<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[BARIX R6 Configuration]]></title><description><![CDATA[<p dir="auto">Hi all, I am trying to configure a BARIX R6 Modbus relay board. I have created the data source but am now unsure about how to write to the points. I intend to use this module to control loads with the relays.<br />
The following is the register map:</p>
<p dir="auto">Detailed “register” map – again – please note that the protocol address in Modbus/RTU is the register number -1 !!<br />
Registe r<br />
Function<br />
1 Live I/O (Byte, Relay state in bit 0..5)<br />
2..256 Reserved, not accessible<br />
257 Device type (hex 0xB1)<br />
258 Firmware version<br />
259 Serial number 1st part<br />
260 Serial number 2nd part<br />
261..264 reserved<br />
265..272 One-time writable for installer<br />
273 Default relay setting for startup<br />
274 Serial interface mode<br />
275 Modbus address<br />
276..289 reserved<br />
290..512 Memory for installer/software use<br />
513.... 65536</p>
<p dir="auto">Any help is greatly appreciated.</p>
]]></description><link>https://forum.mango-os.com/topic/2539/barix-r6-configuration</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 01:24:08 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2539.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 11 Nov 2016 17:34:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to BARIX R6 Configuration on Thu, 17 Nov 2016 22:33:12 GMT]]></title><description><![CDATA[<p dir="auto">Ethernet? I suspect so, but I've only used a standard ethernet cable for that purpose (haven't ports been  self detecting and switching for a half decade or so? <a href="https://en.wikipedia.org/wiki/Medium-dependent_interface#Auto_MDI-X" rel="nofollow ugc">https://en.wikipedia.org/wiki/Medium-dependent_interface#Auto_MDI-X</a> ). Then you'll probably have to give your ethernet interface a static ip on the same network or listen for its IPv6 address and use that.</p>
]]></description><link>https://forum.mango-os.com/post/13287</link><guid isPermaLink="true">https://forum.mango-os.com/post/13287</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 17 Nov 2016 22:33:12 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Thu, 17 Nov 2016 22:20:37 GMT]]></title><description><![CDATA[<p dir="auto">Can I use a crossover cable to connect my mango ES to my laptop?</p>
]]></description><link>https://forum.mango-os.com/post/13286</link><guid isPermaLink="true">https://forum.mango-os.com/post/13286</guid><dc:creator><![CDATA[Chromeaccent]]></dc:creator><pubDate>Thu, 17 Nov 2016 22:20:37 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Wed, 16 Nov 2016 16:43:13 GMT]]></title><description><![CDATA[<p dir="auto">I did change the address to 200 for the R6, I also had to change the address for the other device, this I changed to 230. One thing I did notice was that at first, I would get the result  for temperature in Hexidecimal but after a while it changed to decimal values.</p>
]]></description><link>https://forum.mango-os.com/post/13262</link><guid isPermaLink="true">https://forum.mango-os.com/post/13262</guid><dc:creator><![CDATA[Chromeaccent]]></dc:creator><pubDate>Wed, 16 Nov 2016 16:43:13 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Wed, 16 Nov 2016 15:46:18 GMT]]></title><description><![CDATA[<p dir="auto">I don't know what you mean, "Strangely it responds to Modbus poll" You are not using Slave Id 255 are you? I would not expect that to work. It must have a slave ID &lt;= 247</p>
<p dir="auto">If you are not seeing the Units (I assume you are referring to units) you need, you can set a custom suffix in the text renderer section of the data point.</p>
]]></description><link>https://forum.mango-os.com/post/13258</link><guid isPermaLink="true">https://forum.mango-os.com/post/13258</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 16 Nov 2016 15:46:18 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Wed, 16 Nov 2016 08:15:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi Phildunlap,</p>
<p dir="auto">I was able to get another Modbus device display, this device has two data points, temperature and relative humidity,  however,  I am at a loss as the Barix R6's configuration. Strangely it responds to Modbus poll.<br />
By the way, I have not seen Relative Humidity(RH) in the point properties drop down menu.</p>
]]></description><link>https://forum.mango-os.com/post/13256</link><guid isPermaLink="true">https://forum.mango-os.com/post/13256</guid><dc:creator><![CDATA[Chromeaccent]]></dc:creator><pubDate>Wed, 16 Nov 2016 08:15:03 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Tue, 15 Nov 2016 21:02:46 GMT]]></title><description><![CDATA[<p dir="auto">Hi Chromeaccent,</p>
<p dir="auto">It is possible the parity is "None" instead of "Even" as the manual is not clear. "Even" is the default but "None" is also listed as a supported possibility. From the document:</p>
<pre><code>Supported interface configurations are
19200 baud, 8bit, even parity, 1 stop bit (**default**)
19200 baud, 8bit, no parity, 1 stop bit
9600 baud, 8bit, even parity, 1 stop bit
9600 baud, 8bit, no parity, 1 stop bit
]]></description><link>https://forum.mango-os.com/post/13255</link><guid isPermaLink="true">https://forum.mango-os.com/post/13255</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 15 Nov 2016 21:02:46 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Sat, 12 Nov 2016 00:29:10 GMT]]></title><description><![CDATA[<p dir="auto">You need to disable any data sources using that port before using the test tools.  I'm guessing that is the issue.</p>
]]></description><link>https://forum.mango-os.com/post/13216</link><guid isPermaLink="true">https://forum.mango-os.com/post/13216</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Sat, 12 Nov 2016 00:29:10 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Sat, 12 Nov 2016 00:23:40 GMT]]></title><description><![CDATA[<p dir="auto">When I attempt to write to the device I keep getting:<br />
<strong>There was a problem testing the locator. (com.infiniteautomation.mango.io.serial.SerialPortException: Port /dev/rs485-1 in use by Mango Modbus Data Source DS_451699)</strong><br />
Any ideas?</p>
]]></description><link>https://forum.mango-os.com/post/13215</link><guid isPermaLink="true">https://forum.mango-os.com/post/13215</guid><dc:creator><![CDATA[Chromeaccent]]></dc:creator><pubDate>Sat, 12 Nov 2016 00:23:40 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Fri, 11 Nov 2016 23:47:43 GMT]]></title><description><![CDATA[<p dir="auto">Thanks for your quick response. I have been trying to use Modbus poll from Modbus tools as a master in order to change the R6 address,  however, I have been having communication issues with it. I will try the setting listed above and let you know.</p>
]]></description><link>https://forum.mango-os.com/post/13214</link><guid isPermaLink="true">https://forum.mango-os.com/post/13214</guid><dc:creator><![CDATA[Chromeaccent]]></dc:creator><pubDate>Fri, 11 Nov 2016 23:47:43 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Fri, 11 Nov 2016 20:03:23 GMT]]></title><description><![CDATA[<p dir="auto">It looks like for Write commands you will be writing to Coil Status registers 1-6 (0-5?), once you have communication going.</p>
]]></description><link>https://forum.mango-os.com/post/13213</link><guid isPermaLink="true">https://forum.mango-os.com/post/13213</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 11 Nov 2016 20:03:23 GMT</pubDate></item><item><title><![CDATA[Reply to BARIX R6 Configuration on Fri, 11 Nov 2016 20:15:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi Chromeaccent,</p>
<p dir="auto">My first step was googling for a manual. I found this: <a href="http://www.barix.com/fileadmin/data/Manuals/barixr6_manual_V0200.pdf" rel="nofollow ugc">http://www.barix.com/fileadmin/data/Manuals/barixr6_manual_V0200.pdf</a> so I will be presuming you're talking about that device.</p>
<p dir="auto">The "Supported standard commands" indicates that only read requests on holding registers are supported, so I am guessing those values in your post are holding register offsets. The bit about "please not the protocol address in..." is informing us that it is a 0 offset implementation, but that it's presenting information with a 1 offset. So, in using the test tools, I would assume reading Holding Register 256 should give you the Device Type</p>
<p dir="auto">I do not see the slave ID for the device described in the document, but they say that there is a jumper that can force it into default settings (although it appears from the document that the default modbus address is 255, which is frowned upon in the Modbus spec and you may have issues. I may be able to supply you with a sly workaround to set a better slave ID if this is an issue, but perhaps you have the tools to set the PLC's slave ID or you know it has one that is lower than 247, and this won't be an issue)</p>
<p dir="auto"><img src="https://camo.nodebb.org/db599b85cb58a0b26eebc663f184e0cd418bd7d7?url=https%3A%2F%2Fi.imgur.com%2F9NwrYsn.png" alt="0_1478892172975_modbus-read-forum.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">A request that i think should get the Device Type</p>
<p dir="auto">Settings in document: 19200 baud (bit rate), even parity, 1 stop bit. This would be a Modbus Serial data source.</p>
<p dir="auto"><img src="https://camo.nodebb.org/b4c47fed0668f567254e41005b3ac41eb7bbcde0?url=https%3A%2F%2Fi.imgur.com%2FRs5JWZX.png" alt="0_1478892358263_modbus-read-forum-2.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/13212</link><guid isPermaLink="true">https://forum.mango-os.com/post/13212</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 11 Nov 2016 20:15:07 GMT</pubDate></item></channel></rss>
