<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Modbus4J - help with getting started]]></title><description><![CDATA[<p dir="auto">Hi. I've just downloaded Modbus4J and, as a Java developer in the BMS sector, I want to give it a quick trial before I make too many commitments. I've successfully imported all the source code into a new IntelliJ project, but I can't see much (if anything) in the way of instructions to test the software, i.e. a configuratiom to help me run a master which connects to a given Modbus slave device with a particular IP address or 485 serial port, and so on.</p>
<p dir="auto">Sorry if I'm being a bit thick, but could someone just point me in the right direction here ?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mango-os.com/topic/2644/modbus4j-help-with-getting-started</link><generator>RSS for Node</generator><lastBuildDate>Wed, 20 May 2026 04:35:11 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2644.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 29 Jan 2017 20:58:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Modbus4J - help with getting started on Sun, 29 Jan 2017 22:38:44 GMT]]></title><description><![CDATA[<p dir="auto">check out the modbus data source in the old mango source code for an example on how to use the modbus4j library</p>
<p dir="auto"><a href="https://sourceforge.net/projects/scadabr/files/Software/mango-src/" rel="nofollow ugc">https://sourceforge.net/projects/scadabr/files/Software/mango-src/</a></p>
]]></description><link>https://forum.mango-os.com/post/13753</link><guid isPermaLink="true">https://forum.mango-os.com/post/13753</guid><dc:creator><![CDATA[craig]]></dc:creator><pubDate>Sun, 29 Jan 2017 22:38:44 GMT</pubDate></item></channel></rss>
