<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Mango osx - Modbus over Serial issues]]></title><description><![CDATA[<p dir="auto">I have Mango running on a Linux box core 2.4.0 and modbus 1.4.8 talking to several devices using serial over xbee. All works fine for over a year. I decided to install the latest mango in OS X El Capitan release. The system works for a while then I get the "point may not unreliable message" for modbus points. The http retriever points refresh ok.. The only way I can make it work is shutdown mango and remove and connect my USB serial connection. It runs for 2 hours or 15 minutes then cannot collect data. I have core 2.7 and modes 1.6.5 installed in osx. I installed via download and then did an in-1place upgrade in Mango UI.</p>
<p dir="auto">If go back to the linux box and plug in the USB serial, all is good.   I'm at a loss. I first I thought it was some energy saving mode and disabled that.</p>
]]></description><link>https://forum.mango-os.com/topic/2195/mango-osx-modbus-over-serial-issues</link><generator>RSS for Node</generator><lastBuildDate>Mon, 16 Nov 2026 13:57:35 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2195.rss" rel="self" type="application/rss+xml"/><pubDate>Sun, 27 Mar 2016 01:20:57 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Mango osx - Modbus over Serial issues on Thu, 31 Mar 2016 16:56:55 GMT]]></title><description><![CDATA[<p dir="auto">If you encounter trouble getting it to start and can't find answers to the issues you encounter, We'll certainly answer posts here trying to help you get it going.</p>
]]></description><link>https://forum.mango-os.com/post/11371</link><guid isPermaLink="true">https://forum.mango-os.com/post/11371</guid><dc:creator><![CDATA[phildunlap]]></dc:creator><pubDate>Thu, 31 Mar 2016 16:56:55 GMT</pubDate></item><item><title><![CDATA[Reply to Mango osx - Modbus over Serial issues on Thu, 31 Mar 2016 02:16:44 GMT]]></title><description><![CDATA[<p dir="auto">The reason I was trying some other OS is that the latest release of Mango won't startup on my Linux system. I have am arm hardware running Ubuntu 12.04 LTS with a soft float release.  It is oldish and runs fine. I used the OSX as it had a mac mini sitting on the shelf doing nothing it thought it would be good dev box for experimenting, I've given up. I am going to upgrade the the linux with hard float in a sand box to see if the new version of Mango will work with the latest jdk.</p>
<p dir="auto">It worked fin on the windows OS as well. Not one com error. OSX will remain just iOS dev env.</p>
<p dir="auto">pjc</p>
]]></description><link>https://forum.mango-os.com/post/11368</link><guid isPermaLink="true">https://forum.mango-os.com/post/11368</guid><dc:creator><![CDATA[chrapchp]]></dc:creator><pubDate>Thu, 31 Mar 2016 02:16:44 GMT</pubDate></item><item><title><![CDATA[Reply to Mango osx - Modbus over Serial issues on Wed, 30 Mar 2016 22:55:29 GMT]]></title><description><![CDATA[<p dir="auto">This is strange, we've not had any issues with Modbus Serial in Mango but I also don't know of many or any applications that use Mac OSX as the production system.</p>
]]></description><link>https://forum.mango-os.com/post/11366</link><guid isPermaLink="true">https://forum.mango-os.com/post/11366</guid><dc:creator><![CDATA[JoelHaggar]]></dc:creator><pubDate>Wed, 30 Mar 2016 22:55:29 GMT</pubDate></item></channel></rss>
