<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[AM Line Chart change from default smooth line to regular line]]></title><description><![CDATA[<p dir="auto">Is there any way to change the default smooth chart line to a non-smoothed line, perhaps with your angular directives?</p>
<p dir="auto">I'd like to fix things like this:</p>
<p dir="auto"><img src="https://camo.nodebb.org/2af6fdc421ad6d23e9409344bb95946f2cfbd10d?url=https%3A%2F%2Fi.imgur.com%2FftjKHXs.png" alt="0_1477060011102_smoothing.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">I'd like to be able to see the steps in the line anyway.</p>
<p dir="auto">I noticed in the AM charts website that you can choose smoothed line like below:</p>
<pre><code>"graphs": [{"type": "smoothedLine",}
<p dir="auto">So I tracked down the property <a href="https://docs.amcharts.com/3/javascriptcharts/AmGraph" rel="nofollow ugc">here</a>.</p>
<p dir="auto">Then I tried to add this to the options:</p>
<pre><code>graphs:[{type:'line'}]
<p dir="auto">But it still looks the same to me.</p>
<p dir="auto">In case you'd like to see the entire options code here it is:</p>
<pre><code>                  options="{
                        valueAxes:[
                                axisColor:'black',
                                color:'black',
                                title: 'Temperature °F',
                                titleColor: 'black',
                                fontSize:26,
                                titleFontSize:26,
                                minimum:0,
                                maximum:160
                                axisColor:'black',
                                color:'black',
                                title: 'Firing Rate %',
                                fontSize:26,
                                titleFontSize:26,
                                minimum:0,
                                maximum:100
                        graphs:[
                            {type:'line'}
]]></description><link>https://forum.mango-os.com/topic/2502/am-line-chart-change-from-default-smooth-line-to-regular-line</link><generator>RSS for Node</generator><lastBuildDate>Sun, 15 Nov 2026 02:58:49 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2502.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 21 Oct 2016 14:36:50 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to AM Line Chart change from default smooth line to regular line on Tue, 25 Oct 2016 16:09:28 GMT]]></title><description><![CDATA[<p dir="auto">The series-x-type was exactly what I was looking for.</p>
<p dir="auto">I did just notice that it was in your documentation too.  I do remember looking that over, but at that time I didn't understand what I was reading.  It's all getting more and more clear.</p>
<p dir="auto">Thanks Jared.</p>
]]></description><link>https://forum.mango-os.com/post/12980</link><guid isPermaLink="true">https://forum.mango-os.com/post/12980</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Tue, 25 Oct 2016 16:09:28 GMT</pubDate></item><item><title><![CDATA[Reply to AM Line Chart change from default smooth line to regular line on Tue, 25 Oct 2016 15:59:30 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/mihairosu" aria-label="Profile: mihairosu">@<bdi>mihairosu</bdi></a><br />
I'm not sure how you are using the <code>ma-serial-chart</code> directive (post it up). But if you specify the <code>series-x-point</code> attribute it will use the point's plot type (set on the point edit page) or you can explicitly set it using the <code>series-x-type</code> attribute. You can also set the <code>default-type</code> attribute to change all of the series' types.</p>
]]></description><link>https://forum.mango-os.com/post/12979</link><guid isPermaLink="true">https://forum.mango-os.com/post/12979</guid><dc:creator><![CDATA[Jared Wiltshire]]></dc:creator><pubDate>Tue, 25 Oct 2016 15:59:30 GMT</pubDate></item><item><title><![CDATA[Reply to AM Line Chart change from default smooth line to regular line on Fri, 21 Oct 2016 14:39:50 GMT]]></title><description><![CDATA[<p dir="auto">I just noticed that adding the "graphs" to the options adds an extra legend item.  See below:</p>
<p dir="auto"><img src="https://camo.nodebb.org/f23585f3906a2b42724b717dec169d439e218940?url=https%3A%2F%2Fi.imgur.com%2FzqZT5lU.png" alt="0_1477060793666_added.png" class=" img-fluid img-markdown" /></p>
]]></description><link>https://forum.mango-os.com/post/12939</link><guid isPermaLink="true">https://forum.mango-os.com/post/12939</guid><dc:creator><![CDATA[mihairosu]]></dc:creator><pubDate>Fri, 21 Oct 2016 14:39:50 GMT</pubDate></item></channel></rss>
