<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango ES crashed during Upgrade]]></title><description><![CDATA[<p dir="auto">I recently checked for upgrades and pressed the Do Upgrade button on a mango ES. The webpage hung with the loading bar at about 40% of the upgrade. I can no longer access the mango ES via the web page but can access it via SSH.</p>
<p dir="auto">I have retrieved the following from the ma.log file. Any assistance to get the mango ES running again would be appreciated.</p>
<p dir="auto">The log file is attached.</p>
<p dir="auto"><a href="/forum/uploads/files/1478663868127-102030239-logs.txt">0_1478663897732_102030239 logs.txt</a></p>
]]></description><link>https://forum.mango-os.com/topic/2536/mango-es-crashed-during-upgrade</link><generator>RSS for Node</generator><lastBuildDate>Sat, 17 Oct 2026 03:32:55 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2536.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 09 Nov 2016 03:58:08 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango ES crashed during Upgrade on Thu, 10 Nov 2016 01:16:13 GMT]]></title><description><![CDATA[<p dir="auto">Thanks Joel I will submit a support ticket today - the ES was being upgraded from core 2.7.2 to the latest available version.</p>
]]></description><link>https://forum.mango-os.com/post/13197</link><guid isPermaLink="true">https://forum.mango-os.com/post/13197</guid><dc:creator><![CDATA[MaP]]></dc:creator><pubDate>Thu, 10 Nov 2016 01:16:13 GMT</pubDate></item><item><title><![CDATA[Reply to Mango ES crashed during Upgrade on Wed, 09 Nov 2016 15:28:26 GMT]]></title><description><![CDATA[<p dir="auto">Looks like it's still  not able to connect to the h2 database. Do you know what version you where upgrading from?  Probably nest to contact us at support so we can help you with a live support session.</p>
]]></description><link>https://forum.mango-os.com/post/13195</link><guid isPermaLink="true">https://forum.mango-os.com/post/13195</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Wed, 09 Nov 2016 15:28:26 GMT</pubDate></item><item><title><![CDATA[Reply to Mango ES crashed during Upgrade on Wed, 09 Nov 2016 08:37:13 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://camo.nodebb.org/99d75aca437960e45db37a8cafae7637a9a845a1?url=https%3A%2F%2Fi.imgur.com%2FcchoRN6.png" alt="0_1478680623668_upload-78d5800f-61a6-4e2a-8e3f-175fd33a446a" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/13194</link><guid isPermaLink="true">https://forum.mango-os.com/post/13194</guid><dc:creator><![CDATA[MaP]]></dc:creator><pubDate>Wed, 09 Nov 2016 08:37:13 GMT</pubDate></item><item><title><![CDATA[Reply to Mango ES crashed during Upgrade on Wed, 09 Nov 2016 08:13:19 GMT]]></title><description><![CDATA[<p dir="auto">I have run the suggested commands the output from the ssh session is attached.<br />
<a href="/forum/uploads/files/1478679191020-mango-es-restart-102030239.txt">0_1478679220748_Mango ES  Restart 102030239.txt</a></p>
]]></description><link>https://forum.mango-os.com/post/13193</link><guid isPermaLink="true">https://forum.mango-os.com/post/13193</guid><dc:creator><![CDATA[MaP]]></dc:creator><pubDate>Wed, 09 Nov 2016 08:13:19 GMT</pubDate></item><item><title><![CDATA[Reply to Mango ES crashed during Upgrade on Wed, 09 Nov 2016 04:04:34 GMT]]></title><description><![CDATA[<p dir="auto">This is the part that stands out to me.  Unable to connect to database of type H2</p>
<p dir="auto">I would stop the Mango service and make sure java is not running.</p>
<p dir="auto">You can run <em><strong>sudo service mango stop</strong></em> to stop it.</p>
<p dir="auto">You can run <em><strong>pidof java</strong></em> and make sure it doesn't return a process number.</p>
<p dir="auto">Then you can go into the /opt/mango/bin folder and run <em><strong>./ma.sh start</strong></em></p>
<p dir="auto">This will allow you to see the exact output while it's starting up.  you can share the results of this with us so we can see more clearly the issue.</p>
]]></description><link>https://forum.mango-os.com/post/13192</link><guid isPermaLink="true">https://forum.mango-os.com/post/13192</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Wed, 09 Nov 2016 04:04:34 GMT</pubDate></item></channel></rss>
