<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Communication with Allen Bradley PLC]]></title><description><![CDATA[<p dir="auto">Is the abeip module in Mango store compatible with AB PLC compactlogix controller 1768?</p>
<p dir="auto">I need to communicate with the I/O devices via MangoES as a EtherNet/IP gateway. Since it is developed by Deltamation, will there any support or help available by infinite automation?</p>
<p dir="auto">Can anyone kindly share some insight or experience on the communication with AB PLC compactlogix?</p>
<p dir="auto">Thanks you!</p>
]]></description><link>https://forum.mango-os.com/topic/2359/communication-with-allen-bradley-plc</link><generator>RSS for Node</generator><lastBuildDate>Sun, 07 Jun 2026 13:46:49 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2359.rss" rel="self" type="application/rss+xml"/><pubDate>Fri, 22 Jul 2016 07:11:29 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Communication with Allen Bradley PLC on Mon, 25 Jul 2016 18:34:26 GMT]]></title><description><![CDATA[<p dir="auto">Depending on the hardware you have on site, you may be able lo do without. For example, we utilize Red Lion HMI's.</p>
<p dir="auto">The HMI could be used as a gateway to the AB PLC via Modbus.</p>
<p dir="auto">However the amount of work it requires outweighs the cost of the driver by a lot. Once the settings were correct, it hasn't let me down.</p>
]]></description><link>https://forum.mango-os.com/post/12150</link><guid isPermaLink="true">https://forum.mango-os.com/post/12150</guid><dc:creator><![CDATA[Brad_GMI]]></dc:creator><pubDate>Mon, 25 Jul 2016 18:34:26 GMT</pubDate></item><item><title><![CDATA[Reply to Communication with Allen Bradley PLC on Sat, 23 Jul 2016 00:55:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi Brad,</p>
<p dir="auto">Thank you so much for your valuable information.</p>
<p dir="auto">I will be involve in a job site having AB PLC 1768 controller.<br />
I am considering to communicate AB PLC via MangoES to perform engineering work on site.</p>
<p dir="auto">In fact I am hesitate to buy the abeip driver. Now I have decided to give it a try.</p>
<p dir="auto">Have a nice day!</p>
]]></description><link>https://forum.mango-os.com/post/12140</link><guid isPermaLink="true">https://forum.mango-os.com/post/12140</guid><dc:creator><![CDATA[Desmond]]></dc:creator><pubDate>Sat, 23 Jul 2016 00:55:17 GMT</pubDate></item><item><title><![CDATA[Reply to Communication with Allen Bradley PLC on Fri, 22 Jul 2016 20:31:29 GMT]]></title><description><![CDATA[<p dir="auto"><img src="https://camo.nodebb.org/9cf53627dbbb1074baf4f4d9a3ab9453677ba4c3?url=https%3A%2F%2Fi.imgur.com%2FKozdY0W.png" alt="0_1469219266137_ABEIP.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">If your processor is in a different slot than 0 you will have to match the slot field to the appropriate entry. Same for the rack field. You will get CIP errors otherwise.</p>
<p dir="auto">Once you've got the data source you just add the data points you want to view.</p>
<p dir="auto">I had issues trying to access the bit level field of an Integer type, so I had to create an Integer datapoint in Mango and break the bits out myself.</p>
]]></description><link>https://forum.mango-os.com/post/12136</link><guid isPermaLink="true">https://forum.mango-os.com/post/12136</guid><dc:creator><![CDATA[Brad_GMI]]></dc:creator><pubDate>Fri, 22 Jul 2016 20:31:29 GMT</pubDate></item><item><title><![CDATA[Reply to Communication with Allen Bradley PLC on Fri, 22 Jul 2016 15:49:07 GMT]]></title><description><![CDATA[<p dir="auto">Hi Brad,</p>
<p dir="auto">Thank you for your sharing.</p>
<p dir="auto">As I am unable to find any documentation on the abeip,  perhaps you can share with us on the setting up  the EtherNet/IP as a data source in the MangoES.</p>
<p dir="auto">If possible, a screen shot will be helpful to understand the configuration parameters.</p>
<p dir="auto">Thank you in advance.</p>
]]></description><link>https://forum.mango-os.com/post/12129</link><guid isPermaLink="true">https://forum.mango-os.com/post/12129</guid><dc:creator><![CDATA[Desmond]]></dc:creator><pubDate>Fri, 22 Jul 2016 15:49:07 GMT</pubDate></item><item><title><![CDATA[Reply to Communication with Allen Bradley PLC on Fri, 22 Jul 2016 14:04:43 GMT]]></title><description><![CDATA[<p dir="auto">I'm using the abeip driver to talk to a 1769 controller with 400 tags. I had an issue with loss of communication, which was a result of the poll rate being too slow. I'm using a 5 second poll rate now with interval logging which works for my application.</p>
]]></description><link>https://forum.mango-os.com/post/12126</link><guid isPermaLink="true">https://forum.mango-os.com/post/12126</guid><dc:creator><![CDATA[Brad_GMI]]></dc:creator><pubDate>Fri, 22 Jul 2016 14:04:43 GMT</pubDate></item></channel></rss>
