<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Interval Logging Period will not change]]></title><description><![CDATA[<p dir="auto">Hello Mr Phil,</p>
<p dir="auto">while I am setting up some metapoints, I save the point and it will not allow me to change the interval logging period.  It is all greyed out and is defaulted at 1 minutes.  Is there a setting I am missing.</p>
]]></description><link>https://forum.mango-os.com/topic/2507/interval-logging-period-will-not-change</link><generator>RSS for Node</generator><lastBuildDate>Mon, 20 Apr 2026 13:09:15 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2507.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 24 Oct 2016 20:58:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Interval Logging Period will not change on Mon, 24 Oct 2016 21:02:48 GMT]]></title><description><![CDATA[<p dir="auto">Awesome!!!</p>
]]></description><link>https://forum.mango-os.com/post/12961</link><guid isPermaLink="true">https://forum.mango-os.com/post/12961</guid><dc:creator><![CDATA[atkins.chrisw]]></dc:creator><pubDate>Mon, 24 Oct 2016 21:02:48 GMT</pubDate></item><item><title><![CDATA[Reply to Interval Logging Period will not change on Mon, 24 Oct 2016 21:02:05 GMT]]></title><description><![CDATA[<p dir="auto">By default the point property settings come from a template.  Just uncheck the "Use template" box above and you'll be able to manually set it.</p>
<p dir="auto">If you will have many points with the same setting you can also edit the template and then save it or save it as a new template to use again.  Keep in mind that if you change a template any points using the template will be updated to the new settings.</p>
]]></description><link>https://forum.mango-os.com/post/12960</link><guid isPermaLink="true">https://forum.mango-os.com/post/12960</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Mon, 24 Oct 2016 21:02:05 GMT</pubDate></item></channel></rss>
