<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Using the H2 DB]]></title><description><![CDATA[<p dir="auto">Where can I get information on setting up relationships using the h2 console? Is their another front end to use for this?</p>
]]></description><link>https://forum.mango-os.com/topic/2406/using-the-h2-db</link><generator>RSS for Node</generator><lastBuildDate>Thu, 05 Mar 2026 07:36:46 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2406.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 09 Aug 2016 15:47:52 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Using the H2 DB on Tue, 16 Aug 2016 15:15:19 GMT]]></title><description><![CDATA[<p dir="auto">I  am trying to connect to the h2 server DB with "Razorsql" ,but it tells me ------<br />
((ERROR: An error occurred while trying to make a connection to the<br />
database:</p>
<p dir="auto">JDBC URL: jdbc:h2:P:\IT Dept Installs\Mango Automation 2.7.10<br />
Enterprise Demo\databases\mah2</p>
<p dir="auto">Database may be already in use: "Locked by another process".<br />
Possible solutions: close all other connection(s); use the server<br />
mode [90020-166] ))<br />
Has any one used razor for the h2 DB? Any help would be great. Thanks</p>
]]></description><link>https://forum.mango-os.com/post/12415</link><guid isPermaLink="true">https://forum.mango-os.com/post/12415</guid><dc:creator><![CDATA[LarryE]]></dc:creator><pubDate>Tue, 16 Aug 2016 15:15:19 GMT</pubDate></item><item><title><![CDATA[Reply to Using the H2 DB on Tue, 09 Aug 2016 16:18:54 GMT]]></title><description><![CDATA[<p dir="auto">Hi Larry,</p>
<p dir="auto">What do you mean, "setting up relationships?" You can run ALTER TABLE statements either through the SQL Console or through the h2-web-console script described here: <a href="http://help.infiniteautomation.com/support/solutions/articles/14000022661-about-the-h2-database" rel="nofollow ugc">http://help.infiniteautomation.com/support/solutions/articles/14000022661-about-the-h2-database</a></p>
<p dir="auto">H2 has lots of documentation: <a href="http://www.h2database.com/html/main.html" rel="nofollow ugc">http://www.h2database.com/html/main.html</a></p>
<p dir="auto">You can also convert to MySQL if you have a greater familiarity with it or tools based upon it.</p>
]]></description><link>https://forum.mango-os.com/post/12385</link><guid isPermaLink="true">https://forum.mango-os.com/post/12385</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Tue, 09 Aug 2016 16:18:54 GMT</pubDate></item></channel></rss>
