<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[MangoES IP Address]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I have a Mango ES with Mango V3 and I changed the IP address to a static one using the old way (interface).<br />
After that I can't find the device on my network and don't respond to the fix IP that I give it.<br />
I power cycle the box too but nothing come up.<br />
How I can restore / re found my box on the network.?<br />
Thanks<br />
Mircea</p>
]]></description><link>https://forum.mango-os.com/topic/2873/mangoes-ip-address</link><generator>RSS for Node</generator><lastBuildDate>Mon, 11 May 2026 12:25:24 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2873.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Jul 2017 21:45:12 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to MangoES IP Address on Thu, 26 Oct 2017 15:15:42 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/psysak" aria-label="Profile: psysak">@<bdi>psysak</bdi></a> said in <a href="/post/15971">MangoES IP Address</a>:</p>
<p dir="auto">Ya the new v3 interface has no way to edit up info?</p>
<p dir="auto">Correct, its on the TODO list. Please use the old UI for the time being, sorry for the inconvenience.</p>
]]></description><link>https://forum.mango-os.com/post/15975</link><guid isPermaLink="true">https://forum.mango-os.com/post/15975</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Thu, 26 Oct 2017 15:15:42 GMT</pubDate></item><item><title><![CDATA[Reply to MangoES IP Address on Thu, 26 Oct 2017 14:23:37 GMT]]></title><description><![CDATA[<p dir="auto">Ya the new v3 interface has no way to edit up info?</p>
]]></description><link>https://forum.mango-os.com/post/15971</link><guid isPermaLink="true">https://forum.mango-os.com/post/15971</guid><dc:creator><![CDATA[psysak]]></dc:creator><pubDate>Thu, 26 Oct 2017 14:23:37 GMT</pubDate></item><item><title><![CDATA[Reply to MangoES IP Address on Fri, 28 Jul 2017 14:57:47 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mircea,</p>
<p dir="auto">You could... (any one would be sufficient)</p>
<ul>
<li>Uninstall usbmount</li>
<li>Remove the call to /opt/control/esUsbUtility.sh from /usr/share/usbmount/usbmount</li>
<li>Remove /opt/control/esUsbUtility.sh or remove only the functions you do not want on that device from the function calls near the bottom.</li>
</ul>
]]></description><link>https://forum.mango-os.com/post/15105</link><guid isPermaLink="true">https://forum.mango-os.com/post/15105</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 28 Jul 2017 14:57:47 GMT</pubDate></item><item><title><![CDATA[Reply to MangoES IP Address on Fri, 28 Jul 2017 01:40:54 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Joel,<br />
I will try you suggestion tomorrow.<br />
It is there a way to disable the function of USB Utility ?<br />
I have a project that I like to disable the USB functions.<br />
Thanks<br />
Mircea</p>
]]></description><link>https://forum.mango-os.com/post/15102</link><guid isPermaLink="true">https://forum.mango-os.com/post/15102</guid><dc:creator><![CDATA[Mircea]]></dc:creator><pubDate>Fri, 28 Jul 2017 01:40:54 GMT</pubDate></item><item><title><![CDATA[Reply to MangoES IP Address on Thu, 27 Jul 2017 23:22:17 GMT]]></title><description><![CDATA[<p dir="auto">I would recommend using the <a href="https://help.infiniteautomation.com/network-configuration/" rel="nofollow ugc">USB Utility</a> to check your configuration or set the static IP again.  What do you mean by the "Old way"?  Did you edit the /etc/networks/interfaces file?</p>
<p dir="auto">You can also plug in a monitor and keyboard to check the network settings.</p>
]]></description><link>https://forum.mango-os.com/post/15100</link><guid isPermaLink="true">https://forum.mango-os.com/post/15100</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 27 Jul 2017 23:22:17 GMT</pubDate></item></channel></rss>
