<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Export archive file to csv]]></title><description><![CDATA[<p dir="auto">Hi,  is it possible to set up the MangoES to export data as a csv/excel file, ideally on a separate local drive?  Ideally this would be a daily or monthly file saved to a specific location, where the site engineer can access it if required.</p>
]]></description><link>https://forum.mango-os.com/topic/2774/export-archive-file-to-csv</link><generator>RSS for Node</generator><lastBuildDate>Tue, 18 Aug 2026 01:59:31 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2774.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 21 May 2017 22:43:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Export archive file to csv on Mon, 22 May 2017 15:55:06 GMT]]></title><description><![CDATA[<p dir="auto">I'm not sure if Samba is installed but you could probably install it if isn't.</p>
]]></description><link>https://forum.mango-os.com/post/14482</link><guid isPermaLink="true">https://forum.mango-os.com/post/14482</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 22 May 2017 15:55:06 GMT</pubDate></item><item><title><![CDATA[Reply to Export archive file to csv on Mon, 22 May 2017 03:53:15 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/joelhaggar" aria-label="Profile: JoelHaggar">@<bdi>JoelHaggar</bdi></a> said in <a href="/post/14476">Export archive file to csv</a>:</p>
<p dir="auto">You can use the Excel reports module to generate an Excel file on a schedule.  The files are stored on the local system in /opt/mango/web/modules/excelReports/web/report-data<br />
You could set up a cron job to copy all these files to your location of choice.</p>
<p dir="auto">We can probably make that work.  Just one question - does the Mango have Samba (installed and configured), and therefore set up a shared directory.  This way we can 'pull' from Windows?</p>
]]></description><link>https://forum.mango-os.com/post/14479</link><guid isPermaLink="true">https://forum.mango-os.com/post/14479</guid><dc:creator><![CDATA[tom_buzink]]></dc:creator><pubDate>Mon, 22 May 2017 03:53:15 GMT</pubDate></item><item><title><![CDATA[Reply to Export archive file to csv on Mon, 22 May 2017 03:32:53 GMT]]></title><description><![CDATA[<p dir="auto">You could set up a ftp process to push the file to a windows machine.  The file names look like: Nov_13__2016_9_00_00_AM_Sync_Time_Report.xlsx</p>
]]></description><link>https://forum.mango-os.com/post/14478</link><guid isPermaLink="true">https://forum.mango-os.com/post/14478</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 22 May 2017 03:32:53 GMT</pubDate></item><item><title><![CDATA[Reply to Export archive file to csv on Mon, 22 May 2017 03:26:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi Joel,</p>
<p dir="auto">Thanks for your reply.  That looks like being a potential solution for us.  Is cron able to copy the files to a Windows machine?  And does the Excel report allow data / time to be appended to the file name?</p>
]]></description><link>https://forum.mango-os.com/post/14477</link><guid isPermaLink="true">https://forum.mango-os.com/post/14477</guid><dc:creator><![CDATA[tom_buzink]]></dc:creator><pubDate>Mon, 22 May 2017 03:26:00 GMT</pubDate></item><item><title><![CDATA[Reply to Export archive file to csv on Mon, 22 May 2017 00:18:30 GMT]]></title><description><![CDATA[<p dir="auto">You can use the Excel reports module to generate an Excel file on a schedule.  The files are stored on the local system in /opt/mango/web/modules/excelReports/web/report-data</p>
<p dir="auto">You could set up a cron job to copy all these files to your location of choice.</p>
]]></description><link>https://forum.mango-os.com/post/14476</link><guid isPermaLink="true">https://forum.mango-os.com/post/14476</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 22 May 2017 00:18:30 GMT</pubDate></item></channel></rss>
