<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Graphics replaced by an Icon "Image Chart" in WatchList and Details]]></title><description><![CDATA[<p dir="auto">I experienced the absence of graphic in the WatchList and Data points details.<br />
The graphics appears as an Icon named "Image Chart".<br />
Any solution to bring back the graphics ?<br />
Regards,<br />
Pascal</p>
]]></description><link>https://forum.mango-os.com/topic/2718/graphics-replaced-by-an-icon-image-chart-in-watchlist-and-details</link><generator>RSS for Node</generator><lastBuildDate>Wed, 19 Aug 2026 21:35:12 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2718.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 03 Apr 2017 10:53:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Graphics replaced by an Icon "Image Chart" in WatchList and Details on Mon, 03 Apr 2017 16:01:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi philgdep,</p>
<p dir="auto">Ah okay. No deleting that class file is the beginning and the end of solving that issue (well, you probably already had to restart Mango) What slowed down?</p>
<p dir="auto">One of the lowest hanging fruits to speed up a Mango is to change the database stream type in the env.properties file. Try setting</p>
<p dir="auto"><code>db.nosql.shardStreamType=MAPPED_BYTE_BUFFER</code></p>
<p dir="auto">in env.properties and restarting.</p>
]]></description><link>https://forum.mango-os.com/post/14141</link><guid isPermaLink="true">https://forum.mango-os.com/post/14141</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 03 Apr 2017 16:01:03 GMT</pubDate></item><item><title><![CDATA[Reply to Graphics replaced by an Icon "Image Chart" in WatchList and Details on Mon, 03 Apr 2017 15:56:45 GMT]]></title><description><![CDATA[<p dir="auto">Hi <a class="plugin-mentions-user plugin-mentions-a" href="/user/phildunlap" aria-label="Profile: phildunlap">@<bdi>phildunlap</bdi></a>, im actually working with pascal. So the error is fixed now. We upgraded from 2.6.?? To the latest version friday and got the bug. Is there anything else that we should look at ?</p>
<p dir="auto">The server seems to be very slow since the update was done. But everything seems to work ok.</p>
]]></description><link>https://forum.mango-os.com/post/14140</link><guid isPermaLink="true">https://forum.mango-os.com/post/14140</guid><dc:creator><![CDATA[philgdep]]></dc:creator><pubDate>Mon, 03 Apr 2017 15:56:45 GMT</pubDate></item><item><title><![CDATA[Reply to Graphics replaced by an Icon "Image Chart" in WatchList and Details on Mon, 03 Apr 2017 15:48:24 GMT]]></title><description><![CDATA[<p dir="auto">Hi Pascal and philgdep,</p>
<p dir="auto">Pascal, what philgdep is describing could cause that error. You'd know because there will be a stack trace coming out into Mango/logs/ma.log every time you load a page with a chart if it is that issue. It will complain about a NoSuchMethodError from Range.class, which philgdep has included the path to find it and delete it. You'd have to restart Mango to pick up the changes.</p>
<p dir="auto">If on the other hand it is a different error, share the stack trace and we'll see what that issue is.</p>
]]></description><link>https://forum.mango-os.com/post/14139</link><guid isPermaLink="true">https://forum.mango-os.com/post/14139</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Mon, 03 Apr 2017 15:48:24 GMT</pubDate></item><item><title><![CDATA[Reply to Graphics replaced by an Icon "Image Chart" in WatchList and Details on Mon, 03 Apr 2017 13:22:45 GMT]]></title><description><![CDATA[<p dir="auto">Fixed. It was a problem of due to an update. We had to remove the file: mango/classes/org/jfree/data/Range.class</p>
]]></description><link>https://forum.mango-os.com/post/14137</link><guid isPermaLink="true">https://forum.mango-os.com/post/14137</guid><dc:creator><![CDATA[philgdep]]></dc:creator><pubDate>Mon, 03 Apr 2017 13:22:45 GMT</pubDate></item><item><title><![CDATA[Reply to Graphics replaced by an Icon "Image Chart" in WatchList and Details on Mon, 03 Apr 2017 11:46:24 GMT]]></title><description><![CDATA[<p dir="auto">I just checked and it's a 500 error. It doesn't find the PNG. It happened after updating Mango to the last version. Anybody from Infinite Automation for a fix?</p>
<p dir="auto"><a href="https://i.imgur.com/RuA3IMA.png" rel="nofollow ugc">0_1491219810486_Screen Shot 2017-04-03 at 13.43.04.png</a></p>
]]></description><link>https://forum.mango-os.com/post/14136</link><guid isPermaLink="true">https://forum.mango-os.com/post/14136</guid><dc:creator><![CDATA[philgdep]]></dc:creator><pubDate>Mon, 03 Apr 2017 11:46:24 GMT</pubDate></item></channel></rss>
