<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[How To Copy point data to a scripting point]]></title><description><![CDATA[<p dir="auto">I am trying to copy all points since a specific date into a scripting point with the code below...<br />
I don't understand what is happening at all.. sometimes the script runs and produces 100 points. I purge the points and rerun the script and it produces 6 point values, purge again and run again and it creates 1 point value.<br />
The script always says 7684 points were set according to the result printout..  But when it runs only one point was created or sometimes 10 points or another number of points?  Never creates the 7684 number it says??<br />
I have no clue what determines this outcome and any help understanding this would be appreciated.</p>
<p dir="auto">Run Script is : true<br />
Points Found: 7684<br />
Setting point PointCopy to 541.0 @13/04/2017 00:00:28<br />
Setting point PointCopy to 541.0 @13/04/2017 00:01:28<br />
Setting point PointCopy to 541.0 @13/04/2017 00:02:28<br />
:<br />
Setting point PointCopy to 636.5 @18/04/2017 07:55:28<br />
Setting point PointCopy to 636.5 @18/04/2017 07:56:28<br />
Setting point Run Script #2 Flag1 to false @18/04/2017 11:02:25<br />
Points Copied = 7683<br />
Points fixed = 12<br />
{<br />
value: 636.5,<br />
time: 1492522230001,<br />
millis: 1,<br />
second: 30,<br />
minute: 0,<br />
hour: 11,<br />
day: 18,<br />
dayOfWeek: 3,<br />
dayOfYear: 108,<br />
month: 4,<br />
year: 2017,<br />
last(count): PointValueTime[count],<br />
lastValue: PointValueTime(636.5@2017/04/18 11:00:30.001),<br />
lastValue(count): PointValueTime,<br />
set(value): ,<br />
set(value, timestamp): ,<br />
pointValuesBetween(timestamp, timestamp): PointValueTime[],<br />
pointValuesSince(timestamp): PointValueTime[],<br />
pointValuesBefore(timestamp): PointValueTime[],<br />
pointValuesAfter(timestamp): PointValueTime[],<br />
pointValueAt(timestamp): PointValueTime,<br />
ago(periodType): double,<br />
ago(periodType, periods): double,<br />
past(periodType): AnalogStatisticsWrapper,<br />
past(periodType, periods): AnalogStatisticsWrapper,<br />
prev(periodType): AnalogStatisticsWrapper,<br />
prev(periodType, periods): AnalogStatisticsWrapper,<br />
previous(periodType): AnalogStatisticsWrapper,<br />
previous(periodType, periods): AnalogStatisticsWrapper,<br />
stats(from, to): AnalogStatisticsWrapper,<br />
}</p>
<p dir="auto">THIS IS THE SCRIPT IN QUESTION....</p>
<p dir="auto">print("Run Script is : " +RUNSCRIPT2_FLAG1.value);<br />
var periodBegin = new Date(2017, 3, 13).getTime()<br />
var copied = 0; fixed=0;</p>
<p dir="auto">if (RUNSCRIPT2_FLAG1.value === true){<br />
var values = pointx.pointValuesSince(periodBegin);<br />
print ("Points Found: " + values.length);<br />
for(var k = 0; k &lt; values.length-1; k+=1) {<br />
var val1 = values[k];<br />
var lastval = val1.value;</p>
<pre><code>        if (val1.value &gt;= 1){
            CopiedPoint.set(lastval,val1.time);
             copied +=1;
        else
            copied +=1;
            fixed +=1;
<p dir="auto">RUNSCRIPT2_FLAG1.set(false);<br />
print("Points Copied = " + copied);<br />
print("Points fixed = " + fixed);<br />
print(CopiedPoint);</p>
]]></description><link>https://forum.mango-os.com/topic/2733/how-to-copy-point-data-to-a-scripting-point</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 01:59:32 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2733.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 18 Apr 2017 13:39:04 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Thu, 20 Apr 2017 17:22:19 GMT]]></title><description><![CDATA[<p dir="auto">I can't say. I did some testing and while I have to correct some other errors in what I provided you it didn't seem to have any issues that would have caused duplication points. There was an issue with the variable name passed to the interpolation function, though. The updated version of that script is in the other thread.</p>
]]></description><link>https://forum.mango-os.com/post/14230</link><guid isPermaLink="true">https://forum.mango-os.com/post/14230</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 20 Apr 2017 17:22:19 GMT</pubDate></item><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Wed, 19 Apr 2017 21:10:03 GMT]]></title><description><![CDATA[<p dir="auto">Even without this module I am wondering why it duplicates points because we only set points with a timestamp + interval where there was no timestamp within the interval of the current point so this should not create duplicates should it?</p>
]]></description><link>https://forum.mango-os.com/post/14225</link><guid isPermaLink="true">https://forum.mango-os.com/post/14225</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Wed, 19 Apr 2017 21:10:03 GMT</pubDate></item><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Wed, 19 Apr 2017 20:45:32 GMT]]></title><description><![CDATA[<p dir="auto">You may want to use the Data Import module to delete the duplicates. You can export the point values on the Data Point Details page and mark rows to be removed, then import on /dataImport.shtm</p>
]]></description><link>https://forum.mango-os.com/post/14224</link><guid isPermaLink="true">https://forum.mango-os.com/post/14224</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 19 Apr 2017 20:45:32 GMT</pubDate></item><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Wed, 19 Apr 2017 20:40:11 GMT]]></title><description><![CDATA[<p dir="auto">Yes, you cannot have two values at the same millisecond using the NoSQL module, the latest insert prevails.</p>
]]></description><link>https://forum.mango-os.com/post/14223</link><guid isPermaLink="true">https://forum.mango-os.com/post/14223</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 19 Apr 2017 20:40:11 GMT</pubDate></item><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Wed, 19 Apr 2017 20:37:58 GMT]]></title><description><![CDATA[<p dir="auto">no its not in the list :(<br />
I'm guessing it is required to prevent duplicates?</p>
]]></description><link>https://forum.mango-os.com/post/14222</link><guid isPermaLink="true">https://forum.mango-os.com/post/14222</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Wed, 19 Apr 2017 20:37:58 GMT</pubDate></item><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Wed, 19 Apr 2017 19:57:01 GMT]]></title><description><![CDATA[<p dir="auto">Hi Phillip</p>
<p dir="auto">I foresaw the duplicate values if you are not using NoSQL in the original thread: <a href="http://infiniteautomation.com/forum/topic/2724/how-to-handle-missing-datapoints/3" rel="nofollow ugc">http://infiniteautomation.com/forum/topic/2724/how-to-handle-missing-datapoints/3</a></p>
<p dir="auto">To check if you have the module installed, you would navigate to the /modules.shtm page in the browser and see if it's in the list.</p>
]]></description><link>https://forum.mango-os.com/post/14221</link><guid isPermaLink="true">https://forum.mango-os.com/post/14221</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 19 Apr 2017 19:57:01 GMT</pubDate></item><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Wed, 19 Apr 2017 19:08:49 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a> said in <a href="/forum/post/14219">How To Copy point data to a scripting point</a>:</p>
<p dir="auto">mangoNoSqlDatabase<br />
Do we require the mangoNoSqlDatabase module do to solve this duplicate issue?<br />
I googled mangoNoSqlDatabase and get no results at all related to mango. NOTHING.<br />
Even on the MANGO help site it returns virtually nothing about mangoNoSqlDatabase .<br />
AND I have read those pages you directed me to, and nothing on duplicate records.</p>
]]></description><link>https://forum.mango-os.com/post/14220</link><guid isPermaLink="true">https://forum.mango-os.com/post/14220</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Wed, 19 Apr 2017 19:08:49 GMT</pubDate></item><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Wed, 19 Apr 2017 18:44:00 GMT]]></title><description><![CDATA[<p dir="auto">Do you have the mangoNoSqlDatabase module installed?</p>
<p dir="auto">This article is a useful introduction to Mango's JavaScript: <a href="http://help.infiniteautomation.com/support/solutions/articles/14000022520-about-mango-java-script" rel="nofollow ugc">http://help.infiniteautomation.com/support/solutions/articles/14000022520-about-mango-java-script</a></p>
<p dir="auto">It's a reproduction of the contextual help in the related items for most things which have scripts (click blue ? on data source edit page, scroll to the bottom, click "Mango Java Script")</p>
]]></description><link>https://forum.mango-os.com/post/14219</link><guid isPermaLink="true">https://forum.mango-os.com/post/14219</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 19 Apr 2017 18:44:00 GMT</pubDate></item><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Wed, 19 Apr 2017 18:01:46 GMT]]></title><description><![CDATA[<p dir="auto">Phil; I have the script copying now and writing to a log file, perhaps I was not waiting long enough.  Yes, I control the script running with flags as you noticed, so pretty easy to enable and disable them.<br />
I am still trying to validate the interpolate script you helped me with as working correctly on this copied point before I implement it on the original modbus data.<br />
In testing the script I get duplicates entries for the same timestamp. Is this normal because I thought a point.set with a timestamp that existed would overwrite that value.  how do I prevent duplicates?</p>
<p dir="auto">Also other than the sparse documentation is there a complete and detailed documentation on the objects, properties and methods exposed?  I seem to be learning this data paradigm piece-meal.  Thanks in advance.</p>
]]></description><link>https://forum.mango-os.com/post/14218</link><guid isPermaLink="true">https://forum.mango-os.com/post/14218</guid><dc:creator><![CDATA[Phillip Weeks]]></dc:creator><pubDate>Wed, 19 Apr 2017 18:01:46 GMT</pubDate></item><item><title><![CDATA[Reply to How To Copy point data to a scripting point on Tue, 18 Apr 2017 15:40:40 GMT]]></title><description><![CDATA[<p dir="auto">Hi Phillip,</p>
<li>Does this scripting data source have "Saves historic" checked? (I guess yes)</li>
<li>How are you assessing how many points were created? The number of values PointCopy has? How long did you wait after running the script?</li>
<li>Is your script difficult to disable once enabled? (I guess no)</li>
<p dir="auto">My intuition suggests you didn't wait long enough after the script ran for the values to appear, but you could enable logging in the script and put in <code>LOG.info("Copied: " + copied " + " point values.");</code> to get log messages into Mango/logs/scripting-[data source id].log</p>
<p dir="auto">Values that are not new values (latest timestamps in the series) can take a minute or two (actually configurable) if you're using the NoSQL module to appear, as it is more efficient to wait for the backdates to accumulate than insert them one at a time. That could be what you're seeing? It could also be the logging type of the CopiedPoint is not "All data" and it's something to do with that.</p>
]]></description><link>https://forum.mango-os.com/post/14213</link><guid isPermaLink="true">https://forum.mango-os.com/post/14213</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 18 Apr 2017 15:40:40 GMT</pubDate></item></channel></rss>
