<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[api access problems with swagger]]></title><description><![CDATA[<p dir="auto">I have problems to access the handle api to connect your database, I'm trying to swagger and gives me this error "Can not read from JSON swagger http : <a href="//xx.xx.xx.xx" rel="nofollow ugc">//xx.xx.xx.xx</a> : xxx / rest / api -docs "</p>
<p dir="auto">I was able to be due or I have to do to connect to the database and interact with it from html5 .</p>
<p dir="auto">Thanks in advance</p>
]]></description><link>https://forum.mango-os.com/topic/2292/api-access-problems-with-swagger</link><generator>RSS for Node</generator><lastBuildDate>Fri, 17 Apr 2026 05:30:30 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2292.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 14 Jun 2016 11:59:47 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to api access problems with swagger on Wed, 15 Jun 2016 13:29:41 GMT]]></title><description><![CDATA[<p dir="auto">Can you check that the property, "swagger.enabled=true" is in your env.properties file, which may either be at Mango/overrides/properties/env.properties or Mango/classes/env.properties</p>
]]></description><link>https://forum.mango-os.com/post/11815</link><guid isPermaLink="true">https://forum.mango-os.com/post/11815</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Wed, 15 Jun 2016 13:29:41 GMT</pubDate></item></channel></rss>
