<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Persistent TCP won&#x27;t reconnect after restart]]></title><description><![CDATA[<p dir="auto">Been connected to Persistent TCP source for over 30 hours on port 97 then the target system became unavailable during a restart and now the connection will not  re-establish.. Oddly if I delete this data source and recreate it on another port it starts up again no problem so its not connectivity issues.<br />
Additionally our second ES has active connection on another pipe the entire time.</p>
<p dir="auto">Is there some way to reset the pipe to a clean state? as if it were just recreated?</p>
]]></description><link>https://forum.mango-os.com/topic/2795/persistent-tcp-won-t-reconnect-after-restart</link><generator>RSS for Node</generator><lastBuildDate>Tue, 19 May 2026 12:44:01 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2795.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 02 Jun 2017 01:24:42 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Persistent TCP won&#x27;t reconnect after restart on Fri, 09 Jun 2017 14:09:46 GMT]]></title><description><![CDATA[<p dir="auto">Phil this happened in 2.8.8 and also in 3.02 our current Version .  I did experiment with the broken pipe issue about not automatically restoring connection after Mango restart with no definitive answer.  If I modify the port # the pipe starts again automatically without Mango restart.  If I reboot the entire workstation, Mango sometimes re-established connections without re-configuring the port.  However more often than not a failure to bind alert flashes on the receiver and the connection does not re-establish.</p>
<p dir="auto">We installed V3 now to move forward and rebuilt our database without that Java lock issue and hopefully it will be ancient history :)</p>
]]></description><link>https://forum.mango-os.com/post/14631</link><guid isPermaLink="true">https://forum.mango-os.com/post/14631</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Fri, 09 Jun 2017 14:09:46 GMT</pubDate></item><item><title><![CDATA[Reply to Persistent TCP won&#x27;t reconnect after restart on Sat, 03 Jun 2017 00:47:36 GMT]]></title><description><![CDATA[<p dir="auto">It is most likely that a point is not being created or updated properly, throwing and exception and there's the problem. That should be in the logs. Maybe it's creating a point with an XID that already exists on the target system.</p>
<p dir="auto">You can experiment with creating a simple point and just publishing one point. Then the search is on for the offending point(s). Check the logs.</p>
]]></description><link>https://forum.mango-os.com/post/14606</link><guid isPermaLink="true">https://forum.mango-os.com/post/14606</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Sat, 03 Jun 2017 00:47:36 GMT</pubDate></item><item><title><![CDATA[Reply to Persistent TCP won&#x27;t reconnect after restart on Fri, 02 Jun 2017 20:53:21 GMT]]></title><description><![CDATA[<p dir="auto">So that is the error you're getting, "Broken pipe"?</p>
<p dir="auto">If so, you could experiment with lowering the settings for maximum values per packet (if some server in the middle is upset). Does a new connection publish/receive data for a while, and then fail?</p>
]]></description><link>https://forum.mango-os.com/post/14605</link><guid isPermaLink="true">https://forum.mango-os.com/post/14605</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 02 Jun 2017 20:53:21 GMT</pubDate></item><item><title><![CDATA[Reply to Persistent TCP won&#x27;t reconnect after restart on Fri, 02 Jun 2017 20:29:36 GMT]]></title><description><![CDATA[<p dir="auto">Ok I am sending it to a log now I will look into this further over the weekend and hopefully I'll have a clue what is happening.  It's like only a new connection successfully connects and then it worn't reconnect after the pipe is broken. Before the pipe gets broken or the publisher is disabled it reconnects fine.   I wonder could it be related to my configuration of the Linux box because this behaviour does not happen on our cloud server.</p>
<p dir="auto">I did not run the install script sudo update-rc.d mango defaults.  because it could not find the file.  not sure relevance if any.</p>
]]></description><link>https://forum.mango-os.com/post/14604</link><guid isPermaLink="true">https://forum.mango-os.com/post/14604</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Fri, 02 Jun 2017 20:29:36 GMT</pubDate></item><item><title><![CDATA[Reply to Persistent TCP won&#x27;t reconnect after restart on Fri, 02 Jun 2017 17:08:05 GMT]]></title><description><![CDATA[<p dir="auto">Is it possible there are newer versions of modules and such available? Have you considered enabling logging to see what is occurring?</p>
]]></description><link>https://forum.mango-os.com/post/14599</link><guid isPermaLink="true">https://forum.mango-os.com/post/14599</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 02 Jun 2017 17:08:05 GMT</pubDate></item></channel></rss>
