<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[No pages will load: Timeout trying to lock table events]]></title><description><![CDATA[<p dir="auto">Every page I go to has this error:</p>
<pre><code>Server error: PreparedStatementCallback; SQL [SELECT evt.id,evt.typeName,evt.subtypeName,evt.typeRef1,evt.typeRef2,evt.activeTs,evt.rtnApplicable,evt.rtnTs,evt.rtnCause,evt.alarmLevel,evt.message,evt.ackTs,evt.ackUserId,evt.alternateAckSource,u.username,(select count(1) from userComments where commentType=1 and typeKey=evt.id) as cnt ,ue.silenced
FROM events AS evt left join users u on evt.ackUserId=u.id left join userEvents ue on evt.id=ue.eventId
WHERE ackTs IS NULL AND evt.alarmLevel &gt;= 1 AND ue.userId IN (?) ORDER BY activeTs DESC OFFSET ? ROWS FETCH NEXT ? ROWS ONLY];
Timeout trying to lock table "EVENTS";
SQL statement: SELECT evt.id,evt.typeName,evt.subtypeName,evt.typeRef1,evt.typeRef2,evt.activeTs,evt.rtnApplicable,evt.rtnTs,evt.rtnCause,evt.alarmLevel,evt.message,evt.ackTs,evt.ackUserId,evt.alternateAckSource,u.username,(select count(1) from userComments where commentType=1 and typeKey=evt.id) as cnt ,ue.silenced FROM events AS evt left join users u on evt.ackUserId=u.id left join userEvents ue on evt.id=ue.eventId WHERE ackTs IS NULL AND evt.alarmLevel &gt;= 1 AND ue.userId IN (?) ORDER BY activeTs DESC OFFSET ? ROWS FETCH NEXT ? ROWS ONLY [50200-181];
nested exception is org.h2.jdbc.JdbcSQLException: Timeout trying to lock table "EVENTS"; SQL statement: SELECT evt.id,evt.typeName,evt.subtypeName,evt.typeRef1,evt.typeRef2,evt.activeTs,evt.rtnApplicable,evt.rtnTs,evt.rtnCause,evt.alarmLevel,evt.message,evt.ackTs,evt.ackUserId,evt.alternateAckSource,u.username,(select count(1) from userComments
<p dir="auto">in the log I see:</p>
<pre><code>ERROR 2016-04-14 09:54:39,361 (com.serotonin.epoll.InputStreamEPoll.run:110) - Input stream callback exception org.springframework.jdbc.UncategorizedSQLException: PreparedStatementCallback;
uncategorized SQLException for SQL [insert into events (typeName, subtypeName, typeRef1, typeRef2, activeTs, rtnApplicable, rtnTs, rtnCause, alarmLevel, message, ackTs) values (?,?,?,?,?,?,?,?,?,?,?)];
SQL state [HYT00]; error code [50200]; Timeout trying to lock table "EVENTS"; SQL statement: insert into events (typeName, subtypeName, typeRef1, typeRef2, activeTs, rtnApplicable, rtnTs, rtnCause, alarmLevel, message, ackTs) values (?,?,?,?,?,?,?,?,?,?,?)
[50200-181]; nested exception is org.h2.jdbc.JdbcSQLException: Timeout trying to lock table "EVENTS"; SQL statement: insert into events (typeName, subtypeName, typeRef1, typeRef2, activeTs, rtnApplicable, rtnTs, rtnCause, alarmLevel, message, ackTs) values (?,?,?,?,?,?,?,?,?,?,?)
[50200-181] at org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:84) at
org.springframework.jdbc.support.AbstractFallbackSQLExceptionTranslator.translate(AbstractFallbackSQLExceptionTranslator.java:81) at
org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:645) at
com.serotonin.db.spring.ExtendedJdbcTemplate.update(ExtendedJdbcTemplate.java:112) at
com.serotonin.db.spring.ExtendedJdbcTemplate.update(ExtendedJdbcTemplate.java:95) at
com.serotonin.db.spring.ExtendedJdbcTemplate.update(ExtendedJdbcTemplate.java:91) at
com.serotonin.db.DaoUtils.doInsert(DaoUtils.java:159) at
com.serotonin.m2m2.db.dao.EventDao.insertEvent(EventDao.java:83) at
com.serotonin.m2m2.db.dao.EventDao.saveEvent(EventDao.java:51) at
com.serotonin.m2m2.rt.EventManager.raiseEvent(EventManager.java:111) at
com.serotonin.m2m2.rt.dataSource.DataSourceRT.raiseEvent(DataSourceRT.java:150) at
com.serotonin.m2m2.modbus.rt.ModbusDataSourceRT.receivedException(ModbusDataSourceRT.java:463) at
com.serotonin.modbus4j.sero.messaging.MessageControl.data(MessageControl.java:201) at
com.serotonin.modbus4j.sero.messaging.EpollStreamTransport$1.input(EpollStreamTransport.java:39) at
com.serotonin.m2m2.modbus.rt.MangoInputStreamCallbackWrapper.input(MangoInputStreamCallbackWrapper.java:30) at
com.serotonin.epoll.InputStreamEPoll.run(InputStreamEPoll.java:94) at
com.serotonin.timer.NamedRunnable.run(NamedRunnable.java:25) at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) at
java.lang.Thread.run(Thread.java:745) Caused by: org.h2.jdbc.JdbcSQLException: Timeout trying to lock table "EVENTS";
[50200-181] at org.h2.message.DbException.getJdbcSQLException(DbException.java:345) at
 org.h2.message.DbException.get(DbException.java:179) at
org.h2.message.DbException.get(DbException.java:155) at
org.h2.table.RegularTable.doLock1(RegularTable.java:504) at
org.h2.table.RegularTable.lock(RegularTable.java:469) at
org.h2.command.dml.Insert.insertRows(Insert.java:154) at
org.h2.command.dml.Insert.update(Insert.java:114) at
org.h2.command.CommandContainer.update(CommandContainer.java:78) at
org.h2.command.Command.executeUpdate(Command.java:254) at
org.h2.jdbc.JdbcPreparedStatement.executeUpdateInternal(JdbcPreparedStatement.java:157) at org.h2.jdbc.JdbcPreparedStatement.executeUpdate(JdbcPreparedStatement.java:143) at
com.serotonin.db.spring.ExtendedJdbcTemplate$1.doInPreparedStatement(ExtendedJdbcTemplate.java:119) at
com.serotonin.db.spring.ExtendedJdbcTemplate$1.doInPreparedStatement(ExtendedJdbcTemplate.java:112) at
org.springframework.jdbc.core.JdbcTemplate.execute(JdbcTemplate.java:629) ... 17 more
WARN 2016-04-14 09:54:39,746 (com.serotonin.m2m2.rt.dataSource.PollingDataSource$2.execute:226) - PLC0: poll scheduled at 2016/04/14 09:54:39.744 aborted because Task Currently Running
WARN 2016-04-14 09:54:39,746 (com.serotonin.m2m2.rt.dataSource.PollingDataSource$2.execute:226) - Unit 2: poll scheduled at 2016/04/14 09:54:39.744 aborted because Task Currently Running
<p dir="auto">Any advice as to how I should proceed to get mangoES working again?</p>
<p dir="auto">Craig</p>
]]></description><link>https://forum.mango-os.com/topic/2214/no-pages-will-load-timeout-trying-to-lock-table-events</link><generator>RSS for Node</generator><lastBuildDate>Mon, 09 Mar 2026 09:12:06 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2214.rss" rel="self" type="application/rss+xml"/><pubDate>Thu, 14 Apr 2016 16:58:17 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to No pages will load: Timeout trying to lock table events on Fri, 29 Apr 2016 13:05:40 GMT]]></title><description><![CDATA[<p dir="auto">It is released.</p>
]]></description><link>https://forum.mango-os.com/post/11493</link><guid isPermaLink="true">https://forum.mango-os.com/post/11493</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 29 Apr 2016 13:05:40 GMT</pubDate></item><item><title><![CDATA[Reply to No pages will load: Timeout trying to lock table events on Thu, 28 Apr 2016 16:13:10 GMT]]></title><description><![CDATA[<p dir="auto">Hi Craig,</p>
<p dir="auto">I will push to get this out for you as soon as possible.</p>
]]></description><link>https://forum.mango-os.com/post/11492</link><guid isPermaLink="true">https://forum.mango-os.com/post/11492</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 28 Apr 2016 16:13:10 GMT</pubDate></item><item><title><![CDATA[Reply to No pages will load: Timeout trying to lock table events on Tue, 26 Apr 2016 00:12:58 GMT]]></title><description><![CDATA[<p dir="auto">I'm hopeful you can release this module this week, with or without additional changes.  The operator from the power plant down the road has shown his scheduled e-mail reports to the operator from a power plant further down the road, I'd say you will have another mango ES sale coming down the pipe soon, but I probably won't have access to that one after the initial set up, so it would be helpful if the report disk space leak issue fix can be released.   Thanks</p>
]]></description><link>https://forum.mango-os.com/post/11480</link><guid isPermaLink="true">https://forum.mango-os.com/post/11480</guid><dc:creator><![CDATA[craig]]></dc:creator><pubDate>Tue, 26 Apr 2016 00:12:58 GMT</pubDate></item><item><title><![CDATA[Reply to No pages will load: Timeout trying to lock table events on Fri, 15 Apr 2016 21:28:58 GMT]]></title><description><![CDATA[<p dir="auto">We need to release it. There is one other change that is trying to sneak in to the Reports module. I will try to get this module released for you on Monday next week.</p>
]]></description><link>https://forum.mango-os.com/post/11440</link><guid isPermaLink="true">https://forum.mango-os.com/post/11440</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Fri, 15 Apr 2016 21:28:58 GMT</pubDate></item><item><title><![CDATA[Reply to No pages will load: Timeout trying to lock table events on Fri, 15 Apr 2016 03:17:24 GMT]]></title><description><![CDATA[<p dir="auto">i had run out of disk space again.</p>
<p dir="auto">looks like a fix for the issue has been committed: <a href="https://github.com/infiniteautomation/ma-core-public/issues/687" rel="nofollow ugc">https://github.com/infiniteautomation/ma-core-public/issues/687</a></p>
<p dir="auto">What needs to happen for this fix to reach my mangoES via the check for upgrades function?</p>
]]></description><link>https://forum.mango-os.com/post/11425</link><guid isPermaLink="true">https://forum.mango-os.com/post/11425</guid><dc:creator><![CDATA[craig]]></dc:creator><pubDate>Fri, 15 Apr 2016 03:17:24 GMT</pubDate></item></channel></rss>
