<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Data polling on the hour.]]></title><description><![CDATA[<p dir="auto">HI there,</p>
<p dir="auto">I'm currently working with a few bacnet devices and my points are on various intervals of 5 mins and 15 mins. Is there any way to start the polling on a whole 15m so all of my time stamps are nice?</p>
<p dir="auto">I want to be able to look at the first 15m of the hour and so on but the polling starting point just depends on when I turn the data source on.</p>
<p dir="auto">ie.<br />
14:00:00, data<br />
14:15:00, data</p>
<p dir="auto">rather than<br />
14:02:35, data<br />
14:17:35, data</p>
<p dir="auto">Thanks!<br />
Conor</p>
]]></description><link>https://forum.mango-os.com/topic/2836/data-polling-on-the-hour</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 04:41:39 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2836.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Jul 2017 12:02:56 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Data polling on the hour. on Sat, 08 Jul 2017 19:06:50 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> Thanks Philip, much appreciated.</p>
]]></description><link>https://forum.mango-os.com/post/14846</link><guid isPermaLink="true">https://forum.mango-os.com/post/14846</guid><dc:creator><![CDATA[cbyrne]]></dc:creator><pubDate>Sat, 08 Jul 2017 19:06:50 GMT</pubDate></item><item><title><![CDATA[Reply to Data polling on the hour. on Mon, 03 Jul 2017 15:20:36 GMT]]></title><description><![CDATA[<p dir="auto">Hi Conor,</p>
<p dir="auto">We've looked at adding cron patterns for all data sources, that's probably the right solution for what you desire ultimately, but it isn't integrated yet.</p>
<p dir="auto">But, it is of course possible. I used a Meta point, a virtual data source, an event detector and two event handlers to achieve this.</p>
<p dir="auto">Here's my meta point's script:</p>
<pre><code>var now = new Date();
if( now.getSeconds() === 0 &amp;&amp; !RuntimeManager.isDataSourceEnabled("vrt") ) {
    RuntimeManager.enableDataSource("vrt");
    return 1;
if( startup.value === true ) {
    RuntimeManager.disableDataSource("vrt");
    return 2;
return my.value;
<p dir="auto">You will need to change the data source xid and the condition for if the time is right (you're probably looking for <code>now.getMinutes() % 15 === 0 &amp;&amp; now.getSeconds() === 0</code>).</p>
<p dir="auto">startup is the variable name for the Binary point on our virtual data source, which is set to true by one of our event handlers, created on /event_handlers.shtm on the event for system startup. The startup point needs to update the context. We'll also put a change event detector on our meta point (on its edit page) so that we can set startup back to false with our second event handler. My data source was on the cron <code>0 * * * * ?</code> yours is likely <code>0 0/15 * * * ?</code>.</p>
<p dir="auto">I set the event level for the change event detector to do not log, my binary startup point to have a "no change" change type, and the meta point not to log its value. Here is the JSON from the setup I created testing this:</p>
<pre><code>{
   "dataSources":[
         "xid":"DS_8ecfb519-7d54-4e62-adef-b56f3025faa4",
         "name":"Starter",
         "enabled":true,
         "type":"META",
         "alarmLevels":{
            "SCRIPT_ERROR":"URGENT",
            "CONTEXT_POINT_DISABLED":"URGENT",
            "RESULT_TYPE_ERROR":"URGENT"
         "purgeType":"YEARS",
         "editPermission":"",
         "purgeOverride":false,
         "purgePeriod":1
         "xid":"DS_2df1e33a-6b2f-4341-a8e9-6509a3422563",
         "name":"SystemStartup",
         "enabled":true,
         "type":"VIRTUAL",
         "alarmLevels":{
            "POLL_ABORTED":"URGENT"
         "updatePeriodType":"HOURS",
         "polling":false,
         "updatePeriods":320000,
         "purgePeriod":1
         "xid":"vrt",
         "name":"vrt",
         "enabled":true,
         "type":"VIRTUAL",
         "alarmLevels":{
            "POLL_ABORTED":"CRITICAL"
         "updatePeriodType":"SECONDS",
         "polling":true,
         "updatePeriods":60,
         "purgePeriod":1
   "dataPoints":[
         "xid":"DP_72f9b542-b663-4b87-b7b8-d33a7b4e4c26",
         "name":"test",
         "enabled":true,
         "loggingType":"INTERVAL",
         "pointLocator":{
            "dataType":"NUMERIC",
            "changeType":{
               "type":"BROWNIAN",
               "max":100.0,
               "maxChange":10.0,
               "min":0.0,
               "startValue":"50"
            "settable":false
         "eventDetectors":[
         "plotType":"SPLINE",
         "rollup":"NONE",
         "unit":"",
         "templateXid":"Numeric_Default",
         "chartColour":"",
         "chartRenderer":{
            "type":"IMAGE",
            "timePeriodType":"DAYS",
            "numberOfPeriods":1
         "dataSourceXid":"vrt",
         "defaultCacheSize":1,
         "deviceName":"vrt",
         "discardExtremeValues":false,
         "intervalLoggingPeriod":1,
         "purgePeriod":1,
         "readPermission":"",
         "setPermission":"",
         "textRenderer":{
            "type":"ANALOG",
            "useUnitAsSuffix":true,
            "unit":"",
            "renderedUnit":"",
            "format":"0.00"
         "tolerance":0.0
         "xid":"DP_40ab249a-9ab8-4fb9-ba7f-d26f05010eb2",
         "name":"Start Vrt",
         "enabled":true,
         "loggingType":"NONE",
         "pointLocator":{
            "dataType":"MULTISTATE",
            "updateEvent":"CRON",
            "context":[
                  "varName":"startup",
                  "dataPointXid":"DP_a560ce1f-24c7-4749-ad3c-a7428b0184cc",
                  "updateContext":true
            "logLevel":"NONE",
            "executionDelaySeconds":0,
            "script":"var now = new Date();\r\nif( now.getSeconds() === 0 &amp;&amp; !RuntimeManager.isDataSourceEnabled(\"vrt\") ) {\r\n    RuntimeManager.enableDataSource(\"vrt\");\r\n    return 1;\r\n}\r\nif( startup.value === true ) {\r\n    RuntimeManager.disableDataSource(\"vrt\");\r\n    return 2;\r\n}\r\nreturn my.value;",
            "scriptPermissions":{
               "customPermissions":"",
               "dataPointReadPermissions":"superadmin",
               "dataPointSetPermissions":"superadmin",
               "dataSourcePermissions":"superadmin"
            "settable":false,
            "updateCronPattern":"0 * * * * ?"
         "eventDetectors":[
               "type":"POINT_CHANGE",
               "sourceType":"DATA_POINT",
               "xid":"ED_f7fc9634-0326-44b3-9053-07334205a73d",
               "alias":"",
               "alarmLevel":"DO_NOT_LOG"
         "plotType":"STEP",
         "rollup":"NONE",
         "unit":"",
         "chartColour":"",
         "chartRenderer":{
            "type":"TABLE",
            "limit":10
         "dataSourceXid":"DS_8ecfb519-7d54-4e62-adef-b56f3025faa4",
         "deviceName":"Starter",
         "intervalLoggingPeriod":15,
         "purgePeriod":1,
         "setPermission":"",
         "textRenderer":{
            "type":"PLAIN",
            "unit":"",
            "renderedUnit":"",
            "suffix":""
         "tolerance":0.0
         "xid":"DP_a560ce1f-24c7-4749-ad3c-a7428b0184cc",
         "name":"Started",
         "enabled":true,
         "loggingType":"ON_CHANGE",
         "pointLocator":{
            "dataType":"BINARY",
            "changeType":{
               "type":"NO_CHANGE",
               "startValue":"false"
            "settable":true
         "eventDetectors":[
         "plotType":"STEP",
         "rollup":"NONE",
         "unit":"",
         "templateXid":"Binary_Default",
         "chartColour":"",
         "chartRenderer":{
            "type":"TABLE",
            "limit":10
         "dataSourceXid":"DS_2df1e33a-6b2f-4341-a8e9-6509a3422563",
         "deviceName":"SystemStartup",
         "purgePeriod":1,
         "setPermission":"",
         "textRenderer":{
            "type":"BINARY",
            "oneColour":"black",
            "oneLabel":"one",
            "zeroColour":"blue",
            "zeroLabel":"zero"
         "tolerance":0.0
   "eventHandlers":[
         "eventType":{
            "sourceType":"SYSTEM",
            "systemType":"SYSTEM_STARTUP"
         "xid":"EH_b7ce0223-7bf9-48ea-8383-a5b7c812e400",
         "handlerType":"SET_POINT",
         "targetPointId":"DP_a560ce1f-24c7-4749-ad3c-a7428b0184cc",
         "activeAction":"STATIC_VALUE",
         "activeValueToSet":"true",
         "inactiveAction":"NONE",
         "alias":"",
         "disabled":false
         "eventType":{
            "dataPointXID":"DP_40ab249a-9ab8-4fb9-ba7f-d26f05010eb2",
            "detectorXID":"ED_f7fc9634-0326-44b3-9053-07334205a73d"
         "xid":"EH_3d59cbd8-d84a-4b69-a554-7b53479c895b",
         "activeValueToSet":"",
         "alias":"",
         "disabled":false
<p dir="auto">I should note that this solution is imperfect. If one were to disable and re-enable the data source manually, the polling would be off. It would be possible to use one of the points from the data source to trigger the meta point and check the polling, but I'm not sure it would be wise and worthwhile. After all, if one noticed polling is off through someone doing that, you can just set the point set true at startup to true again.</p>
]]></description><link>https://forum.mango-os.com/post/14787</link><guid isPermaLink="true">https://forum.mango-os.com/post/14787</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 03 Jul 2017 15:20:36 GMT</pubDate></item></channel></rss>
