<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[New automation user]]></title><description><![CDATA[<p dir="auto">hi all,<br />
as i titled this post,<br />
i'm totally new on  mango automation , can anybody here provide me required settings to add new MODbus serial data source and data point which will controlling lights . i used M-7053 16-channel Non-Isolated digital input module .</p>
]]></description><link>https://forum.mango-os.com/topic/2747/new-automation-user</link><generator>RSS for Node</generator><lastBuildDate>Mon, 15 Jun 2026 07:45:49 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2747.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 03 May 2017 05:49:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to New automation user on Wed, 03 May 2017 15:09:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi Joe,  welcome to the forum.  This will really depend on the required settings from the device.  Start by setting the baud rate and selecting your serial port.  Then I would use the test tools to read some of the registers to determine which ones you want and that communication is working.  Next add data points and set your polling rate and enable the data source and data points.  You should then be able to see the data updating on the Watch List.</p>
<p dir="auto">Here is a helpful article: <a href="https://help.infiniteautomation.com/configuring-data-sources-and-data-points/" rel="nofollow ugc">https://help.infiniteautomation.com/configuring-data-sources-and-data-points/</a></p>
]]></description><link>https://forum.mango-os.com/post/14301</link><guid isPermaLink="true">https://forum.mango-os.com/post/14301</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Wed, 03 May 2017 15:09:15 GMT</pubDate></item></channel></rss>
