on Thu, 06 Sep 2018 14:51:42 GMT]]></title><description><![CDATA[<p dir="auto">in the API docs for the &lt;ma-point-values&gt;  (ui/docs/ng-mango/ma-point-values).  You'll see all the options that can used. Just remember to make them a string.</p>
]]></description><link>https://forum.mango-os.com/post/19761</link><guid isPermaLink="true">https://forum.mango-os.com/post/19761</guid><dc:creator><![CDATA[CraigWeb]]></dc:creator><pubDate>Thu, 06 Sep 2018 14:51:42 GMT</pubDate></item><item><title><![CDATA[Reply to Hard coding the rollup-type in the watchlist-chart on Thu, 06 Sep 2018 13:18:40 GMT]]></title><description><![CDATA[<p dir="auto">Just hit on this cause I'm trying to do the exact same thing. Thanks for sharing.</p>
<p dir="auto">Is there a place I can easily refer to to find all possible values for the parameters? Can I suggest a link from the help files?</p>
]]></description><link>https://forum.mango-os.com/post/19760</link><guid isPermaLink="true">https://forum.mango-os.com/post/19760</guid><dc:creator><![CDATA[psysak]]></dc:creator><pubDate>Thu, 06 Sep 2018 13:18:40 GMT</pubDate></item><item><title><![CDATA[Reply to Hard coding the rollup-type in the watchlist-chart on Tue, 03 Oct 2017 16:09:54 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for sharing the resolution! Glad you're enjoying it!</p>
]]></description><link>https://forum.mango-os.com/post/15723</link><guid isPermaLink="true">https://forum.mango-os.com/post/15723</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 03 Oct 2017 16:09:54 GMT</pubDate></item><item><title><![CDATA[Reply to Hard coding the rollup-type in the watchlist-chart on Tue, 03 Oct 2017 15:27:49 GMT]]></title><description><![CDATA[<p dir="auto">It works with double quotes and needed double quotes around the value   rollup-type = " 'DELTA' "<br />
... I love the design of this engine, It's a powerful tool for sure.<br />
great job team!!</p>
]]></description><link>https://forum.mango-os.com/post/15720</link><guid isPermaLink="true">https://forum.mango-os.com/post/15720</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Tue, 03 Oct 2017 15:27:49 GMT</pubDate></item></channel></rss>
