<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Interval Logging of Meta Point Not Working]]></title><description><![CDATA[<p dir="auto">We've set interval logging to every minute, however all data points seem to be logged.<br />
When exporting chart data or viewing the chart there seems to be a point logged on every context update.<br />
What we would like is one point every minute that is the average / max of all of the context update values.<br />
What are we doing wrong here?</p>
<p dir="auto">Cheers.</p>
]]></description><link>https://forum.mango-os.com/topic/2934/interval-logging-of-meta-point-not-working</link><generator>RSS for Node</generator><lastBuildDate>Wed, 07 Oct 2026 03:24:10 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2934.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Sep 2017 06:37:03 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Interval Logging of Meta Point Not Working on Tue, 19 Sep 2017 14:57:21 GMT]]></title><description><![CDATA[<p dir="auto">Aha! Certianly! Thanks for sharing the resolution.</p>
]]></description><link>https://forum.mango-os.com/post/15536</link><guid isPermaLink="true">https://forum.mango-os.com/post/15536</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 19 Sep 2017 14:57:21 GMT</pubDate></item><item><title><![CDATA[Reply to Interval Logging of Meta Point Not Working on Tue, 19 Sep 2017 05:29:33 GMT]]></title><description><![CDATA[<p dir="auto">Hi phildunlap,</p>
<p dir="auto">I've just realised I left out a key piece of information here.<br />
The data is being published to a mango server using Mango Persistent TCP.<br />
I have since noticed that the publisher's Update event was set to All!  I have now corrected this to Logged data and the points on the server are now correct.<br />
Thanks for the assistance.</p>
<p dir="auto">Jeon</p>
]]></description><link>https://forum.mango-os.com/post/15532</link><guid isPermaLink="true">https://forum.mango-os.com/post/15532</guid><dc:creator><![CDATA[jeon]]></dc:creator><pubDate>Tue, 19 Sep 2017 05:29:33 GMT</pubDate></item><item><title><![CDATA[Reply to Interval Logging of Meta Point Not Working on Fri, 15 Sep 2017 18:12:06 GMT]]></title><description><![CDATA[<p dir="auto">Hi Jeon,</p>
<p dir="auto">I still find myself wondering if you're using a rollup, nothing in that configuration would circumvent interval logging. Can you post a screenshot of the page you're talking about, and, if it's the new data point details page, can you expand the header bar to include your date options in the screenshot?</p>
]]></description><link>https://forum.mango-os.com/post/15511</link><guid isPermaLink="true">https://forum.mango-os.com/post/15511</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 15 Sep 2017 18:12:06 GMT</pubDate></item><item><title><![CDATA[Reply to Interval Logging of Meta Point Not Working on Thu, 14 Sep 2017 01:35:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi phildunlap,</p>
<p dir="auto">The JSON for the point is as below:</p>
<pre><code>{
   "dataPoints":[
         "xid":"DP_015105",
         "name":"Customer - W",
         "enabled":true,
         "loggingType":"INTERVAL",
         "purgeType":"YEARS",
         "pointLocator":{
            "dataType":"NUMERIC",
            "updateEvent":"CONTEXT_UPDATE",
            "context":[
                  "varName":"pv",
                  "dataPointXid":"DP_732541",
                  "updateContext":true
                  "varName":"batt",
                  "dataPointXid":"DP_670549",
            "logLevel":"NONE",
            "executionDelaySeconds":0,
            "script":"return pv.value + batt.value;",
            "scriptPermissions":{
               "customPermissions":"",
               "dataPointReadPermissions":"superadmin",
               "dataPointSetPermissions":"superadmin",
               "dataSourcePermissions":"superadmin"
            "settable":false,
            "updateCronPattern":""
         "eventDetectors":[
         "plotType":"SPLINE",
         "unit":"W",
         "chartColour":"black",
         "chartRenderer":{
            "type":"IMAGE",
            "timePeriodType":"DAYS",
            "numberOfPeriods":1
         "dataSourceXid":"DS_458140",
         "defaultCacheSize":1,
         "deviceName":"Meta",
         "discardExtremeValues":true,
         "discardHighLimit":20000.0,
         "discardLowLimit":-20000.0,
         "intervalLoggingPeriod":1,
         "purgeOverride":false,
         "purgePeriod":1,
         "readPermission":"",
         "setPermission":"",
         "textRenderer":{
            "type":"ANALOG",
            "useUnitAsSuffix":true,
            "unit":"W",
            "renderedUnit":"W",
            "format":"0.00"
         "tolerance":0.0
<p dir="auto">It is an active meta point.</p>
<p dir="auto">I am not using a rollup, I am just viewing the point details chart and using its download chart data function.</p>
]]></description><link>https://forum.mango-os.com/post/15448</link><guid isPermaLink="true">https://forum.mango-os.com/post/15448</guid><dc:creator><![CDATA[jeon]]></dc:creator><pubDate>Thu, 14 Sep 2017 01:35:39 GMT</pubDate></item><item><title><![CDATA[Reply to Interval Logging of Meta Point Not Working on Wed, 13 Sep 2017 15:23:39 GMT]]></title><description><![CDATA[<p dir="auto">Hi jeon,</p>
<p dir="auto">Can you post the script body of your meta point or share its JSON export? Are you doing history generation, or is this on an active meta point?</p>
<p dir="auto">Edit: It was suggested to me that you may be using a rollup to view the chart. Can you check that? The rollup will appear to have data for every interval of the rollup.</p>
]]></description><link>https://forum.mango-os.com/post/15427</link><guid isPermaLink="true">https://forum.mango-os.com/post/15427</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 13 Sep 2017 15:23:39 GMT</pubDate></item></channel></rss>
