<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Network routers map in Default Transport is not unique]]></title><description><![CDATA[<p dir="auto">We have a case where multiple bacnet networks have same id and different network address.<br />
This make it difficult for us to get to them since the MAP defined in Default transport is per network number only and the bacnet STACK cannot make a difference between the networks.</p>
<p dir="auto">So for example:<br />
Remote device 1 on Network 2 with Network address  x.x.x.x<br />
Remote device 2 on Network 2 with Network address  y.y.y.y</p>
<p dir="auto">I would appreciate if someone can tell me:<br />
Is something configured bad in the network or is it a valid configuration.<br />
If it’s valid I will expect some solution to be able to initialize the Default router MAP only once and be able to access  all remote devices uniqly like I used to do in older versions.</p>
<p dir="auto">Thanks.</p>
]]></description><link>https://forum.mango-os.com/topic/2141/network-routers-map-in-default-transport-is-not-unique</link><generator>RSS for Node</generator><lastBuildDate>Wed, 15 Jul 2026 04:07:03 GMT</lastBuildDate><atom:link href="https://forum.mango-os.com/topic/2141.rss" rel="self" type="application/rss+xml"/><pubDate>Tue, 23 Feb 2016 10:31:10 GMT</pubDate><ttl>60</ttl></channel></rss>
