<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How to use the override folder]]></title><description><![CDATA[<p dir="auto">Hello, I have an interface for a plant and I'm trying to put it in <strong>override</strong> folder to avoid to remake hole interface again in dashboard design but is something that I'm doing wrong because it's not working... Can someone give some advice on how should I do it.<br />
I tried to follow the tutorial from adminTemplate but didn't worked.</p>
]]></description><link>https://forum.mango-os.com/topic/2947/how-to-use-the-override-folder</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 01:27:10 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2947.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Sep 2017 17:12:00 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How to use the override folder on Wed, 20 Sep 2017 16:29:25 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for this, I'll try...</p>
]]></description><link>https://forum.mango-os.com/post/15548</link><guid isPermaLink="true">https://forum.mango-os.com/post/15548</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Wed, 20 Sep 2017 16:29:25 GMT</pubDate></item><item><title><![CDATA[Reply to How to use the override folder on Fri, 15 Sep 2017 17:52:41 GMT]]></title><description><![CDATA[<p dir="auto">Here is a support article that covers the general process of setting up your own AngularJS module:</p>
<p dir="auto"><a href="https://help.infiniteautomation.com/getting-started-with-a-user-module/" rel="nofollow ugc">https://help.infiniteautomation.com/getting-started-with-a-user-module/</a></p>
]]></description><link>https://forum.mango-os.com/post/15508</link><guid isPermaLink="true">https://forum.mango-os.com/post/15508</guid><dc:creator><![CDATA[Will Geller]]></dc:creator><pubDate>Fri, 15 Sep 2017 17:52:41 GMT</pubDate></item><item><title><![CDATA[Reply to How to use the override folder on Fri, 15 Sep 2017 15:08:19 GMT]]></title><description><![CDATA[<p dir="auto">Hi George,</p>
<p dir="auto">The best way to add custom javascript is to use the userModule feature as described here:<br />
<a href="https://forum.infiniteautomation.com/topic/2831/publishing-live-dashboard/2" rel="nofollow ugc">https://forum.infiniteautomation.com/topic/2831/publishing-live-dashboard/2</a></p>
<p dir="auto">Essentially what you are doing is creating an angular module that is editable right from the UI Settings page. You can create your own controllers, components, directives, filters etc.</p>
<p dir="auto">I plan to release a support article or video today that reveals the basics on how to work with this feature of Mango.</p>
]]></description><link>https://forum.mango-os.com/post/15499</link><guid isPermaLink="true">https://forum.mango-os.com/post/15499</guid><dc:creator><![CDATA[Will Geller]]></dc:creator><pubDate>Fri, 15 Sep 2017 15:08:19 GMT</pubDate></item><item><title><![CDATA[Reply to How to use the override folder on Fri, 15 Sep 2017 08:48:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: joelhaggar">@<bdi>joelhaggar</bdi></a> Thanks for replay, with images is simple but I have some pages with some functions made in JavaScript and I want to import the page so that I am don't have to rewrite all in Angular again... Is this possible?</p>
]]></description><link>https://forum.mango-os.com/post/15495</link><guid isPermaLink="true">https://forum.mango-os.com/post/15495</guid><dc:creator><![CDATA[georgestefan]]></dc:creator><pubDate>Fri, 15 Sep 2017 08:48:49 GMT</pubDate></item><item><title><![CDATA[Reply to How to use the override folder on Thu, 14 Sep 2017 18:31:00 GMT]]></title><description><![CDATA[<p dir="auto">Even better you can use the new File Store in Mango.  You can see it's menu item under Administration and there you can upload, download and edit files.  In other places throughout Mango like the Dashboard Designer you can then use a file picker to select images files from the File Store.</p>
]]></description><link>https://forum.mango-os.com/post/15482</link><guid isPermaLink="true">https://forum.mango-os.com/post/15482</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 14 Sep 2017 18:31:00 GMT</pubDate></item></channel></rss>
