<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TCP/IP data source setup value]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have defined TCP/IP data source. On remote machine I have tcp server. With TCP/IP data point I want to change a value on the remote machine. I've noticed, that when I click "Submit" in Test Utility frame of the TCP/IP data source, the test string is sended every second time: when I click for the first time it sends, clicked second time doesn't send, clicked third time sends...and so on. I want to send value every time I setup value of the data point. Is there something wrong with the data source config? Regards</p>
]]></description><link>https://forum.mango-os.com/topic/2893/tcp-ip-data-source-setup-value</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 09:29:06 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2893.rss" rel="self" type="application/rss+xml"/><pubDate>Sat, 12 Aug 2017 15:32:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TCP/IP data source setup value on Thu, 31 Aug 2017 17:27:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi przemom,</p>
<p dir="auto">We released version 3.2.1 of the TCP/IP data source, which includes the changes from that issue to make it more robust. Give it a try!</p>
]]></description><link>https://forum.mango-os.com/post/15338</link><guid isPermaLink="true">https://forum.mango-os.com/post/15338</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 31 Aug 2017 17:27:00 GMT</pubDate></item><item><title><![CDATA[Reply to TCP/IP data source setup value on Mon, 14 Aug 2017 16:11:42 GMT]]></title><description><![CDATA[<p dir="auto">Hi przemom,</p>
<p dir="auto">There probably is room for us to make that more robust. I noticed I was able to choke up the data source by pounding the set button while it was pointed at a nc -k. I found that decreasing the timeout and retries made it a lot less likely that it'd get it stuck, but it still was able to. I was not able to reproduce what you're describing, where it's every other. I have created a git issue for this: <a href="https://github.com/infiniteautomation/ma-core-public/issues/1068" rel="nofollow ugc">https://github.com/infiniteautomation/ma-core-public/issues/1068</a></p>
]]></description><link>https://forum.mango-os.com/post/15187</link><guid isPermaLink="true">https://forum.mango-os.com/post/15187</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 14 Aug 2017 16:11:42 GMT</pubDate></item></channel></rss>
