<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Problem updating windows mango server]]></title><description><![CDATA[<p dir="auto">We are trying to update our mango server from 2.5.2 to 2.7.12. Until now we are unssuccesful either with the manual update proccdure either with the "auto upgrade" from within mango enviroment.</p>
<p dir="auto">Can you please give us some help. We are attaching log file and a screenshot with the error that occured.</p>
<p dir="auto">Best Regards</p>
<p dir="auto">Stathis<a href="/forum/uploads/files/1479311473682-ma.log">0_1479311451298_ma.log</a> <img src="https://camo.nodebb.org/aac878328696fc515933c4a70e1ae09539961ab4?url=https%3A%2F%2Fi.imgur.com%2FiojOFJQ.png" alt="0_1479311464178_mango upgrade.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/topic/2547/problem-updating-windows-mango-server</link><generator>RSS for Node</generator><lastBuildDate>Tue, 09 Jun 2026 02:39:06 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2547.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 16 Nov 2016 15:52:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Problem updating windows mango server on Tue, 17 Jan 2017 16:04:25 GMT]]></title><description><![CDATA[<p dir="auto">The database would undergo the same updates it would if it were upgrading to 2.7.</p>
<p dir="auto">No the upgrades have not been updated to drop the tables, it slipped my mind to get "DROP IF EXISTS" into the mysql upgrade scripts, so you may have to drop the tables the upgrades create, or restore your MySQL dump into a new MySQL database.</p>
]]></description><link>https://forum.mango-os.com/post/13692</link><guid isPermaLink="true">https://forum.mango-os.com/post/13692</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 17 Jan 2017 16:04:25 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Tue, 17 Jan 2017 07:36:52 GMT]]></title><description><![CDATA[<p dir="auto">Hi Phil</p>
<p dir="auto">As we are clearly unsuccesful to upgrade to 2,7 versions ,we are at the proccess to upgrade to the latest 2.8.4. (i remind you that we are at 2.6 version)</p>
<p dir="auto">Is this possible ?</p>
<p dir="auto">Also do we have to delete tables from our MySQL schema or you have implemented to the latest version the solution to the problems that we encounter. You have advise us to drop some tables in the prvious atempts.</p>
<p dir="auto">Thx<br />
.</p>
]]></description><link>https://forum.mango-os.com/post/13689</link><guid isPermaLink="true">https://forum.mango-os.com/post/13689</guid><dc:creator><![CDATA[hornetgr]]></dc:creator><pubDate>Tue, 17 Jan 2017 07:36:52 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Fri, 18 Nov 2016 17:07:15 GMT]]></title><description><![CDATA[<p dir="auto">Hi Phil,<br />
well we settle for now at 2.6.0 version ( well its a start!) and we are going to try to upgrade to 2.7.12 next week..</p>
<p dir="auto">No luck from 2.5.2 to 2.7.12 it is impossible with our setup. Numerous errors in MySQL as you predicted.<br />
We also had many errors in 2.6.0 from a free bacnet datasource, that we deleted and after that 2.6 is working.</p>
<p dir="auto">I am send you the ma log from early morning trials.</p>
<p dir="auto"><a href="/forum/uploads/files/1479488676943-ma-2.log">0_1479488668091_ma (2).log</a></p>
]]></description><link>https://forum.mango-os.com/post/13296</link><guid isPermaLink="true">https://forum.mango-os.com/post/13296</guid><dc:creator><![CDATA[hornetgr]]></dc:creator><pubDate>Fri, 18 Nov 2016 17:07:15 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Thu, 17 Nov 2016 18:04:25 GMT]]></title><description><![CDATA[<p dir="auto">About the edit button , so silly of me , thanks.</p>
<p dir="auto">Well after each unsuccessful upgrade attempt we always perform a clean install of mango, (we delete everything and copy from another location). We also restore from a database SQL dump that is exported before doing anything.</p>
<p dir="auto">You send us much information and work for tomorrow. We will keep you informed.</p>
]]></description><link>https://forum.mango-os.com/post/13285</link><guid isPermaLink="true">https://forum.mango-os.com/post/13285</guid><dc:creator><![CDATA[hornetgr]]></dc:creator><pubDate>Thu, 17 Nov 2016 18:04:25 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Thu, 17 Nov 2016 16:58:42 GMT]]></title><description><![CDATA[<p dir="auto">You could also try just setting your database schema version to 12, since it seems like everything has already seemed run to some extent. Upgrade 11 is only two statements:</p>
<pre><code>CREATE TABLE jsonData (id int not null auto_increment,xid varchar(50) not null, name varchar(255) not null, readPermission varchar(255), editPermission varchar(255), data longtext, primary key (id))engine=InnoDB;
ALTER TABLE jsonData ADD CONSTRAINT jsonDataUn1 UNIQUE (xid);
<p dir="auto">so consider</p>
<pre><code>UPDATE systemSettings SET settingvalue='12' WHERE settingname='databaseSchemaVersion';
<p dir="auto">if</p>
<pre><code>SHOW CREATE TABLE jsonData;
<p dir="auto">looks alright.</p>
]]></description><link>https://forum.mango-os.com/post/13284</link><guid isPermaLink="true">https://forum.mango-os.com/post/13284</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 17 Nov 2016 16:58:42 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Thu, 17 Nov 2016 17:15:29 GMT]]></title><description><![CDATA[<p dir="auto">Edit is in the gear icon in the bottom left of your post.</p>
<p dir="auto">The scripts in the Mango/bin directory may have been updated. You can compare versions of the script on our Github, if you like: <a href="https://github.com/infiniteautomation/ma-core-public/blob/2.7.x/Core/scripts/ma-start.bat" rel="nofollow ugc">https://github.com/infiniteautomation/ma-core-public/blob/2.7.x/Core/scripts/ma-start.bat</a> . I believe at some point there was an issue with how the update was being performed on Windows.</p>
<p dir="auto">I suspect a lot of the SQL problems we're having are a result of doing the upgrades so many times. And, you're restoring from a MySQL dump, yes? Those typically begin with a bunch of <code>DROP TABLE IF EXISTS `tableName`;</code> statements, so it's not dropping the tables made by previous attempts at running because they're unknown at the time of the dump! I'll raise the idea of including the <code>DROP TABLE IF EXISTS</code> in future versions, but it does seem like something else would have to have gone wrong and we shouldn't presume the table ought be purged. So, in addition to potentially circumventing upgrade 10 if it fails from a clean restore, you may need to</p>
<pre><code>DROP TABLE templates;
DROP TABLE jsonData;
<p dir="auto">before running the upgrades. Consider also renaming the files in your Mango/classes/ directory, log4j.xml --&gt; normal-log4j.xml, debug-log4j.xml --&gt; log4j.xml to enable debug logging. If you are letting the script unzip the upgrade (if it isn't just unzipped by now), though, you may wish to place it in your Mango/overrides/properties directory as log4j.xml, and skip renaming it.</p>
]]></description><link>https://forum.mango-os.com/post/13283</link><guid isPermaLink="true">https://forum.mango-os.com/post/13283</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 17 Nov 2016 17:15:29 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Thu, 17 Nov 2016 16:26:26 GMT]]></title><description><![CDATA[<p dir="auto">And also we have another question.</p>
<p dir="auto">Why we need the new scripts, its seems that the old ma-start is doing the same thing.<br />
In all the other cases we used the new scripts and the did the same thing.</p>
<p dir="auto">Sorry for the multi threads but i cannot find the edit button</p>
]]></description><link>https://forum.mango-os.com/post/13282</link><guid isPermaLink="true">https://forum.mango-os.com/post/13282</guid><dc:creator><![CDATA[hornetgr]]></dc:creator><pubDate>Thu, 17 Nov 2016 16:26:26 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Thu, 17 Nov 2016 16:16:17 GMT]]></title><description><![CDATA[<p dir="auto">we forgot to mention that all the upgrade logs are null</p>
]]></description><link>https://forum.mango-os.com/post/13281</link><guid isPermaLink="true">https://forum.mango-os.com/post/13281</guid><dc:creator><![CDATA[hornetgr]]></dc:creator><pubDate>Thu, 17 Nov 2016 16:16:17 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Thu, 17 Nov 2016 16:14:00 GMT]]></title><description><![CDATA[<p dir="auto">Hi again,</p>
<p dir="auto">The new script is not running at all!</p>
<p dir="auto">we used the old script (ma-start) and it stopped at the upgrade 10 we did the commands and then again stops with an error.</p>
<p dir="auto">the logs attached</p>
<p dir="auto"><a href="/forum/uploads/files/1479399231312-ma-1.log">0_1479399223522_ma (1).log</a></p>
]]></description><link>https://forum.mango-os.com/post/13280</link><guid isPermaLink="true">https://forum.mango-os.com/post/13280</guid><dc:creator><![CDATA[hornetgr]]></dc:creator><pubDate>Thu, 17 Nov 2016 16:14:00 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Thu, 17 Nov 2016 13:23:47 GMT]]></title><description><![CDATA[<p dir="auto">How bizarre. I don't see the errors from the first post in the log you just attached. Did you restore a backup and then run the commands I included? If so, I suspect you skipped Upgrade 9 to 10 (not in your log) and only did the upgrade for 10 to 11, then tried 11 to 12. If I am mistaken, please share your Upgrade9.log file.</p>
<p dir="auto">Your procedure looks fine, but you can't skip Upgrade 9. It would be considerably more painful to try to perform Upgrade 9 from the command line (unless your existing user permission settings are not very important to you, then you can run the commands in the mysql portion of <a href="https://github.com/infiniteautomation/ma-core-public/blob/2.7.x/Core/src/com/serotonin/m2m2/db/upgrade/Upgrade9.java" rel="nofollow ugc">https://github.com/infiniteautomation/ma-core-public/blob/2.7.x/Core/src/com/serotonin/m2m2/db/upgrade/Upgrade9.java</a></p>
<p dir="auto">But I would encourage you to,</p>
<li>restore from a backup,</li>
<li>place Core zip in Mango/ directory</li>
<li>place module zips in Mango/web/modules</li>
<li>start Mango with ma-start.bat</li>
<li>IFF Mango fails in upgrade 10 with the 'templates table exists' SQL error, run the commands I gave you</li>
]]></description><link>https://forum.mango-os.com/post/13278</link><guid isPermaLink="true">https://forum.mango-os.com/post/13278</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 17 Nov 2016 13:23:47 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Thu, 17 Nov 2016 11:16:59 GMT]]></title><description><![CDATA[<p dir="auto">Goodmorning Phil,</p>
<p dir="auto">Well the upgrade is not going well either.</p>
<p dir="auto">We did all the things that you send us and we had no luck at all i would say.<br />
We  attached a newer log to see.</p>
<p dir="auto">We would like here to review the upgrade procedure that we did.</p>
<p dir="auto">After shutdown mango and backup etc etc we did the following:</p>
<p dir="auto">-delete lib directory<br />
-verify that env properties file is at MA_HOME/overrides/properties directory<br />
-We input all the commands you send us to the MySQL command line prompt (response is attached)<br />
-unzip and copy all files of core 2.7.12 to MA_HOME  and also place zip modules at web/modules directory<br />
-replace the ma_start.bat and copy upgrade.bat withh the newer vesrion from your site to MA_HOME/bin</p>
<ul>
<li>fire ma_start.bat</li>
</ul>
<p dir="auto">The rest is at the logs..<br />
<a href="/forum/uploads/files/1479381278118-ma.log">0_1479381266006_ma.log</a></p>
<p dir="auto"><a href="/forum/uploads/files/1479381280289-mango-sql-log.txt">0_1479381279814_mango sql log.txt</a></p>
<p dir="auto">Best Regards<br />
Stathis</p>
]]></description><link>https://forum.mango-os.com/post/13277</link><guid isPermaLink="true">https://forum.mango-os.com/post/13277</guid><dc:creator><![CDATA[hornetgr]]></dc:creator><pubDate>Thu, 17 Nov 2016 11:16:59 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Wed, 16 Nov 2016 19:27:51 GMT]]></title><description><![CDATA[<p dir="auto">Thx Phil, we will try again tomorrow (it is late night here in Greece now) and we will keep you posted.</p>
]]></description><link>https://forum.mango-os.com/post/13271</link><guid isPermaLink="true">https://forum.mango-os.com/post/13271</guid><dc:creator><![CDATA[hornetgr]]></dc:creator><pubDate>Wed, 16 Nov 2016 19:27:51 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Wed, 16 Nov 2016 19:22:32 GMT]]></title><description><![CDATA[<p dir="auto">Well, I can't say i know how it got in this state (I'll run some tests on that when I have a minute to sanity check) but this should be a path to resolution:</p>
<p dir="auto">Open a MySQL terminal into your Mango's database, run the following commands. Don't worry if they give errors about already existing!</p>
<pre><code>CREATE TABLE templates ( id int NOT NULL auto_increment, xid varchar(50) NOT NULL, name VARCHAR(255), templateType VARCHAR(50), readPermission VARCHAR(255), setPermission VARCHAR(255), data longblob NOT NULL, PRIMARY KEY (id) ) engine=InnoDB;
ALTER TABLE templates ADD CONSTRAINT templatesUn1 UNIQUE (xid);
ALTER TABLE dataPoints ADD COLUMN templateId INT;
ALTER TABLE dataPoints ADD CONSTRAINT dataPointsFk2 FOREIGN KEY (templateId) REFERENCES templates(id);
<p dir="auto">This is what Upgrade10 was trying to do for the most part. Then run</p>
<pre><code>UPDATE systemSettings SET settingvalue='11' WHERE settingname='databaseSchemaVersion';
<p dir="auto">And it should all work!</p>
]]></description><link>https://forum.mango-os.com/post/13270</link><guid isPermaLink="true">https://forum.mango-os.com/post/13270</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 16 Nov 2016 19:22:32 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Wed, 16 Nov 2016 19:04:48 GMT]]></title><description><![CDATA[<p dir="auto">My mistake! I did not notice the log file, only the image. I am looking now...</p>
]]></description><link>https://forum.mango-os.com/post/13269</link><guid isPermaLink="true">https://forum.mango-os.com/post/13269</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 16 Nov 2016 19:04:48 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Wed, 16 Nov 2016 19:03:49 GMT]]></title><description><![CDATA[<p dir="auto">Hi Phil thank you for your quick response.</p>
<p dir="auto">Our DB is MySQL<br />
Contents of the particular log is null.<br />
Upgrade is done from server screen and we see the command prompt but nothing different than the attached log</p>
]]></description><link>https://forum.mango-os.com/post/13268</link><guid isPermaLink="true">https://forum.mango-os.com/post/13268</guid><dc:creator><![CDATA[hornetgr]]></dc:creator><pubDate>Wed, 16 Nov 2016 19:03:49 GMT</pubDate></item><item><title><![CDATA[Reply to Problem updating windows mango server on Wed, 16 Nov 2016 18:53:13 GMT]]></title><description><![CDATA[<p dir="auto">Hi Stathis,</p>
<p dir="auto">I am guessing this is the origin of your post in the other thread about only updating modules and not the core!</p>
<p dir="auto">It looks like there's an error occuring in the upgrade script. Can you tell me,</p>
<li>What is your database?</li>
<li>What is the content of Mango/logs/com.serotonin.m2m2.db.upgrade.Upgrade10.log</li>
<p dir="auto">You can also get better information about the failure by launching this in a terminal or command prompt, as the final exception will print into the console, and you can share the exception here. This exception is also very likely at the end of your Mango/logs/ma.log file. Please post that error.</p>
]]></description><link>https://forum.mango-os.com/post/13267</link><guid isPermaLink="true">https://forum.mango-os.com/post/13267</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 16 Nov 2016 18:53:13 GMT</pubDate></item></channel></rss>
