<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No design mode DG Lux]]></title><description><![CDATA[<p dir="auto">I am running dglux2.5 on a mangoes, when logged in as administrator I do not get the design mode button in dglux.</p>
]]></description><link>https://forum.mango-os.com/topic/2409/no-design-mode-dg-lux</link><generator>RSS for Node</generator><lastBuildDate>Mon, 08 Jun 2026 05:04:51 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2409.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 12 Aug 2016 13:33:13 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No design mode DG Lux on Sat, 13 Aug 2016 06:03:03 GMT]]></title><description><![CDATA[<p dir="auto">Hi Andrew,</p>
<p dir="auto">You should definitely be able to get into design mode as user "admin" (not just any user with admin privileges!). Unless you have changed the settings or deleted your userdb folder in Mango/web/modules/dglux/web/</p>
<p dir="auto">One way to alleviate this would be to reinstall the DGLux module after deleting the existing module folder. I am guessing you do not have dashboards yet?</p>
<p dir="auto">Alternatively, you could...</p>
<li>Move your Mango/web/modules/dglux directory up a level (so that it doesn't load),</li>
<li>Download it again,</li>
<li>Open up DGLux, Log in.</li>
<li>Shut mango down.</li>
<li>Displace the userdb directory in your original DGLux module, and move the userdb directory from the new DGLux directory to the old.</li>
<li>Move the old DGLux directory back into the Mango/web/modules directory (overwriting the new one).</li>
]]></description><link>https://forum.mango-os.com/post/12405</link><guid isPermaLink="true">https://forum.mango-os.com/post/12405</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Sat, 13 Aug 2016 06:03:03 GMT</pubDate></item><item><title><![CDATA[Reply to No design mode DG Lux on Fri, 12 Aug 2016 14:14:58 GMT]]></title><description><![CDATA[<p dir="auto">I am logged into mango as admin, and I have tried clearing the cache.  Any other ideas?</p>
<p dir="auto">Thanks</p>
]]></description><link>https://forum.mango-os.com/post/12404</link><guid isPermaLink="true">https://forum.mango-os.com/post/12404</guid><dc:creator><![CDATA[AndrewSetpoint]]></dc:creator><pubDate>Fri, 12 Aug 2016 14:14:58 GMT</pubDate></item><item><title><![CDATA[Reply to No design mode DG Lux on Fri, 12 Aug 2016 13:37:33 GMT]]></title><description><![CDATA[<p dir="auto">Unless you specifically give a user permission to design mode the only username is "admin"  even if other users are super admin by default the only user that can use design mode is "admin"</p>
<p dir="auto">If you are logging in as admin I would suggest clearing your browsers cache and see if that resolves it.</p>
]]></description><link>https://forum.mango-os.com/post/12403</link><guid isPermaLink="true">https://forum.mango-os.com/post/12403</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Fri, 12 Aug 2016 13:37:33 GMT</pubDate></item></channel></rss>
