<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No space left on device &#x2F;&#x2F; (org.tinytsdb.TinyTSDBException: java.io.IOException: No space left on device)]]></title><description><![CDATA[<p dir="auto">Hi together,<br />
we had a deactivated point on the MangoES. After reboot the server did not start. The logs are attached. We have enough space on the disk.</p>
<p dir="auto"><img src="https://camo.nodebb.org/65225c430a4f302874170a0b5e1606afe242f416?url=https%3A%2F%2Fi.imgur.com%2Fo0SgL6e.png" alt="0_1496156952863_upload-29409c49-4fca-405b-940e-64e1d8b77bf2" class=" img-fluid img-markdown" /></p>
<p dir="auto">Some suggestions?</p>
<p dir="auto">Regards, Sasa</p>
<p dir="auto">[0_1496157253251_ma.log](Uploading 100%)</p>
]]></description><link>https://forum.mango-os.com/topic/2789/no-space-left-on-device-org-tinytsdb-tinytsdbexception-java-io-ioexception-no-space-left-on-device</link><generator>RSS for Node</generator><lastBuildDate>Sun, 12 Jul 2026 02:27:26 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2789.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 30 May 2017 15:14:40 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No space left on device &#x2F;&#x2F; (org.tinytsdb.TinyTSDBException: java.io.IOException: No space left on device) on Tue, 30 May 2017 17:02:50 GMT]]></title><description><![CDATA[<p dir="auto">No problem and glad to hear you got it resolved!</p>
]]></description><link>https://forum.mango-os.com/post/14566</link><guid isPermaLink="true">https://forum.mango-os.com/post/14566</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 30 May 2017 17:02:50 GMT</pubDate></item><item><title><![CDATA[Reply to No space left on device &#x2F;&#x2F; (org.tinytsdb.TinyTSDBException: java.io.IOException: No space left on device) on Tue, 30 May 2017 16:48:20 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a></p>
<p dir="auto">That´s it - solved!</p>
<p dir="auto">Thx &amp; Cheers<br />
Sasa</p>
]]></description><link>https://forum.mango-os.com/post/14565</link><guid isPermaLink="true">https://forum.mango-os.com/post/14565</guid><dc:creator><![CDATA[sasa]]></dc:creator><pubDate>Tue, 30 May 2017 16:48:20 GMT</pubDate></item><item><title><![CDATA[Reply to No space left on device &#x2F;&#x2F; (org.tinytsdb.TinyTSDBException: java.io.IOException: No space left on device) on Tue, 30 May 2017 16:15:27 GMT]]></title><description><![CDATA[<p dir="auto">Yeah if it's the same problem you can just delete everything in /var/spool/exim4/input and it should free up a hundred thousand or more. You can just <code>find /var/spool/exim4/input -type f -delete</code></p>
]]></description><link>https://forum.mango-os.com/post/14563</link><guid isPermaLink="true">https://forum.mango-os.com/post/14563</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 30 May 2017 16:15:27 GMT</pubDate></item><item><title><![CDATA[Reply to No space left on device &#x2F;&#x2F; (org.tinytsdb.TinyTSDBException: java.io.IOException: No space left on device) on Tue, 30 May 2017 16:00:27 GMT]]></title><description><![CDATA[<p dir="auto">Thank you Phil,</p>
<p dir="auto">here is the output and it is 100% used, right!</p>
<p dir="auto"><img src="https://camo.nodebb.org/dbe97e6dbbc11250fcf49cdb100a3f064776eccf?url=https%3A%2F%2Fi.imgur.com%2FPneu8AC.png" alt="0_1496159904254_upload-40b86bf8-a309-440c-93ed-b155b86f7183" class=" img-fluid img-markdown" /></p>
<p dir="auto">Should I remove all from /var/spool/exim4/input? What exact redirect do you recommend?</p>
]]></description><link>https://forum.mango-os.com/post/14561</link><guid isPermaLink="true">https://forum.mango-os.com/post/14561</guid><dc:creator><![CDATA[sasa]]></dc:creator><pubDate>Tue, 30 May 2017 16:00:27 GMT</pubDate></item><item><title><![CDATA[Reply to No space left on device &#x2F;&#x2F; (org.tinytsdb.TinyTSDBException: java.io.IOException: No space left on device) on Tue, 30 May 2017 15:31:53 GMT]]></title><description><![CDATA[<p dir="auto">Hi Sasa,</p>
<p dir="auto">Can you check <code>df -i</code> to see if you have inodes remaining?</p>
<p dir="auto">Here is a thread where someone ran out of inodes: <a href="https://forum.infiniteautomation.com/topic/2556/mango-not-starting-disk-is-full" rel="nofollow ugc">https://forum.infiniteautomation.com/topic/2556/mango-not-starting-disk-is-full</a></p>
<p dir="auto">The issue was traced to a cron script creating a lot of files in /var/spool/exim4/input and could be fixed by updating /etc/cron.d/system-info to redirect all output like <code>&gt;/dev/null 2&gt;&amp;1</code></p>
]]></description><link>https://forum.mango-os.com/post/14560</link><guid isPermaLink="true">https://forum.mango-os.com/post/14560</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 30 May 2017 15:31:53 GMT</pubDate></item><item><title><![CDATA[Reply to No space left on device &#x2F;&#x2F; (org.tinytsdb.TinyTSDBException: java.io.IOException: No space left on device) on Tue, 30 May 2017 15:22:01 GMT]]></title><description><![CDATA[<p dir="auto">Sorry for the title. It was an older issue with this exception, but it seems not affect the current error. Here is still the "tsdb" exception:</p>
<pre><code>ERROR 2017-05-13 11:58:46,511 (com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehind.execute:110) - Error saving point value.
	at org.tinytsdb.impl.TinyTSDBImpl.write(TinyTSDBImpl.java:309)
	at com.infiniteautomation.nosql.MangoNoSqlPointValueDao.savePointValueSync(MangoNoSqlPointValueDao.java:65)
	at com.infiniteautomation.nosql.MangoNoSqlBatchWriteBehind.execute(MangoNoSqlBatchWriteBehind.java:96)
	at com.serotonin.m2m2.rt.maint.BackgroundProcessing$1.run(BackgroundProcessing.java:54)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Caused by: java.io.IOException: No space left on device
	at java.io.UnixFileSystem.createFileExclusively(Native Method)
	at java.io.File.createNewFile(File.java:1012)
	at org.tinytsdb.impl.Shard.ensureDirty(Shard.java:325)
	at org.tinytsdb.impl.Series.write(Series.java:160)
	at org.tinytsdb.impl.Series.write(Series.java:145)
	at org.tinytsdb.impl.TinyTSDBImpl.write(TinyTSDBImpl.java:301)
	... 6 more
]]></description><link>https://forum.mango-os.com/post/14558</link><guid isPermaLink="true">https://forum.mango-os.com/post/14558</guid><dc:creator><![CDATA[sasa]]></dc:creator><pubDate>Tue, 30 May 2017 15:22:01 GMT</pubDate></item><item><title><![CDATA[Reply to No space left on device &#x2F;&#x2F; (org.tinytsdb.TinyTSDBException: java.io.IOException: No space left on device) on Tue, 30 May 2017 15:18:08 GMT]]></title><description><![CDATA[<pre><code>INFO  2017-05-30 16:47:35,858 (com.serotonin.m2m2.Main.main:82) - Starting Mango 2.7.12 with Schema Version: 12
INFO  2017-05-30 16:47:37,464 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'sqlds', v1.6.2 by Infinite Automation Software
INFO  2017-05-30 16:47:37,546 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'TCPIP', v1.1.5 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,558 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'asciiFile', v1.2.1 by Infinite Automation
INFO  2017-05-30 16:47:37,570 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'sqlConsole', v1.5.1 by Infinite Automation Software
INFO  2017-05-30 16:47:37,583 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'galil', v1.5.1 by Infinite Automation Software
INFO  2017-05-30 16:47:37,598 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'sstGlobalScripts', v1.5.1 by Infinite Automation Software
INFO  2017-05-30 16:47:37,610 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'mbus', v1.1.3 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,629 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'log4jDS', v1.1.2 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,640 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'persistent', v1.6.5 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,652 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'vmstat', v1.5.1 by Infinite Automation Software
INFO  2017-05-30 16:47:37,663 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'mangoApi', v1.1.7 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,674 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'pointLinks', v1.5.5 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,687 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'log4JReset', v1.1.1 by Infinite Automation Software
INFO  2017-05-30 16:47:37,691 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'sstTheme', v1.1.1 by Infinite Automation Software
INFO  2017-05-30 16:47:37,698 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'jmxds', v1.5.1 by Infinite Automation Software
INFO  2017-05-30 16:47:37,715 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'twilio', v1.1.2 by (unknown vendor)
INFO  2017-05-30 16:47:37,731 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'mangoESConfiguration', v1.1.7 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,746 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'meta', v2.2.4 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,759 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'excelReports', v1.0.6 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,782 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'snmp', v1.5.3 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,793 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'http', v1.5.2 by Infinite Automation Software
INFO  2017-05-30 16:47:37,810 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'controlcore', v1.1.1 by Infinite Automation
INFO  2017-05-30 16:47:37,821 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'graphicalViews', v1.6.7 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,869 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'scripting', v1.1.2 by Infinite Automation Software
INFO  2017-05-30 16:47:37,882 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'watchlists', v1.7.4 by Infinite Automation Software
INFO  2017-05-30 16:47:37,904 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'dataPointDetailsView', v1.0.5 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,917 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'modbus', v1.6.5 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:37,933 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'dashboards', v3.2.2 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:38,175 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'onewire', v1.5.1 by Infinite Automation Software
INFO  2017-05-30 16:47:38,196 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'virtualDS', v1.5.2 by Infinite Automation Software
INFO  2017-05-30 16:47:38,208 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'dataFile', v1.1.1 by Infinite Automation
INFO  2017-05-30 16:47:38,230 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'ssh', v1.1.1 by Infinite Automation
INFO  2017-05-30 16:47:38,242 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'dnp3', v1.6.2 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:38,254 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'dataImport', v1.4.1 by Infinite Automation Software
INFO  2017-05-30 16:47:38,265 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'pop3', v1.5.1 by Infinite Automation Software
INFO  2017-05-30 16:47:38,276 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'jspViews', v2.1.1 by Infinite Automation Software
INFO  2017-05-30 16:47:38,292 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'templateConfig', v1.0.8 by Infinite Automation Software
INFO  2017-05-30 16:47:38,310 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'BACnet', v2.2.4 by Infinite Automation Software
INFO  2017-05-30 16:47:38,325 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'pid', v1.1.1 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:38,339 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'zwave', v1.1.2 by Infinite Automation
INFO  2017-05-30 16:47:38,378 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'egauge', v1.1.1 by Infinite Automation
INFO  2017-05-30 16:47:38,389 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'openv4j', v1.1.2 by aploese
INFO  2017-05-30 16:47:38,393 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'scheduledEvents', v1.5.2 by (unknown vendor)
INFO  2017-05-30 16:47:38,404 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'loggingConsole', v1.1.1 by Infinite Automation
INFO  2017-05-30 16:47:38,415 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'sstGraphics', v1.1.1 by Infinite Automation Software
INFO  2017-05-30 16:47:38,452 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'mangoNoSqlDatabase', v1.2.3 by Infinite Automation Software
INFO  2017-05-30 16:47:38,465 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'reports', v2.2.3 by Infinite Automation Systems Inc.
INFO  2017-05-30 16:47:38,479 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'maintenanceEvents', v1.5.1 by Infinite Automation Software
INFO  2017-05-30 16:47:38,491 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'serial', v1.2.1 by Infinite Automation
INFO  2017-05-30 16:47:38,503 (com.serotonin.m2m2.Main.loadModules:417) - Loading module 'internal', v1.5.3 by Infinite Automation Software
INFO  2017-05-30 16:47:41,325 (com.infiniteautomation.mangoApi.MangoApiReloadingProperties.checkForReload:146) - (mangoApiHeaders) Found updated file at /opt/mango/web/modules/mangoApi/classes/mangoApiHeaders.properties. Reloading properties
INFO  2017-05-30 16:47:41,714 (com.serotonin.m2m2.Lifecycle.loadLic:464) - Checking license...
INFO  2017-05-30 16:47:42,019 (com.serotonin.m2m2.db.H2Proxy.initializeImpl:42) - Initializing H2 connection manager
FATAL 2017-05-30 16:47:44,554 (com.serotonin.m2m2.db.DatabaseProxy.initialize:190) - Unable to connect to database of type H2
org.springframework.jdbc.CannotGetJdbcConnectionException: Could not get JDBC Connection; nested exception is org.h2.jdbc.JdbcSQLException: Error opening database: "Could not save properties /opt/mango/databases/mah2.lock.db" [8000-181]
	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:80)
	at org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:615)
	at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:680)
	at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:712)
	at org.springframework.jdbc.core.JdbcTemplate.query(JdbcTemplate.java:722)
	at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:39)
	at com.serotonin.db.spring.ExtendedJdbcTemplate.queryForObject(ExtendedJdbcTemplate.java:63)
	at com.serotonin.m2m2.db.H2Proxy.tableExists(H2Proxy.java:244)
	at com.serotonin.m2m2.db.DatabaseProxy.newDatabaseCheck(DatabaseProxy.java:204)
	at com.serotonin.m2m2.db.DatabaseProxy.initialize(DatabaseProxy.java:106)
	at com.serotonin.m2m2.Lifecycle.databaseInitialize(Lifecycle.java:602)
	at com.serotonin.m2m2.Lifecycle.initialize(Lifecycle.java:280)
	at com.serotonin.m2m2.Main.main(Main.java:116)
Caused by: org.h2.jdbc.JdbcSQLException: Error opening database: "Could not save properties /opt/mango/databases/mah2.lock.db" [8000-181]
	at org.h2.message.DbException.getJdbcSQLException(DbException.java:345)
	at org.h2.message.DbException.get(DbException.java:168)
	at org.h2.store.FileLock.getExceptionFatal(FileLock.java:456)
	at org.h2.store.FileLock.save(FileLock.java:225)
	at org.h2.store.FileLock.lockFile(FileLock.java:352)
	at org.h2.store.FileLock.lock(FileLock.java:135)
	at org.h2.engine.Database.open(Database.java:631)
	at org.h2.engine.Database.openDatabase(Database.java:266)
	at org.h2.engine.Database.&lt;init&gt;(Database.java:260)
	at org.h2.engine.Engine.openSession(Engine.java:60)
	at org.h2.engine.Engine.openSession(Engine.java:167)
	at org.h2.engine.Engine.createSessionAndValidate(Engine.java:145)
	at org.h2.engine.Engine.createSession(Engine.java:128)
	at org.h2.engine.Engine.createSession(Engine.java:26)
	at org.h2.engine.SessionRemote.connectEmbeddedOrServer(SessionRemote.java:347)
	at org.h2.jdbc.JdbcConnection.&lt;init&gt;(JdbcConnection.java:108)
	at org.h2.jdbc.JdbcConnection.&lt;init&gt;(JdbcConnection.java:92)
	at org.h2.Driver.connect(Driver.java:72)
	at org.h2.jdbcx.JdbcDataSource.getJdbcConnection(JdbcDataSource.java:190)
	at org.h2.jdbcx.JdbcDataSource.getXAConnection(JdbcDataSource.java:353)
	at org.h2.jdbcx.JdbcDataSource.getPooledConnection(JdbcDataSource.java:385)
	at org.h2.jdbcx.JdbcConnectionPool.getConnectionNow(JdbcConnectionPool.java:227)
	at org.h2.jdbcx.JdbcConnectionPool.getConnection(JdbcConnectionPool.java:199)
	at org.springframework.jdbc.datasource.DataSourceUtils.doGetConnection(DataSourceUtils.java:111)
	at org.springframework.jdbc.datasource.DataSourceUtils.getConnection(DataSourceUtils.java:77)
	... 12 more
Caused by: java.io.FileNotFoundException: /opt/mango/databases/mah2.lock.db (No space left on device)
	at java.io.FileOutputStream.open(Native Method)
	at java.io.FileOutputStream.&lt;init&gt;(FileOutputStream.java:213)
	at java.io.FileOutputStream.&lt;init&gt;(FileOutputStream.java:101)
	at org.h2.store.fs.FilePathDisk.newOutputStream(FilePathDisk.java:290)
	at org.h2.store.fs.FileUtils.newOutputStream(FileUtils.java:233)
	at org.h2.store.FileLock.save(FileLock.java:213)
	... 33 more
ERROR 2017-05-30 16:47:44,562 (com.serotonin.m2m2.Main.main:120) - Error during initialization
	... 12 more
	... 33 more
INFO  2017-05-30 16:47:44,565 (com.serotonin.m2m2.Lifecycle.terminate:344) - Mango Lifecycle terminating...
]]></description><link>https://forum.mango-os.com/post/14557</link><guid isPermaLink="true">https://forum.mango-os.com/post/14557</guid><dc:creator><![CDATA[sasa]]></dc:creator><pubDate>Tue, 30 May 2017 15:18:08 GMT</pubDate></item></channel></rss>
