<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Gigabit Ethernet fix speed and full-duplex]]></title><description><![CDATA[<p dir="auto">Hi ,<br />
It is any way to setup the Ethernet port speed and communications mode ?<br />
I like to have the speed to be setup to 100Mbps Full.<br />
Were I can do this ?<br />
Thanks<br />
Mircea</p>
]]></description><link>https://forum.mango-os.com/topic/2823/gigabit-ethernet-fix-speed-and-full-duplex</link><generator>RSS for Node</generator><lastBuildDate>Tue, 10 Nov 2026 09:05:43 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2823.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Jun 2017 15:10:28 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Gigabit Ethernet fix speed and full-duplex on Wed, 28 Jun 2017 02:16:25 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mircea,</p>
<p dir="auto">Is this for a MangoES? If so, the following link may help: <a href="https://wiki.debian.org/NetworkConfiguration#Setting_the_speed_and_duplex" rel="nofollow ugc">https://wiki.debian.org/NetworkConfiguration#Setting_the_speed_and_duplex</a></p>
<p dir="auto">As noted in that link, do be careful (particularly if this device is remote!) that you do not inadvertently lock yourself out of the device. Unstable link speeds can often be symptomatic of bad cabling, faulty termination, or intermittent noise and identifying and addressing the root cause may be called for.</p>
<p dir="auto">One other thing to note is that many switches and other bits of network gear allow you to set a 'manual' speed by effectively disabling some rates, eg. you could disable Gigabit on the switch port and auto-negotiation would max out at 100Base-TX.</p>
]]></description><link>https://forum.mango-os.com/post/14753</link><guid isPermaLink="true">https://forum.mango-os.com/post/14753</guid><dc:creator><![CDATA[jeremyh]]></dc:creator><pubDate>Wed, 28 Jun 2017 02:16:25 GMT</pubDate></item><item><title><![CDATA[Reply to Gigabit Ethernet fix speed and full-duplex on Mon, 26 Jun 2017 20:52:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi Mircea,</p>
<p dir="auto">I don't have any experience with what you're asking about. I was under the impression the speed of most Ethernet systems is negotiated actively since various components (like using multiple hubs) can introduce subtle electrical effects that create problems as you go full speed. Googling suggested there's a program called 'ethtool' one can explicitly use for the purpose of recommending a speed to the adapter.</p>
<p dir="auto"><a href="https://en.wikipedia.org/wiki/Autonegotiation" rel="nofollow ugc">https://en.wikipedia.org/wiki/Autonegotiation</a></p>
]]></description><link>https://forum.mango-os.com/post/14738</link><guid isPermaLink="true">https://forum.mango-os.com/post/14738</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 26 Jun 2017 20:52:07 GMT</pubDate></item></channel></rss>
