<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango Es startup inrush @ 24Vdc]]></title><description><![CDATA[<p dir="auto">Hi,</p>
<p dir="auto">The mango unit is tripping my 24vdc 200W power supply on startup due to inrush I assume. Do you have an idea of what the inrush current is at 24Vdc?</p>
]]></description><link>https://forum.mango-os.com/topic/2872/mango-es-startup-inrush-24vdc</link><generator>RSS for Node</generator><lastBuildDate>Fri, 12 Jun 2026 11:35:27 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2872.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 27 Jul 2017 06:53:36 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango Es startup inrush @ 24Vdc on Thu, 27 Jul 2017 23:42:33 GMT]]></title><description><![CDATA[<p dir="auto">Power supply is probably the wrong word, it's 48/24v dcdc converter. Once the unit is up and running the unit only draws &lt;1Amp and everything works fine. Even If I put it on a small 9Ahr battery it will drop the voltage during startup 1-2Volts on the battery.<br />
I've tried a 300W converter of the same brand and next i'll try a different brand.<br />
Is there a different onboard psu for the AC model vs. dc model or is it the same unit with a different plug?</p>
]]></description><link>https://forum.mango-os.com/post/15101</link><guid isPermaLink="true">https://forum.mango-os.com/post/15101</guid><dc:creator><![CDATA[shaner]]></dc:creator><pubDate>Thu, 27 Jul 2017 23:42:33 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Es startup inrush @ 24Vdc on Thu, 27 Jul 2017 15:25:50 GMT]]></title><description><![CDATA[<p dir="auto">Sounds like a busted PSU to me as well.</p>
]]></description><link>https://forum.mango-os.com/post/15091</link><guid isPermaLink="true">https://forum.mango-os.com/post/15091</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Thu, 27 Jul 2017 15:25:50 GMT</pubDate></item><item><title><![CDATA[Reply to Mango Es startup inrush @ 24Vdc on Thu, 27 Jul 2017 15:19:54 GMT]]></title><description><![CDATA[<p dir="auto">At 24vdc the MangoES shouldn't pull more than an amp.  There would need to be a pretty serious issue if it's tripping a 200 watt power supply and I think you would see smoke.  I would test the power supply or try a different one.</p>
]]></description><link>https://forum.mango-os.com/post/15090</link><guid isPermaLink="true">https://forum.mango-os.com/post/15090</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Thu, 27 Jul 2017 15:19:54 GMT</pubDate></item></channel></rss>
