<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Report setup-&quot;Location for time&quot; and &quot;Named range&quot;]]></title><description><![CDATA[<p dir="auto">Hello,</p>
<p dir="auto">I try to setup excel report.<br />
My excel template:<br />
<img src="https://camo.nodebb.org/653ed78930855fed933422d414e60c7ac007b30f?url=https%3A%2F%2Fi.imgur.com%2FqyGF47x.png" alt="0_1478645464934_report1.PNG" class=" img-fluid img-markdown" /></p>
<p dir="auto">I don't know how to set up these:<br />
<img src="https://camo.nodebb.org/5072949c70b67ac9a4a1b26e926023079c28575a?url=https%3A%2F%2Fi.imgur.com%2Fl2pjSkb.png" alt="0_1478645505793_REPORT2.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Many thanks!<br />
Jack Chang</p>
]]></description><link>https://forum.mango-os.com/topic/2535/report-setup-location-for-time-and-named-range</link><generator>RSS for Node</generator><lastBuildDate>Sat, 18 Apr 2026 23:35:36 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2535.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 08 Nov 2016 22:51:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Report setup-&quot;Location for time&quot; and &quot;Named range&quot; on Tue, 08 Nov 2016 23:52:36 GMT]]></title><description><![CDATA[<p dir="auto">The best way I found to do this was to create a second sheet and have Mango paste the data into that and then on the first sheet you simply link to the data on the second sheet.</p>
<p dir="auto">See sample below. Highlight at least 2-3 rows and then in the formulas tab choose create from selection. These are now what you select in Mango. Format the columns before you upload the Excel file.</p>
<p dir="auto"><img src="https://camo.nodebb.org/c261afe4a5db1b194e6b3ed13439b551b0d5f059?url=https%3A%2F%2Fi.imgur.com%2FpCLmajj.png" alt="0_1478649010748_ExcelSample.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/13189</link><guid isPermaLink="true">https://forum.mango-os.com/post/13189</guid><dc:creator><![CDATA[v8dave]]></dc:creator><pubDate>Tue, 08 Nov 2016 23:52:36 GMT</pubDate></item><item><title><![CDATA[Reply to Report setup-&quot;Location for time&quot; and &quot;Named range&quot; on Tue, 08 Nov 2016 23:42:25 GMT]]></title><description><![CDATA[<p dir="auto">You need to create a named range in your excel file for the time stamps to go into.</p>
<p dir="auto">You also need to create named ranges for any data points.  The ranges need to be at least 2 rows in a column.  Once you upload the excel file with the named ranges they will show up in those drop down lists for you to select.  Let me know if that helps.</p>
]]></description><link>https://forum.mango-os.com/post/13188</link><guid isPermaLink="true">https://forum.mango-os.com/post/13188</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Tue, 08 Nov 2016 23:42:25 GMT</pubDate></item><item><title><![CDATA[Reply to Report setup-&quot;Location for time&quot; and &quot;Named range&quot; on Tue, 08 Nov 2016 22:53:18 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://camo.nodebb.org/e27727b1bd202f52a4148cfc0e61e22602bf61e0?url=https%3A%2F%2Fi.imgur.com%2FubfwcIf.png" alt="0_1478645596037_report1.PNG" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/13187</link><guid isPermaLink="true">https://forum.mango-os.com/post/13187</guid><dc:creator><![CDATA[jackchang]]></dc:creator><pubDate>Tue, 08 Nov 2016 22:53:18 GMT</pubDate></item></channel></rss>
