<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[TED - The Energy Detective data to Mango]]></title><description><![CDATA[<p dir="auto">I have successfully integrated TED, The Energy detective, into Mango. I have been using TED for over a year to track energy data in an effort to reduce electrical consumption and cost. The consumption has been reduced by over 15% but the cost has stayed the same since my utility keeps raising rates. Overall I have avoided the increased expenditure by reducing consumption.</p>
<p dir="auto">TED will output an XML file (not well known or documented) when commanded assuming you have the USB data option enabled. TEDService must be running but their "Footprints" software does not have to be to get the XML file. You can use the command "dashboarddata" to get the XML output.</p>
<p dir="auto">On the Mango side I used the HTTP Retreiver as a data source. In the URL I used "localhost:8085/dashboarddata" (TED default port is 9090). In my case TED is on the same computer as Mango so I used localhost. You could use any computer on your LAN as long as your firewall setting are correct and use that computers static IP. Then in the Value RegEx field I used &lt;DlrMtd&gt;(.*?)&lt;/DlrMtd&gt; to parse the XML file for specific data. In this example this returns the value for Dollars Spent Month-To-Date.</p>
<p dir="auto">See my public page at <a href="http://mikeshouse.homedns.org" rel="nofollow ugc">http://mikeshouse.homedns.org</a></p>
<p dir="auto">The 1-wire temp sensors are sitting on my desk so all the data is the same. I need to get around to running the Cat5 cable to the field devices.</p>
]]></description><link>https://forum.mango-os.com/topic/234/ted-the-energy-detective-data-to-mango</link><generator>RSS for Node</generator><lastBuildDate>Tue, 15 Sep 2026 06:49:03 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/234.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 02 Dec 2009 14:58:25 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to TED - The Energy Detective data to Mango on Sun, 21 Mar 2010 17:32:17 GMT]]></title><description><![CDATA[<p dir="auto">Hi,<br />
I just purchased the TED 5000 series... Will let you know how it works with mango shortly.</p>
]]></description><link>https://forum.mango-os.com/post/3467</link><guid isPermaLink="true">https://forum.mango-os.com/post/3467</guid><dc:creator><![CDATA[mjbcomputers]]></dc:creator><pubDate>Sun, 21 Mar 2010 17:32:17 GMT</pubDate></item><item><title><![CDATA[Reply to TED - The Energy Detective data to Mango on Wed, 09 Dec 2009 01:59:25 GMT]]></title><description><![CDATA[<p dir="auto">I am using the TED Model 1001 with the USB dataport enabled.</p>
<p dir="auto">This setup seems to be working well so far. I am trying to run the TED Footprints software and TED Service off of a flash drive. I did not like the way it accesses the hard drive once per second. It did not work well with a USB 1.0 flash drive. You can see gaps in my data the last few days. It was locking up with JAVA This is not a Mango problem. Tonight I moved it to a USB 2.0 Flash drive. We'll see what happens.</p>
]]></description><link>https://forum.mango-os.com/post/2928</link><guid isPermaLink="true">https://forum.mango-os.com/post/2928</guid><dc:creator><![CDATA[mhradom]]></dc:creator><pubDate>Wed, 09 Dec 2009 01:59:25 GMT</pubDate></item><item><title><![CDATA[Reply to TED - The Energy Detective data to Mango on Tue, 08 Dec 2009 03:17:34 GMT]]></title><description><![CDATA[<p dir="auto">could you tell me which TED are you using?</p>
]]></description><link>https://forum.mango-os.com/post/2924</link><guid isPermaLink="true">https://forum.mango-os.com/post/2924</guid><dc:creator><![CDATA[leolee22]]></dc:creator><pubDate>Tue, 08 Dec 2009 03:17:34 GMT</pubDate></item></channel></rss>
