<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Server connection with Bacnet]]></title><description><![CDATA[<p dir="auto">hello,</p>
<p dir="auto">i am very new in Bacnet ;) i want to lern how can i connect an UDP server with Bacnet4J klasses for example for an Analog Input object?</p>
<p dir="auto">best regards,<br />
Tom</p>
]]></description><link>https://forum.mango-os.com/topic/264/server-connection-with-bacnet</link><generator>RSS for Node</generator><lastBuildDate>Wed, 16 Sep 2026 15:16:21 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/264.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 18 Jan 2010 15:30:27 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Server connection with Bacnet on Sat, 30 Jan 2010 10:39:43 GMT]]></title><description><![CDATA[<p dir="auto">Hi, I have the same problem. I have a Johnson Controls FX40 and set up some analogue temperature BACNet points on the FX40.</p>
<p dir="auto">The FX40 is attached to a fixed IP address wireless router and I can easy get in there to change the logic or monitor the logic.</p>
<p dir="auto">I tried to setup a BACNet point using mango and in the Device ID I enter 5667 which is the device ID and in broadcast address I enter in the fixed IP address where I want to connect too.</p>
<p dir="auto">What do I enter in the port address, at this time its 47808 and as for the wireless fixed IP address router I only port forward, 8080, 3011, 1911, 9973 to the FX40 and that’s all that is needed.</p>
<p dir="auto">I can enable the device and no warnings or alarms appear, and when i change the port to 8080 or use whois i get "Address already in use: Cannot bind" and i get that on all the above port addresses 8080, 3011, 1911, 9973.</p>
<p dir="auto">Has anyone got any ideas ?</p>
]]></description><link>https://forum.mango-os.com/post/3114</link><guid isPermaLink="true">https://forum.mango-os.com/post/3114</guid><dc:creator><![CDATA[maxking]]></dc:creator><pubDate>Sat, 30 Jan 2010 10:39:43 GMT</pubDate></item></channel></rss>
